Sponsored by:
Sponsored by: CARiD
00VI PCV Valve setup
Old Mar 5, 2008 | 05:34 PM
  #41
speed racer's Avatar
Its best if you get a reducer a 1/2" to 3/8" barb fitting. The 1/2" side will fit the PCV on the fat side. Just use the 3/8" hose on the other side.
On the same topic but different problem. Has anyone modified the 4th gen rear valve cover with a horizontal barb fitting and is experiencing some yellow liquid coming out. I think the brass barb fitting is deteriorating.
Old Mar 11, 2008 | 01:49 PM
  #42
ajcool2's Avatar
I'm running a reducer on the hose coming from my iacv could that be cause the iacv code?
Old Mar 11, 2008 | 05:39 PM
  #43
MOHFpro90's Avatar
Speedracer, I did, but dont have any yellow liquid...hmmm, maybe its oil + some brass residue?
ajcool, No, it wouldnt. You are running the 4th gen right? Ive got a spare if you want it.
Old Mar 11, 2008 | 07:01 PM
  #44
What size reducer? As long as there's no leaks you should be fine, but at the same time you want the IACV to have enough air. Sometimes 3/8" works sometimes it doesn't. Its a hit and miss on different maximas.
Old Mar 11, 2008 | 08:45 PM
  #45
Tatanko's Avatar
Bacon Lover
How recently did you change the oil?
It wouldn't throw a code, I wouldn't think. My hose was kinked at one point right after my initial installation and although the IACV wasn't receiving enough air, it still didn't throw a code.
Old Mar 14, 2008 | 10:55 AM
  #46
[QUOTE=Tatanko;6294262]How recently did you change the oil?
/QUOTE]
Change the oil religiously at 4k miles. Its been happening for a while. I thought it was my old oil catch can setup which was the home depot one. But I since changed to one of those ebay catch cans. Its better but I know for sure the yellow residue is from the barb fitting. I'm almost tempted to just get a 5th gen rear valve cover to fix the situation.
Old Mar 14, 2008 | 12:08 PM
  #47
ajcool2's Avatar
I think I'm just going to replace my IACV this weekend.
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
