Sponsored by:
Sponsored by: CARiD
It's time to play NAME THAT VQ35 sound!!!
Old Sep 28, 2006 | 04:18 PM
tavarish's Avatar
fwd gone rwd cr00
Ok, this is the car i've been working on, and it runs fine, starts up fine, and idles fine. But every 20 seconds or so the idle drops, and it makes this HORRIBLE clunking sound.
Here's some possible solutions:
I'm leaning towards this: LEAN CONDITION - the fuel isnt getting to the engine, as the psi is a bit low (but i could have a faulty fpr gauge)
Not enough tranny fluid - this was actualy a bit low, it could use 2 more quarts IMO.
Not enough oil - The dipstick reads "high" when car's warmed up, but maybe there still isnt enough oil.
Other than that, I dont know what it could be.
If it was valves, the car would have this sound constantly. The car revvs great, and above 1000 rpms the sound is gone. It's just when it drops, it starts clunking.
Here are the vids:
http://www.youtube.com/watch?v=pWnzeSby8gg
Inside the car:
http://www.youtube.com/watch?v=HR6R112gfrU
Any help would be appreciated.
Thanks,
-Freddy
Old Sep 28, 2006 | 05:18 PM
bigirish's Avatar
Dude, that noise sounds a hell of a lot like a rod knocking to me.
Old Sep 28, 2006 | 05:37 PM
speed racer's Avatar
Have you tried putting in a heavy oil? That sounds bad and can definetely be something broken or on the verge of breaking. I would suggest either taking it apart to look for damage or just look into a new engine. It just doesn't sound normal even if the fuel pressure was low.
Old Sep 28, 2006 | 05:42 PM
ThisMaxIsTight's Avatar
hmmm ... why does it sound normal when its reved up though??
Old Sep 28, 2006 | 05:46 PM
LA02MAX's Avatar
sounds more like a rattle...something caught in your IM? That's freaking scary sounding....
Old Sep 28, 2006 | 05:48 PM
.... .. no theres nothing caught in the IM ... ive listened to this car in person, up very close to the motor .... something is wrong ... God I hope its nothing serious ..... if someone can suggest the problem and Freddy and I can fix it properly, you will receive $100 in your paypal account, you will have to pm me
Old Sep 28, 2006 | 05:58 PM
tavarish's Avatar
fwd gone rwd cr00
i think it might be the auto flexplate/TC. I'll give you an update tomorrow.
nismology's Avatar
Either way the motor is going to have to be torn down at least partially to discover what's causing the noise so you might as well do it now.
Old Sep 28, 2006 | 06:00 PM
nismology's Avatar
I don't think the motor would run if that flexplate was that much out of alignment.
Old Sep 28, 2006 | 10:04 PM
tavarish's Avatar
fwd gone rwd cr00
I'll check the TC bolts tomorrow. I strongly doubt something is wrong with the engine itself. It revs fine, and exhibits no knocking at rpms higher than 1000. Even most times below 1000 it's fine. I know it knocks ALOT less when it's hot, leading me to believe it's a lubrication problem.
Old Sep 29, 2006 | 03:29 AM
nismology's Avatar
10frijoles
Old Sep 29, 2006 | 08:03 AM
tavarish's Avatar
fwd gone rwd cr00
10frijoles
i'll try to avoid that, but if it comes down to that, I can do it on the weekend.
Old Sep 29, 2006 | 09:00 AM
x X CLoud X x's Avatar
It can be several things 1 would be a spun bearing. You should stop the car immediately once you hear any knocking, otherwise you are eating the crankshaft journals beyond repair. You're also contaminating all the oil passages and crevices in the block. Not good. You might end up replacing everything from shortblock, crankshaft and even oil pump. If you hear this stop the engine immediately! Don't try to convince yourself its something easy to fix and not knocking....
If you change the filter & oil, take a pic at the metal shavings and post it. Different kind of metals are used in manufacturing so most probably we can tell whats affected. Its a long shot but it will give you an idea.
or as quoted from a friend himself
"My brother in law (who races pro comp eliminator NHRA) told me the easiest way to tell if it is a rod bearing is to put in some super thick oil, like deisel oil 15 W40.. if the knocking seems to go away or lessen its because the oil pressure builds up.. this could be why when you and I both rev the motor the knock goes away.. so if it goes away or lessens with the thick goo it is most likely a rod bearing.. I know this is a crude test, but I just did it and sure as F$%& it almost completely went away... lame"
or you can unplug each ignition coil one at a time until the knock disappears so you can narrow down the knock to a specific cylinder.
If you have such knocking at a cold engine it is most likely piston slap. When it´s going away after heating up the engine it´s because the pistons are expanding.
If the knocking appears when the engine is getting warm it´s because the oil is getting thinner when hot and can´t dampens/egalize the loose in the rod bearings anymore.
