Sponsored by:
Sponsored by: CARiD
noob question: how do you decrease or increase compression?
Old Jul 21, 2006 | 09:47 AM
dawalkster's Avatar
is craving Bojangles
So one question that's been on my mind recently is what exactly compression is, and how you tune it. I understand that boosted cars need a lower compression so that it can handle high amounts of boost; and high revving all motor cars usually have high compression. What else should i know?
Also, say i wanted to lower or raise compression - how would one go about doing that? I realize its not a simple thing to do. And once you do lower/raise compression how do you test to see what your compression is?
help a noob out, or atleast give me links to places where i can learn the answers
Old Jul 21, 2006 | 10:10 AM
Nealoc187's Avatar
SLOW
you calculate what your static compression is. it's just a mechanical calculation, combustion chamber volume at BDC vs TDC. if the volume is 10 times bigger at BDC than TDC, you have 10:1 compression. If the volume is 8x bigger at BDC than TDC, you have 8:1 compression.
You can change it (static compression) by changing the thickness of your head gasket, milling the head or block, pistons of different combustion area design, etc. You can't "tune" it, you have to actually change parts to change it.
Old Jul 21, 2006 | 03:09 PM
JClaw's Avatar
Increasing displacement with the same volume combustion chamber is a real winner because it also yields higher compression.
Old Jul 21, 2006 | 04:11 PM
nismology's Avatar
This statement is rather vague.
Old Jul 21, 2006 | 06:59 PM
eng92's Avatar
Just a roundabout way of saying that you can get more power by "stroking" an engine
Old Jul 21, 2006 | 07:37 PM
nismology's Avatar
Understood but i didn't quite understand how it was germane to what the OP was asking about.
Old Jul 23, 2006 | 08:40 PM
f550maranello2's Avatar
changing pistons to deep dish also changes the compression... same with connecting rods...
Old Jul 23, 2006 | 08:47 PM
DAVE Sz's Avatar
Hooooooonda.....
I just used Seafoam.
Old Jul 25, 2006 | 06:48 AM
YellowNinja's Avatar
seafoam wont do anything but restore the original compression in the engine. so it wont really be changing it.
Old Jul 25, 2006 | 08:21 AM
nismology's Avatar
It won't even do that.
He was being sarcastic, BTW.
Old Jul 25, 2006 | 08:33 AM
GoalieKeg's Avatar
I put in octane booster and injector cleaner at the same time and it gave me .5 seconds in the 1/4 mile, it also polished my heads for me.
Old Jul 25, 2006 | 11:20 AM
MaximaSE96's Avatar
Maxima Owner
if u want to lower u can also use 3.5 heads on a 3.0...but there are many ways....to raise...milling heads....different pistons made for Higher or Lower Comp.....thicker head gasket.....stroker kits for the 3.5 guys....
Old Jul 25, 2006 | 02:31 PM
BEJAY1's Avatar
Conecarver
Are there any aftermarket head gasket's avail for the VQ30DE? I was just reading about a CRX that used a .025" thinner gasket for about 1pt compression increase.
Old Jul 25, 2006 | 09:01 PM
haha d*mn it, now i feel like a dumb a$$.
Old Jul 27, 2006 | 07:18 AM
Luquire's Avatar
So if i was going to use forced induction like nitrous on the max i should use the 3.5 head on my 3.0.
Old Jul 27, 2006 | 08:58 AM
SPiG's Avatar
SomePsychoGuy
To go through the trouble and expense of changing the heads you might as well use the entire VQ35 block. The VQ can hold a lot of boost if tuned correctly. The only reliable way on a VQ to change compression is to use aftermarket pistons.
Different thickness head gaskets aren't the best idea as they will affect cam timing and possibly fitment of the lower IM and the timing chain covers. If we had inline engines with adjustible cam gears like RBs, SRs and hondas then we could do this.
Old Jul 27, 2006 | 09:04 AM
nismology's Avatar
I personally wouldn't use heads with a larger bore than the block. The name of the game is to sqeeze the a/f mixture toward the center where the spark plug is. That's what the squish area is for. With that hybrid setup, some of the mixture would sneak out to the periphery. It could work, but it just wouldn't be optimal IMO.
Old Jul 27, 2006 | 09:08 AM
nismology's Avatar
It has more do with with the fact that they use timing belts than anything else.
Old Jul 27, 2006 | 10:15 AM
DrTySOUFMaX23's Avatar
im trying to understand this too but you lost me at "combustion chamber volume at BDC vs TDC"
Old Jul 27, 2006 | 10:35 AM
nismology's Avatar
It's the ratio between the volume of the cylinder at the bottom of it's stroke versus the volume at the top of the stroke. For example, if a cylinder's volume is 400cc's at bottom dead center and 40cc's at top dead center, it has a compression ratio of 10:1.
Old Jul 29, 2006 | 07:59 PM
MaximaSE96's Avatar
Maxima Owner
word......like the vg guys could get away with adjustable cam gears...i dont remember id anyone makes them maybe for the 300zx vgs
Old Aug 2, 2006 | 08:44 AM
datsun40146's Avatar
You really can "tune" compression, and the best way to increase it is to shave the heads down.
Old Aug 2, 2006 | 08:57 AM
nismology's Avatar
I would disagree. That's the worst option because of the reasons posted in the second paragraph of post # 16. For these engines, aftermarket pistons are THE option.
Old Aug 2, 2006 | 09:14 AM
speed racer's Avatar
So if guys wanted to stay all motor with the 3.0 block and raise compression would that mean that one would have to get custom piston and rods or does a manufacture sell them already?
Old Aug 3, 2006 | 08:21 AM
SPiG's Avatar
SomePsychoGuy
OK let me rephrase, If you change the CR through the head or head gasket many parts will not line up correctly since we have a V engine (could be fix through some creative dremeling and machining), and our cam timing will be off because we have a timing chain and can't use adjustible cam gears (not as easy thing to fix).
If you are going to go throught the trouble of building an engine you should probably just get a VQ35. Increasing the CR will not give you that much power for it to be worth tearing the motor apart. Hell for that trouble you should get the 100mm Darton sleeves and pistons with a VQ40 crank or some other stroker kit and get a 3.8-4.3L VQ and have 350-400whp NA with some good cams.The VQ30 has a good amount of potential NA, but the VQ35 does have more and has off the shelf internals that are becoming cheaper and cheaper. Building a VQ30, especially a NA VQ30, just doesn't seem practical.
However you really don't need to think about building any VQ anytime soon. A well modded, EMU tuned, VQ30 with a DE-k manifold could easily have more Hp than most VQ35s and will be plenty fast. Very few Maxima people have built their engine with turbo, and no one has done it for NA AFAIK.
Old Aug 3, 2006 | 08:29 AM
nismology's Avatar
I understand all this. All i meant was that it's not easy to dial the cam timing back to stock because we don't use a timing belt setup.
I plan on being one of the first. The plan eventually is headwork, 11.5:1's, and cams in a 3.5.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
maxinout93
Oct 31, 2015 02:04 AM
trsandrew
Oct 25, 2015 02:47 PM
