Sponsored by:
Sponsored by: CARiD
3.5 swap! Has anyone retained the EGR from the 4th gen? How?
Old Jul 31, 2006 | 03:05 PM
csb's Avatar
csb
Please enlighten me. Thanks in advance.
Old Jul 31, 2006 | 03:14 PM
GoalieKeg's Avatar
You can't do it with your motor and manifold because you don't have the external EGR port. 04+ maximas are the only ones that have it. There is no point in trying to make a custom pipe welded to the manifold anyways. You'd also have to make a custom adapter for the 4th gen EGR to sit properly on the 3.5 heads as well so that the copper pipe will match up with both the EGR and the manifold. There is no real point in retaining the EGR, it's more hassle than anything with the 3.5 swap. Cap or have the header welded shut and call it a day.
Old Jul 31, 2006 | 03:21 PM
csb's Avatar
csb
Hey Dan...thanks...that's kinda' what I thought. Have you hit 13's yet or is it still too d$&n hot ?
Old Jul 31, 2006 | 03:38 PM
GoalieKeg's Avatar
Way too damn hot...E-manage Ultimate is on the way though. That'll for sure get me into easy 13's with good track and weather.
Old Jul 31, 2006 | 08:23 PM
krismax's Avatar
Father of the 00 VI
easy to do cut your EGR tube in half cut a 04 IM tube in half throw away the 04 piece that goes to egr throw away your egr to IM side then attach with high temp hose all done.
just hook all your egr tubes back up to simialr spots and plug connections back in if your keeping your stock ecu then its simple
Old Jul 31, 2006 | 08:34 PM
tavarish's Avatar
fwd gone rwd cr00
block off egr, plug in all sensors. easy as pie.
Old Jul 31, 2006 | 08:44 PM
mforrest100's Avatar
Man you just come out the blue....I swear you post about once a month.
Old Aug 1, 2006 | 06:22 AM
Kevlo911's Avatar
Kevlo for President
Lurking > posting
Old Aug 1, 2006 | 06:49 AM
WielkiWaac's Avatar
MaximaDriver
how about egr error code if you using old ecu??
Old Aug 1, 2006 | 08:55 AM
GoalieKeg's Avatar
You won't have one if you retain the old EGR equipment.
Old Aug 3, 2006 | 10:52 AM
oTranscendental's Avatar
If you lose the egr, will you fail emissions? I dont even know If i still have mine.
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Blackwind
Aug 5, 2015 06:35 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
