Cleaning Up Fuel
Cleaning Up Fuel
A byproduct of my 00VI install was replacing some of the fuel lines, since I eliminated the vacuum gallery. All WAS well until tonight when I went to drive the car and noticed a fuel smell and the car ran like crap. This was maybe 10 seconds into driving, so I immedeatly pulled back into the driveway, shut the car off, and popped the hood.
Turns out the fuel return line had popped off the fuel rail. Not all the way off, but enough to spray fuel all over the place. Had it been a tiny, miniscule amount, I would have cleaned it up with a rag and called it a lesson learned. But, it was no small amount. It coated most everything on the driver's side of the engine bay, and left shallow puddles in some places right near where the line came off. I tried to soak some up, and immedeatly disconnected the battery as well.
So how do I clean this up safely? It would be great if I could drive the car tommorrow, as I have remedied the problem that caused the hose to pop off (loose connection + something else near it helping to pull it off from tension). My first thought was to cover the filter and some electrical stuff and spray it down with my pressure washer, but it's fuel and I wasn't sure how well that would work.
Help me out guys, I'm a little worried
You can use shop towels to wipe up any excess fuel. Most likely as soon as the liquid is wipped up the risiduals should vaporize. You might want to let it dry up for a little while. Maybe run the car at idle for 15min to allow the heat to evaporate any left over fuel.
Unless you think your method would be better
I wouldn't know. I'd LIKE to be able to drive my car to work tommorrow, though.
I really wouldnt worry about it, as long as the pools of fuel are gone the rest will evaporate very quickly. You'll probably have the smell for a day or so. My 3rd gen leaked at an injector o ring before I got a chance to change it and it always had a small pool when I stopped driving.
~Alex
~Alex
Yeesh. Well I think I'm still going to follow some others' advice and spray the engine bay down as well. That way I won't have to deal with the smell as much, either.
Originally Posted by nismology
Gasoline is petroleum-based (DUH) so water won't do all that much other than spread it around. Use a good engine degreaser on it.
when my fuel line popped off, i soaked up the physical puddles that where in the engine bay, and the rest just evaporated in a few minutes
funny u mention this, my fuel line popped off when i was driving, after i had the 00Vi done already for like a few weeks, I was running on a popped(half-assed on the fuel rail though) fuel line for like 3 blocks before i pulled over.... it was NOT a pretty sight.....
Gotta be careful dealing with Fuel lines, man you could have burend up the car while driving it with the reutrn line sraying around the hot engine.
Gotta be careful dealing with Fuel lines, man you could have burnt up the car while driving it with the reutrn line sraying around the hot engine.
jmlee44
Oct 2, 2022 02:13 PM
fx4five
Oct 1, 2015 04:58 AM
