Sponsored by:
Sponsored by: CARiD
3.5 misfiring at low rpms.
Old Aug 13, 2006 | 05:29 PM
GodFather's Avatar
Made in Taiwan
Got a new issue today, car ran fine for 2 days, very strong and smooth.
All of a sudden today, after I park it a couple hours to go shopping with my gf it start up fine but misses at idle. Then I drove it and it misses at all rpms below 3k. After 3k, it's fine. Weird...
Well, upon completion of the swap, the idle does seem to be missing, but once I rev up beyond 1k, it's gone, I assume it's the jwt cams that's doing that. But today, the problem got a little worse and I don't know what it is. Got a CEL and it's 0701 and 0604, that's multiple misfiring and cylinder 5 misfiring. The car can drive and can idle without stalling, but it just shakes and misses at lower rpms and idle like I mentioned. I took it home for diagnositcs, injectors seemed fine, coils checked out, spark plugs seemed glazed and stupid me, I was using the 3.0 spark plugs. I went to get the 3.5spark plugs--they are like half an inch longer in the threads section. After the sparkplugs, same problems was at hand, it just misses and feels like it's hard to climb up the rpms, but once it goes past 3k, it's a smooth and strong ride again.
Can anyone give some pointers again? Thanks
-Peter-
Old Aug 13, 2006 | 07:25 PM
diymaximakid's Avatar
what are you using as fuel management
Old Aug 13, 2006 | 08:44 PM
GodFather's Avatar
Made in Taiwan
none as of now, i'm still waiting shipment on my wideband plxm300. I'm buying the walbro fuel pump and a fpr at a local shop tomorrow. only after fuel setup and wideband installed will i install the EU. I got the EU, i just don't want to install it before I am fully ready to tune it.
but the problem has come down to occasions. I can drive this car half the time being normal and half the time missing but without the cel. very weird.
Old Aug 14, 2006 | 10:46 AM
I would say that your getting to much fuel down low for it to burn,but that doesnt sound like a fuel problem.Jus make sure all your sensors are tighten down and all the connections are on securely.
Old Aug 14, 2006 | 11:36 AM
nismology's Avatar
The ECU will adjust it's short-term fuel trims to compensate for the larger injectors. That's not it.
Old Aug 14, 2006 | 01:29 PM
GodFather's Avatar
Made in Taiwan
I don't have larger injectors in my setup. I get to use my stock 4th gen sidefeed injectors. If fuel is concerned, it should be lean in my opinion. So I don't think it's fuel.
Anyways, I found the problem already. It's the wires for the coilpack harness, the hot lead got burned up and melt off to exposed the wires and was also burning off the signal lead wire for cylinder 3 and 5. So today I used some heat shield sleeves and taped them all up and dandy. Now the car runs like a beast again. Thanks for your inputs.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
zmcneely13
Sep 26, 2015 02:26 PM
