Sponsored by:
Sponsored by: CARiD
3.5 swap complete, idles too high, can't use 1st gear
Old Sep 6, 2006 | 12:49 PM
Mad_A's Avatar
Ok, so my car was supposed to be all ready today, I get in and turn it on, and its idling slighlty under 2000rpm... I figure I'll give it some time, maybe the ecu is still figuring things out, but when I come to drive, I put it in first gear and when I come to release the clutch the car keeps on jumping, then slowing down, then jumping, then slowing down, chirping the tires with each jump, repeatedly... compeltely undrivable. I put it in second gear and it was fine, rpms still too high, had to drive with foot on teh brake pedal but the jumping was gone... so I took it back to the shop. I'm guessing they either need to adjust the throttle cable so its not idling too high.. and I'm worried the new clutch wasn't installed properly? Anyone have any ideas?
Old Sep 6, 2006 | 12:55 PM
tavarish's Avatar
fwd gone rwd cr00
let me guess....they mounted the throttle bracket on the firewall?
Old Sep 6, 2006 | 02:15 PM
Mad_A's Avatar
Yes, they did...
Old Sep 6, 2006 | 02:29 PM
Fre$h_TurK
wow...i love how tavarish knows everything :-D
Old Sep 6, 2006 | 02:42 PM
tavarish's Avatar
fwd gone rwd cr00
Originally Posted by Mad_A
Yes, they did...
mount it on the engine and all will be fine.
Old Sep 6, 2006 | 03:25 PM
Mad_A's Avatar
Ok, I called them up and they said all fixed, so I went to pick it up and they basically are no longer using the bracket. You can see below the bracket at the top of the picture was where the cable was coming through, now its just lying there, is that ok?
Old Sep 6, 2006 | 04:43 PM
Nismo3112's Avatar
Custom User Title
That was tht first mistake I made on mine. It has to be mounted on the engine...
Old Sep 6, 2006 | 04:48 PM
DandyMax's Avatar
3.5 in the works
It looks like it's just hanging loose there now and not fixed anywhere....
Old Sep 6, 2006 | 05:15 PM
tavarish's Avatar
fwd gone rwd cr00
it should look something like this: just make a bracket to hold the cable in place.
Old Sep 6, 2006 | 06:01 PM
vsamoylov
make a bracket and secure it to the engine. having it hang there is a no-no.
tavarish sweet intake set-up. but a battery tie-down on that battery though.
Old Sep 6, 2006 | 06:09 PM
Biggs_02's Avatar
seeing how everyone's engine swap is going well and seeing the pictures makes me sad and jealous. I have been working on my car since march now and took the motor in and out 3 times, on my second motor, and still no motor in the car. :-(
Old Sep 6, 2006 | 06:16 PM
vsamoylov
maybe you should make a thread then.
Old Sep 6, 2006 | 06:18 PM
Mad_A's Avatar
Yeah, I'm not happy with it just lying there, would you happen to have a closer pic of the bracket and where it is mounted?
Old Sep 6, 2006 | 06:23 PM
vsamoylov
just look at the picture that tavarish posted. he has the bracket bolted to the throttle body. and if that doesnt help it never hurts to be a little bit creative and come up with something yourself.
Old Sep 6, 2006 | 06:59 PM
Mad_A's Avatar
Allrighty, I'll see what we can come up with, its just that the regular mechanic is out, and the guy at the shop now only speaks spanish, I was hoping to show him a print out of the pic and use some sign language to get him to do the same lol.
I'll post a pic when I'm done.
Old Sep 6, 2006 | 07:10 PM
MaxBlack97's Avatar
Stickies holla at them
Old Sep 6, 2006 | 07:21 PM
tavarish's Avatar
fwd gone rwd cr00
yeah, i got the tie down here somewhere.
Intake's the stock hacked airbox with clean panel filter.
Old Sep 6, 2006 | 07:25 PM
AllBlackMax's Avatar
aka The Doom Ship
Wow, congrats on the swap. It's good to see other Max enthusiasts in my area. What shop are you working with?
Old Sep 6, 2006 | 07:29 PM
csb's Avatar
csb
Mad A, I have a suggestion. I used my stock 3.0 throttle/cruise bracket and used a tin snip to cut one corner of it off (it'll be obvious which corner if you hold it against the IM). The reason I cut it is because there was a clearance issue with regard to its mounting location on the 3.5 IM. There is a flat spot on the 3.5 IM very near to where the plenum begins (on the front side)...I believe there are two stamped circles roughly 1 inch apart in that very spot. I drilled a hole in the IM where the outermost circle is, threaded it and secured the 3.0 bracket with one of the OEM bracket bolts. Then, because there was no place to install the second bolt, I used JB Weld b/w the bracket edge and the IM as a precaution. Trust me...that sucka' will never move (unless I want it to) and the angle is perfect.
Old Sep 7, 2006 | 05:59 AM
Mad_A's Avatar
Gee, thanks for the insight and the suggestion
Not only have I read the stickies on this (wouldn't have gotten anywhere otherwise) but I printed out two copies, gave one to the mechanic, and went there every day for a month to go over what he did, and point out 'well, the printout says you should really do it like this. Look, if you switch out the connectors you can get that to fit. Look, it says you need to take this off to get the coils to fit. etc.'
Old Sep 7, 2006 | 06:05 AM
Mad_A's Avatar
csb, thanks for the suggestion. I'm probably going to wait till the mechanic who worked on it comes back from vacation, and have him mount the bracket on the engine/throttle body.. as well as check out some funky sounds I'm hearing, lol.
AllBlackMax, thanks bro, it took a month but it was definately worth it! I worked with a shop near 35 and Hebron.. pm me if you'd like more details. You might have read about me complaining about them somewhat (like sya, for mounting the bracket to the firewall, lol), but I should say that this was their first time doing something like this, and the managed to hook everything up, no codes or check engine light, asked them to hook up the egr (I used an '04 engine) etc. so in the end I'm happy, and I managed to learn quite a bit about engines during my daily visits to follow up on their work
Old Sep 8, 2006 | 07:52 PM
GoalieKeg's Avatar
Throttle bracket pics FTW!
Old Sep 10, 2006 | 05:40 PM
Mad_A's Avatar
Woot!
Very nice! Exactly what I was looking for.
Old Sep 25, 2006 | 09:38 AM
Mad_A's Avatar
Is it just my ignorance, or does it look like the IACV is completely missing, thus explaining my idle problems
schmellyfart
Sep 25, 2015 04:47 PM
maxima-junky
Aug 13, 2015 09:59 AM
Team STILLEN
Aug 10, 2015 04:29 PM
Blackwind
Aug 5, 2015 06:35 PM
