So I set the new revlimit record
BY ACCIDENT
I have a spike in fuel starting around 6000, I know this and I know why so don't say ****.
Timing jumps at 6600 so I am gonna have to do something about that. It didn't feel like it was knocking.
So you might be wondering why I took the rpm's so high... I set the limit to 7200, I floored it in neutral and it never stopped!!!!!
The ONLY map that goes past 7200 is the NCVS map, the Revlimt LIMIT was 7200, the Injector map and Ignition map both stop at 7200.
Originally Posted by Zack342
I mis-shifted and hit 8600rpm
but that could have also been from detonation, who knows.
I was asking....I thought it was the same setting.
Do you feel the ignition cut is better, then a fuel cut?
Why not? It's a separate setting. I don't launch at 7800...
Rather have a wasted spark than wasted fuel....
BTW I got the wideband in today, I am gonna tune later this afternoon if the rain stops. Car is quite rich, 10-11's at WOT.
Originally Posted by IceY2K1
Why would you prefer that over just reducing IPW?
?? I'm not, I rather have a fuel cut, I am saying the disadvantage of a ignition cut. Both for safety tho.
I am not sold on one being significantly better than the other.
An ignition cut wastes fuel yes, but if it kicks in like a 2-step it's not as hard as slamming the wall like the stock ECU cut (removing almost all fuel).
A soft fuel cut (reducing PW but not to zero) gives you a softer cut yes but if you've got the foot on the floor the engine momentum and the effect of the interpolation between cells will still carry you up past the cut a ways.
And, would a soft fuel cut (suddenly lean mixture) on a FI car at high rpms cause problems? I don't know. Maybe it's occurring quick enough (ie for a short enough duration) the engine can survive it. What kind of cuts do FI cars typically have?
I figured...*KABOOM*, however viewing jeremeys' hard fuel cut logs, apparently for at least 600rpm or so.
I think many use ignition cut along with cutting boost.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
scary, and here I am looking into getting one... I'm surprised it didn't hurt anything...
