Sponsored by:
Sponsored by: CARiD
Engine Controls
Old Oct 24, 2006 | 03:42 PM
Hoooper
Exclamation Engine Controls
ok, i have a pretty pressing and serious problem. did a 6spd swap and car will not start. it will crank fine, but will only spark once. when the engine is initially turned over, it will spark once then will no longer spark.
Parts used:
6spd tranny
6spd ECU
6spd wiring harness
shifter, clutch and all that
Problems checked and are ok:
ground above CPS
immobilizer unit
Neutral safety switch and clutch safety switch
Old Oct 24, 2006 | 06:20 PM
Hoooper
someone please help, sort of serious problem. any input is welcome
Old Oct 24, 2006 | 06:53 PM
NmexMAX's Avatar
dot dot dot ...
Just curious, has your car been sitting for ~ 5 months with the same problem re: the swap...?
Old Oct 24, 2006 | 06:58 PM
Hoooper
uhhh......yeah pretty much. well not sitting it was still being messed with but yeah. any ideas?
Old Oct 24, 2006 | 07:02 PM
NmexMAX's Avatar
dot dot dot ...
And you've checked everything thoroughly that was suggested in your 2 other threads?
Old Oct 24, 2006 | 07:06 PM
Hoooper
as far as ive been told. mathell at "the shop" is working on the car and says hes checked everything thoroughly. everything meaning wiring destinations. if anyone could even come up with why it might do that, regardless of whether i say its been checked or not, it would be great.
Old Oct 25, 2006 | 11:47 AM
Hoooper
nobody knows anything?
Old Oct 25, 2006 | 11:56 AM
GodFather's Avatar
Made in Taiwan
You didn't mention the flywheel, make sure your ring gear is on there correctly. You can't get it wrong because of the bolt patter, but since you didn't mention, I'd have to bring it up. Ring gear's used to calculate rpms and timing stuff.
-Peter-
Old Oct 25, 2006 | 04:21 PM
Hoooper
i guess ill have to ask him to check the wiring again. well see. this needs to get resolved soon and im getting REALLY anxious
Old Oct 26, 2006 | 05:24 AM
HowlerMonkey's Avatar
dude...............you have an immobilizer problem.
Your new ECU requires a proceedure to "relearn" the ecu to the car.
Check your codes and you should find one that references what I am talking about.
Old Oct 26, 2006 | 05:47 AM
NmexMAX's Avatar
dot dot dot ...
that's what my money is on.
Even if your shop has done many reputable jobs (though you haven't said this, 99% of people will say my shop has done this that or the other) doesn't necessarily qualify them to know everything, such as an immobilizer problem.
Explain further please.
Old Oct 26, 2006 | 01:26 PM
Hoooper
yeah i know, but i checked the security light and its not on, plus we had the dealer reprogram the immo twice. its mathel from "the shop" aka turbo95max, knows a lot of max's but ill admit not as much about 5.5's as 4th gens
the key is turned over so that the engine cranks. on the first revolution a coil will spark once, then nothing after that even as the engine continues to crank
Old Oct 26, 2006 | 01:27 PM
Hoooper
would there be an immo code even if it passes the security light check?
Old Oct 27, 2006 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
aka turbo95max
Well you should've said that from the start...
best thing to do is check and eliminate the variable.
Old Oct 27, 2006 | 08:14 AM
GodFather's Avatar
Made in Taiwan
Pm travis, TurboS13Hatch on the org. He's done a couple sentra's swapping in the full vq35de with 6-speed trannies. I did hear him mentioning some technical stuff about those swaps. Maybe he can help.
-Peter-
Old Oct 27, 2006 | 07:09 PM
Hoooper
anybody have an idea of what sensor could cause this?
Old Oct 27, 2006 | 07:21 PM
NmexMAX's Avatar
dot dot dot ...
Why dont you take GodFather's advice?
Old Oct 27, 2006 | 07:23 PM
Hoooper
i am, have pmed turbos13 and im looking for someone with a datalogger, just hoping someone has a possible answer to check first.
derekinthez
Nov 13, 2022 04:00 PM
Starrider
Dec 18, 2015 04:43 AM
fastcarny
Oct 6, 2015 10:42 AM
carid
Sep 9, 2015 05:06 AM
