Sponsored by:
Sponsored by: CARiD
Re: Throttle Body For 3.5 Swap
Old Oct 16, 2006 | 01:30 PM
laflyer23's Avatar
I was wondering if you can ONLY 01-02 Pathfinder throttle body?? Or can other throttle bodys be used??? Like lets say an 03 altima 3.5 throttle body??
Old Oct 16, 2006 | 01:55 PM
AnDyMaN's Avatar
i believe the 03 altima 3.5 is also drive by wire. i believe jclaw had issues with the 3.5 drive by wire when he used the altima engine. If my knowledge doesn't fail me, the 01-02 pathfinder is the only 3.5 engine that isn't drive by wire so it'll work perfectly with the engine swap. dont quote me on that tho.
Old Oct 16, 2006 | 02:04 PM
laflyer23's Avatar
I wont quote ya but that'll convince me enough not to buy that one. Thanks for the help. So i'd rather just stick to the stickie and get an 01-02 throttle body.
Old Oct 16, 2006 | 02:12 PM
Nismo3112's Avatar
Custom User Title
I think it's only the 01 Pathfinder TB..
Old Oct 16, 2006 | 02:26 PM
laflyer23's Avatar
Thats interesting. I'm just kinda confused b/cuz in the sticky it says 01-02 so not sure exactly which year. I'll keep looking and get opinions, if all else fails i'll just go with 01.
Old Oct 16, 2006 | 02:58 PM
Jime's Avatar
Pretty easy to convert the stock 3.5 TB to cable thats what I am using. Only problem is getting the cruise to work.
Old Oct 16, 2006 | 03:15 PM
Nismo3112's Avatar
Custom User Title
Jime whats your idle at?
Old Oct 16, 2006 | 03:29 PM
Jime's Avatar
I keep it around 1500 at the track but 800-1000 on the street. I use the EU and change timing to adjust it rather than do it manually.
Old Oct 16, 2006 | 03:36 PM
Nismo3112's Avatar
Custom User Title
I drove with it at 1500 for a while but then shaved some off the plastic stopper to bring it down to 1000 ish.
Old Oct 16, 2006 | 03:42 PM
Jime's Avatar
I can adjust mine manually with the screw down to where it stalls.
Old Oct 16, 2006 | 04:21 PM
nismology's Avatar
I can confirm that both an 01 and 02 TB will work. The PF didn't go drive-by-wire until 03.
*Confirmed using the Nissan FAST program
Old Oct 16, 2006 | 05:46 PM
krismax's Avatar
Father of the 00 VI
i have a 3.5 TB $95 shipped
Old Oct 16, 2006 | 08:39 PM
laflyer23's Avatar
If this is a 01-02 pathfinder 3.5 TB, then i'll take it off your hands on friday!!!!
Old Oct 17, 2006 | 02:05 PM
laflyer23's Avatar
I've been calling places to get a tb and they've been asking me what production date the car was made. So i'm wondering if just as long as it's 01 or 02 it's good. And the production date doesnt matter to me??
Old Oct 17, 2006 | 02:09 PM
krismax's Avatar
Father of the 00 VI
its so simple i say this over and over tell them " i need a TB that came off a 3.5 pathfinder and has cables not electric" if it fits that then thats it
Old Oct 17, 2006 | 07:34 PM
MDeezy's Avatar
07/00 or 08/00 production dates work fine.
is it that there isnt enough space to put the plate for cruise control when converting the drive by wire? From images I've seen, looks like there isnt enough space to fit it on.
Old Oct 17, 2006 | 07:43 PM
Biggs_02's Avatar
what do you mean?? if you use the pathfinder tb you should be able to fit the cruise control on there with no problem only problem is when you do the conversion from the drive by wire tb to a drive by cable...i dont' think it's possible to use the cruise.
Old Oct 17, 2006 | 07:46 PM
MDeezy's Avatar
I was refering to if you retro the drive by wire, not sure if there is enouh space to fit the cruise control.
the Pathy TB is already set, just bolt up with an adapter plate and you're done.
Old Oct 17, 2006 | 08:00 PM
Biggs_02's Avatar
no when i did mine there was no room to put the other braket in. i don't think anyone has done it yet. i don't think it's even possible
Old Oct 18, 2006 | 09:06 AM
laflyer23's Avatar
I dont really care about not running cruise control. But just a quick question does my air conditioning still work with the swap??
Old Oct 18, 2006 | 11:37 AM
scrhale's Avatar
Why wouldn't it?
Old Oct 18, 2006 | 12:46 PM
krismax's Avatar
Father of the 00 VI
my cruise worked fine with my 00 vi and pathy TB
Old Oct 18, 2006 | 03:31 PM
Weimar Ben's Avatar
Helicopters! Money!!!
if you use the PF TB, you must make an adapter plate to fit it to the 3.5 FWD intake manifold. The mounting holes are different.
Old Oct 18, 2006 | 07:07 PM
Biggs_02's Avatar
or just buy one from stephen max. and yeah why wouldn't your ac work....
Old Oct 19, 2006 | 08:09 AM
laflyer23's Avatar
Just want to make sure that it can be hooked up and works fine b/cuz i live in Cali and i hate the heat. Anyway thanks for the info guys.
Old Oct 19, 2006 | 12:27 PM
GoalieKeg's Avatar
Pathfinder Throttle Body
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
MaxRPM6
Sep 11, 2015 06:56 PM
Maxboy23
Sep 4, 2015 06:04 PM
