Sponsored by:
Sponsored by: CARiD
New Motor is In !!! Pics !!
Old Aug 21, 2006 | 02:54 PM
matty's Avatar
I posted this up here since It gets a bit more viewers than the S/C forum...plus alot of guys wanna know about the DEK swap in here.
My Following Setup Changes:
- VQ3.0-DEK with 8,500 confermed miles
- 2001 5speed Trans with 15,000 miles
- Clutch Net 6 puck Sprung Hub Clutch
- NEW Fidanza Flywheel
- All new MT-90 Trans oil
- Pathfinder Throttle Body
- NO EGR Components
- 2.87 Pulley
- New K&N Cone Filter
- SS Auto Chrome Shorty Headers
- 555 cc Deatschwerks Injectors
- 4th Gen lower Manifold
- Front and Rear ES Motor Mounts
- Nissan New side (2) Motor Mounts
- ES Lower Control Arm bushings
- NEW Outer Tie rod ends
- NEW ES Sway bar bushings
- NEW 99' Steering Rack
- NEW Nissan Power Steering Pump ($322)
A few things I need to do is:
--My fans arent turning on. Weather its related to the Emanage or not, I have no idea ??
--I also have to extend the Charge pipe so it sits even. I hate it on an angle. Im gonna bring out from the TB.
--I have to make everything neater on the top of the motor and Mound the IACV.
--Adjust the TPS when hot (I did it when it was cold but hot is when they say it should be done)
After about 8 weeks of waiting im finally done. When I took out the old motor I found that the front rad support was rusted right through. Well I had to have it towed to the body shop, and fixed. That took about 6-7 weeks since they couldnt get me right in.
I got it started Sunday morning and kept blowing through spark plugs. I went through 2 sets of plugs before I finally figured out to mess with the lag setting for the injectors. I had to change the oil as well since it stunk like fuel.
matty's Avatar
Old Aug 21, 2006 | 02:56 PM
matty's Avatar
Rad Support
Final Product:
Old Aug 21, 2006 | 02:57 PM
matty's Avatar
Old Aug 21, 2006 | 03:06 PM
Nismo3112's Avatar
Custom User Title
Nice!!! I love engine swaps... Nice rad support too!!
Old Aug 21, 2006 | 03:22 PM
matts95max's Avatar
Dude that looks very clean! im hoping that my 3rd attempt at the de-k will prove worthy and reliable! I was wondering when you were going to get everything done. How is everything working together? big dif from the de with the s/c since you have that vi now?
Old Aug 21, 2006 | 04:16 PM
tavarish's Avatar
fwd gone rwd cr00
hey man, i have an 01 engine cover, want it? im in NJ, and you can chek out my swap as well. (i'm gonna SC it when i have the money)
Old Aug 21, 2006 | 04:30 PM
LA02MAX's Avatar
why would you wanna cover up that awesome polished valve cover? I think it looks with the cover off. just my opinion though.
Old Aug 21, 2006 | 04:54 PM
Zack342's Avatar
looks good
Old Aug 21, 2006 | 06:01 PM
hightuner's Avatar
Nissan maniaco conpulsif
looks sick man
Old Aug 21, 2006 | 06:22 PM
matty's Avatar
The angle of the Charge Pipe really bothers me so I gotta order some more silicone and clamps. I have a bit of piping left over.
I got the idle worked out, I just dont know what my fans arent kicking on ? Im puzzled.
-matt
Old Aug 21, 2006 | 06:28 PM
gtr_rider's Avatar
192.168.1.1
Great job.. My friends needs the same work done to his rad support.. Silly nissan
Old Aug 21, 2006 | 08:29 PM
JeEvE's Avatar
Congrats on the swap, looks very clean.
Have a few questions...
Did you make the TB adapter yourself and how difficult was it to replace the rad support, I noticed mine was rusted but I didnt really look into how hard it would be to replace it.
Also, do the SS Autochrome Headers have a hole for the EGR guide tube and does it bolt up to a stock y-pipe?
Old Aug 21, 2006 | 08:48 PM
matty's Avatar
Stephan Max made them for me. The Rad support I had done at the Body shop. Took a bit of time, But I think with the motor in, would have been double the amount of Labor just because of the lack of room. The a/c does need to be discharged which s*cks.
