Sponsored by:
Sponsored by: CARiD
3.5 swap problems, hesitation + codes
Old Sep 18, 2006 | 10:44 AM
Mad_A's Avatar
So at first I had problems with the car jumping in first gear due to the throttle cable bracket being mounted on the firewall, this has since been fixed, it is now mounted on the engine.
The problem now occurs between 1500 - 2800rpm, the car will lose all power, just hesitate then get power back and jump forward.. a scan came up with codes for the IAC, MAF and MAP... any ideas?
Old Sep 18, 2006 | 05:04 PM
Mad_A's Avatar
No one has encoutered this before or has any ideas or suggestions?
Old Sep 18, 2006 | 05:47 PM
tavarish's Avatar
fwd gone rwd cr00
it's one of 2 things. Fuel pressure, or crank position sensor. Make sure it's clean, and free of any metal particles. Fuel pressure should be around 51-52psi all the time.
just read the post again. Change the MAF. Now.
Old Sep 18, 2006 | 06:35 PM
Mad_A's Avatar
I'll check on that tomorrow then. I thought it was the fuel pressure, but the mechanic seemed to disagree.. in using the 3.5 fuel rail and injectors, he didn't use an fpr, instead he hacked some piece from the 3.0 fuel rail and used that to convert the system to returnless.. so I've been sceptical of that part since the begining, lol.
Old Sep 18, 2006 | 07:59 PM
tavarish's Avatar
fwd gone rwd cr00
tell your mechanic to stop being lazy and use an fpr with a readout.
schmellyfart
Sep 25, 2015 04:47 PM
Slamrod
Sep 3, 2015 07:38 PM
homeyclaus
Sep 3, 2015 06:15 PM
dinososexy2.6
Aug 30, 2015 01:35 AM
Blackwind
Aug 5, 2015 06:35 PM
