Sponsored by:
Sponsored by: CARiD
What's the torque spec for '97 flywheel?
Old Aug 7, 2006 | 07:14 PM
csb's Avatar
csb
Thx for the help.
Old Aug 7, 2006 | 07:57 PM
GodFather's Avatar
Made in Taiwan
I had the car up the rack and a good set of air tools handy at the shop. All I did was air-gun that sunabich till it can't torque in anymore. If you try hand tools, you'd have to make sure you stationed the crank pulley to zero movements.
My point is...Anything that would tend to turn while I"d torque it down, I would definitely use heavy duty air tools. They do miracles and save time.
But, contrary to answering your question...I don't have an answer. My air gun torqued flywheel never gave me a problem.
Old Aug 7, 2006 | 08:02 PM
csb's Avatar
csb
Why would I have to keep the crank pulley still if the timing gear is all on and the case is sealed?
Old Aug 7, 2006 | 08:30 PM
GoalieKeg's Avatar
61-69 ft lbs. Please make sure you do them in sequence.
Old Aug 8, 2006 | 04:30 PM
NmexMAX's Avatar
dot dot dot ...
What was the torque set @?
Old Aug 8, 2006 | 06:31 PM
matty's Avatar
What Sequece ?? You guys add a bit of lock tight on the threads ?
-matt
Old Aug 8, 2006 | 06:56 PM
csb's Avatar
csb
Lock tite...yes...as for sequence, just tighten bolts on sides opposite each other as you go around (kind of like a star pattern with many points).
Old Aug 8, 2006 | 09:21 PM
GodFather's Avatar
Made in Taiwan
I wasn't aware what torque setting it was on. That's why I said I didn't have an answer for him. But I believe they've been using the same torque specs for that air gun forever. I've never seen it flipped higher or lower. It's always at the **** spot.
Old Aug 8, 2006 | 09:31 PM
ThurzNite's Avatar
this needs to be stickied: http://forums.maxima.org/showthread.php?t=440195
Jae
Old Aug 9, 2006 | 05:09 AM
GoalieKeg's Avatar
This is dangerous. It's a good way to strip your crank bolts...
Old Aug 9, 2006 | 10:08 AM
csb's Avatar
csb
That's what I was thinkin'...I'm far too **** not to use a torque wrench for nearly everything (but then you know that, don't you GoalieKeg).
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
The Wizard
24
Oct 1, 2015 08:47 PM
