Sponsored by:
Sponsored by: CARiD
Plug coolant line or T it?
Old Oct 6, 2006 | 08:56 AM
MDeezy's Avatar
Putting a few last touches on the swap before I turn the key.
There is a coolant line that normaly plugs into the 4th gen TB, there is also another Coolant line that connects to that side pipe (I'm working on pics). These are both coolant lines that have lost their function, should I connect these two lines and let coolant flow all around? or should I plug both lines?
Old Oct 6, 2006 | 11:48 AM
Tatanko's Avatar
Bacon Lover
Connecting them should be fine. People do this all the time with the 00VI swap, and it's precisely what I'll be doing.
Old Oct 6, 2006 | 11:49 AM
MDeezy's Avatar
I figured so, its coolant and flows all around. I'll put a connector between the lines and clamp them.
Old Oct 6, 2006 | 12:12 PM
tavarish's Avatar
fwd gone rwd cr00
yea, i connected them to each other.
Old Oct 6, 2006 | 03:02 PM
chillin014's Avatar
im so jealous
Old Oct 7, 2006 | 08:36 AM
gtr_rider's Avatar
192.168.1.1
If you can get a long enough hose to make the full path of both lines connected together that would be best. Reason being is because for some reason sooner or later the coolant will want to trickle out of the connector.
Old Oct 7, 2006 | 08:47 AM
MDeezy's Avatar
the connector i bought is a little small and I could use a larger one, but they are clamped pretty good.
I'll look at autozone for a long tube to replace it so that there isnt a place for a leak
Old Oct 8, 2006 | 09:19 AM
goldtooth's Avatar
I have installed the 00VI, and I have a question related to this topic. I am using the 4th gen TB, and I have kept the coolant lines attached. My friend and I discussed that it could be better if the TB was bypassed and just connecting the coolant lines to each other and skipping the TB because the coolant "heats" up the TB. So if the TB would be bypassed and not have coolant lines attached to it, the air flowing through it would not heat up. What do you say?
Old Oct 8, 2006 | 11:18 AM
RA030726's Avatar
I'm nutty for Nissans
Plugging it is fine too, if you have the caps, but most just have a peice of hose left over so connecting them together is just as simple. My IM/TB stays dang cool with no coolant running through it. I like having a cooler IM, but it really doesnt make a performance difference.
Old Oct 8, 2006 | 11:37 AM
GodFather's Avatar
Made in Taiwan
connect them with a long hose like GTR said, it's better in the long run.
Old Oct 8, 2006 | 01:26 PM
MDeezy's Avatar
I already saw a few drops leaking from the connection. I'm going to get a long hose and connect them but I tightened the clamps for now, till I work out a few other issues.
Old Oct 8, 2006 | 01:46 PM
Tatanko's Avatar
Bacon Lover
You haven't noticed any of the "sticky throttle" issues, have you?
Old Oct 8, 2006 | 07:48 PM
gtr_rider's Avatar
192.168.1.1
in colder climates you may notice it, but in the south.. pssh
Old Oct 8, 2006 | 08:19 PM
Tatanko's Avatar
Bacon Lover
Well I'm waiting for his reply, first, mr. jackass Thanks for all the help I've been bugging you for on AIM, btw.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
magiconthetire
Oct 26, 2015 09:03 PM