Yes. It has the same pipe that feeds to the EGR valve like the stock headers have. I had that cut off and the hole welded shut. Yes. They do bolt up to the stock Y-pipe.
-matt
Old Aug 22, 2006 | 07:35 AM
hightuner's Avatar
sup matty , since u have a 96 like me
I guess you can confim me if the NEW 99' Steering Rack fit perfectly ?? like the 96
do you need to swap anything else to make it work ?
i am also doing a 3.5 and i wonder if i should change it too , while the engine is out thanks
Old Aug 22, 2006 | 08:18 AM
mforrest100's Avatar
Picked up a 99 Steering Rack from here.
http://buy-steering.com/index.htm
Went in without any problems.
Old Aug 22, 2006 | 09:34 AM
hightuner's Avatar
cool thx, 10 char
Old Aug 22, 2006 | 09:45 AM
JeEvE's Avatar
Any difference with the 99 rack compared to the previous years?
Old Aug 22, 2006 | 10:18 AM
MDeezy's Avatar
Sexy matty, this was a long time in the works. Enjoy!
Old Aug 22, 2006 | 01:03 PM
ofgortens's Avatar
Great job... looks awesome... hope it runs as well as it looks
Old Aug 22, 2006 | 03:58 PM
Stillen Maxima's Avatar
Pay to Play
!!!!!!BEAUTIFULL!!!!!!GOOD JOB
Old Aug 22, 2006 | 04:17 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Looks great!
Check your EU jumpers for the fans...I set mine wrong and they wouldn't turn on correctly.
Old Aug 22, 2006 | 07:34 PM
GodFather's Avatar
Made in Taiwan
Nice. Great job, and good pictures.
Old Aug 23, 2006 | 06:17 AM
DandyMax's Avatar
3.5 in the works
Originally Posted by IceY2K1
Looks great!
Which way is your JP13 now... 1-2 or OPEN?
Old Aug 23, 2006 | 07:26 PM
matty's Avatar
1-2 or OPEN with the 5th gen Coolant Log ?? Thats pretty much all I changed. Should be the same as the 4th gen part ??
-matt
Old Aug 24, 2006 | 01:09 PM
i30ds's Avatar
Armed and Dangerous
Nice work Matt.
Old Aug 26, 2006 | 08:41 PM
CaTalyst.X's Avatar
Awesome job i love it
Old Aug 27, 2006 | 04:18 AM
Alex_V
Originally Posted by matty
Ahhh holy crap a levatating blazer!!!
j/p, thats a nice engine! Boost the crap outta it, and for a nissan thats not even broken in!
~Alex
Old Aug 27, 2006 | 03:29 PM
vortechpower's Avatar
Looks nice! your going to want to get the charge pipe off of the coolant line! I dont think the emanage has anything to do with the fans. Do you think 555cc injectors is alittle much? With it being so hot out lately I havent felt the full power yet. I cant wait to see the dyno numbers...
Old Aug 27, 2006 | 03:30 PM
Looks nice! your going to want to get the charge pipe off of the coolant line! I dont think the emanage has anything to do with the fans. Do you think 555cc injectors is alittle much? With it being so hot out lately I havent felt the full power yet. I cant wait to see the dyno numbers... Maxima still for sale!!
Old Aug 27, 2006 | 03:50 PM
matty's Avatar
The charge pipe is about 2 inches from the top coolant line ?!?!? Once I reposition the charge pipe to my liking, it will end up a bit closer to it, like I had it before.
I got the 555's because I have emanage, and I was on the tail end of the 370's.
I dont know what the jumper setting should be on JP13 and JP14. Im going to change them back to OPEN on each and see if the fand click on. If not, Ill have to swap in the 4th gen coolant temp sensor and see if it fixes it.
What kinda metal mounting peice did you use to mount the IACV on the Plenum ??
-matt
Old Aug 27, 2006 | 06:41 PM
DandyMax's Avatar
3.5 in the works
Matty, there's no need to change JP14 if your air temp sensor is reading normally...
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
newtomaxima
Sep 25, 2015 05:16 AM
