Sponsored by:
Sponsored by: CARiD
Z IM questions
Old Aug 3, 2006 | 10:43 AM
oTranscendental's Avatar
Z IM questions
So I've been interested in the Zim and looking at the 350 forums.
I called a dealership and asked about the difference between the 287hp and 300hp lower plenum. They said the ports are different and if I was trying to do this with my motor "i should go with the 287 plenum".
Well from what he said the 300hp version has more aggressive intake cams. I don't know how this would make the ports so different that I couldn't use the 300hp ZIM.
Any input? Also, whats the deal with the Z plenum not having butterfly plates; is it making more power just like that?! Just confused as to why the max has a VI and the Z doesn't.
Old Aug 3, 2006 | 02:00 PM
Hoooper
i would say he told you to get the 287 intake because the 300 has different cams which you would need to take advantage of the different runners. the ports im pretty sure are the same, but the runner lengths are different.
Old Aug 3, 2006 | 09:36 PM
What if I used a piggyback tuner though? The Mrev guys use the 287 lower plenum with the MD spacer.
Old Aug 3, 2006 | 11:17 PM
Hoooper
you still wouldnt get the full potential of the high RPM hp without the cams. you could get some of the power back, but you would see a loss at lower rpms. i would go for the 287. however, dyno's have been done that show overall without using VTC's, a Z im has less area under the curve than the 2k2 im. so maybe you should stick with the 2k2 im on your vq
Old Aug 4, 2006 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
Anyone ever try and pull MAF V on an A32 to gain some torque? This might help build some area under the curve when using this IM set-up.
Old Aug 10, 2006 | 01:04 PM
meximax's Avatar
SC Overspinning Swapper!!
No worthy a sticky or anything, but this thread could probably answer a couple of your VQ35 intake manifold questions.
http://forums.maxima.org/showthread.php?t=475915
Old Aug 10, 2006 | 01:24 PM
nismology's Avatar
You're better off modifying the stock 2k2 intake manifold.
Old Aug 10, 2006 | 02:04 PM
meximax's Avatar
Z manifold modifications can be found all over this forum. I don't think there are any on 2k2 modifications.
I do miss the big torque my 2k2 IM. However, the Z IM with MD spacer did give me 20 whp (13 w/o spacer) more at than the "stock" 2k2 at 6500 rpm. Couple the Z manifold with aftermarket cams or forced induction and you are in for plenty of high end power.
Old Aug 10, 2006 | 02:32 PM
nismology's Avatar
Just because there aren't many threads about it doesn't mean people haven't done it or it can't be done.
Old Aug 10, 2006 | 04:43 PM
NmexMAX's Avatar
dot dot dot ...
I made 22 more whp @ 6550 with my modified 2k2 IM..
nismology
Old Aug 19, 2006 | 05:17 PM
BUSi87's Avatar
I was thinking about getting the Z im too but after talkin to from friend Ricky from Industrial Performance, he said he'll do a full race port to my stock max im and get way more power than i ever will with a Z im... ummm this goin happen in like 3 weeks so i'll update u on that.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
