Sponsored by:
Sponsored by: CARiD
Lapping valves and clearances
Old Oct 12, 2006 | 04:35 PM
nismology's Avatar
I was talking to a mechanic about it and he said that i might have to adjust the valve clearance after lapping since the valves will be sitting ever-so-slightly closer to the lifter. Has anyone here lapped their valves and measured the clearance afterward? Thanks in advance.
In a VQ BTW...
Old Oct 12, 2006 | 06:03 PM
eng92's Avatar
I measured the clearance on all my valves (VQ35) after lapping and they were all well within factory spec with the original lifters.
Valve lapping compound is pretty fine grit and you are only using light hand pressure unless your valve faces/seats are severely pitted. IMO the material generally removed is of the magnitude 0.0001".
The clearance spec allows a .003"/.004" tolerance so unless you were at the extreme end to begin with, there should not be a problem.
If you are going through all the trouble of rebuilding your heads, you should be checking your valve clearance anyways. Who is to say it was within spec when it left the factory?
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Gingerheadman
Oct 1, 2015 05:11 PM
tardrex
Sep 11, 2015 07:35 PM