But for me it sounds (at least in the clip) also like a bad rod bearing. Discharge the oil of the oil filter in a white plastic plate or so and check in the sunlight. If metallic fragments are in there a bearing is gone.
or it can be a drive belt tensioner... check the flex plate as well
honestly there is no definite answer, but you have nothing to lose by checkn all of these
im no expert in maximas, but i do have a decent amount of knowledge in building Supras(mk4s)
good look and please tell us when you do find out, its hard to diagnose anything from online
ps- I would also try pulling the valve covers off and running the engine, it could probably be coming from one of the camshafts.. hardest part is, is that the problem can either lie in the shortblock or head but like i said, try everything
Old Sep 29, 2006 | 09:29 AM
tavarish's Avatar
fwd gone rwd cr00
is a failed rod bearing intermittent like that? It runs fine for awhile, i'm trying to rule out any engine internals, but im gonna change the oil, and see if that does anything, and i'll also check for metal shavings. If need be, i'll pull the timing covers and head.
and you cant run the engine with the valve covers off, the engine would stall.
Old Sep 29, 2006 | 09:38 AM
tavarish's Avatar
fwd gone rwd cr00
here's what rod knock sounds like:
http://www.youtube.com/watch?v=xNIbHUi7E7M
http://www.youtube.com/watch?v=niHvQ-P00gA
It's constant, not intermittent, and doesnt clunk like this one does.
Old Sep 29, 2006 | 09:56 AM
tavarish's Avatar
fwd gone rwd cr00
It could be timing chain tensioner.
Old Sep 29, 2006 | 04:31 PM
nismology's Avatar
That sounds nothing like rod knock.
See above. Rod knock is cyclic and occurs at regular intervals, not randomly like in the video.
Stock cast pistons do not expand that much. Forged aftermarket pistons with high silicone content do.
Old Sep 29, 2006 | 08:26 PM
505max94se's Avatar
That's defnitely NOT a rod knock...From watching the video, it almost sounds like intake backfire which I believe is sometimes caused by advancing the timing too much. Does it soundlike loud popping popcorn?? What is your base timing set at?? It's just a guess, so don't quote me on this...
Old Sep 29, 2006 | 09:43 PM
Jon94SE's Avatar
I can almost promise you it's your timing, My car was making the same sound due to too much timing advance, the only difference was mine would idle okay but it made the noise when I would punch it. I just backed off the timing off a bit and it was fine. Try that out and see what happens
Old Sep 29, 2006 | 10:04 PM
LA02MAX's Avatar
but doesn't base ignition timing stay just about the same <2300 rpms? Why would the sound completely go away at 1000 rpms, with the nearly the same throttle position?
Old Sep 29, 2006 | 11:14 PM
GodFather's Avatar
Made in Taiwan
Man, that doesn't sound good. I "may" know what it is though. I did have that kinda noise for a week after my last year's motor swap. Then I fixed it and it was done.
Here's what I got...
With engine at idle, it clutters like that. Then when I pressed down the clutch pedal, the noise goes away. So, I thought it was tranny related. I took down the tranny and also found my flywheel snapped in two pieces inside the clutch assembly, they are just dangling inside the clutch assembly when the clutch is gripped onto the flywheel. When the clutch is not gripping, the noise got away. I did drive a whole week with the snapped flywheel and I even redlined it many times. You should try to see if clutch pedal down does make a difference, if it does, you may have the same thing I had. Mine was a stillen flywheel at the time, and it literally snapped in 2 pieces. Afterwhich, I replaced it with a fidanza flywheel and never had a problem with it at all.
-Peter-
Old Sep 29, 2006 | 11:55 PM
tavarish's Avatar
fwd gone rwd cr00
-Peter-
it's automatic.
Old Sep 30, 2006 | 05:58 AM
GodFather's Avatar
Made in Taiwan
oh, sorry. then disregard my post.
Old Sep 30, 2006 | 07:43 AM
GoalieKeg's Avatar
Better give me credit freddy if it is...
Old Sep 30, 2006 | 11:28 AM
tavarish's Avatar
fwd gone rwd cr00
UPDATE: I got some stp oil treatment, some thick synthetic oil, and 3 quarts of tranny fluid, seafoamed the car, and the sound is 90% GONE. I also replaced the FPR (this one was bad, didnt keep pressure at all, gonna have to get a new one)
I also think the alternator's not charging the battery, but i think I might have the wires crossed, or a fuse blown. Other than that, this car runs absolutely perfect. I ran the codes, and it's just regular stuff that's not gonna hinder the performance of the car. EVAP and EGR stuff.
Old Sep 30, 2006 | 06:47 PM
bigirish's Avatar
That is good stuff. That noise was disturbing!
kjlouis
Nov 24, 2018 06:09 AM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
