Sponsored by:
Sponsored by: CARiD
Did the Z IM make power over the stocker?
Old Nov 3, 2006 | 07:44 AM
Fred Allen Burge's Avatar
Hello,
Seems like I've seen a dyno for this but can't find it now. Did the Z intake manifold make any power over the stock FWD 3.5L intake manifold or has nobody tested it yet?
Thanks,
Fred
Old Nov 3, 2006 | 08:37 AM
scrhale's Avatar
I am pretty sure it lost power due to the lack of exhaust VTCs
Old Nov 3, 2006 | 08:45 AM
Puppetmaster's Avatar
Here it is:
http://forums.maxima.org/showthread.php?t=475915
Originally Posted by meximax
Highlights:
-FWD IM makes 25 ft/lb of torque more than Z33 (no spacer) @ 3500 rpm
-FWD IM makes 17 ft/lb of torque more than Z33 (no spacer) @ 4300 rpm
-FWD IM makes 20 hp more than Z33 (no spacer) @ 6900 rpm
-Z33 makes ~18 hp more during the VI change point @ 5800 rpm
Old Nov 3, 2006 | 08:57 AM
Thanks, and OUCH!
Fred
Old Nov 3, 2006 | 08:58 AM
eng92's Avatar
To date, people have only used Z33 IMs from 287 hp motors which do not have exhaust VTCs.
Maybe you mean intake VTCs. AFAIK only Vasily and myself have 3.5 swaps with Z33 IMs and functioning intake VTCs.
I am not aware of any A33B owners that have installed Z33 IMs.
Old Nov 3, 2006 | 09:01 AM
How much have you two dyno'd at or have you yet?
Thanks,
Fred
Old Nov 3, 2006 | 09:11 AM
eng92's Avatar
Thanks,
Fred
Vasily has dynoed. It was nothing spectacular but he was lacking headers and any sort of tuning at the time.
I am doing a lot of flow testing and material removal inside my Z33 IM right now. I am hoping to be finished before the snow flies so I can dyno it.
I only plan to dyno once so I want to have everything optimal before I go. It may have to wait until the spring.
Old Nov 3, 2006 | 09:30 AM
I see, are you using an aftermarket spacer as well? The seem to be the hot ticket for the Z guys.
Fred
Old Nov 3, 2006 | 09:44 AM
Yeah he put down around 225 whp 240 tq with stock headers. Had quite a bit of potential there.
http://forums.maxima.org/showthread.php?t=466571
Old Nov 3, 2006 | 09:53 AM
eng92's Avatar
Fred
I have not yet. The IM just clears my hood now when closed. I would have to drop the engine about 1/4" if I go with the spacer.
I am concentrating on equalizing the pressure drops between cylinders for a given flow. They are horribly out of whack in stock form (close to 50% variation) I have dropped it considerably without messing with the runner lengths too much. If I cannot get it to where I am satisfied, then I will get a spacer.
Old Nov 3, 2006 | 12:58 PM
vq354thgen
225 whp and 240 tq is nothing spectacular for a bone stock maxima? i can only imagine what happens when headers and tuning come into play.
Old Nov 3, 2006 | 01:00 PM
NmexMAX's Avatar
dot dot dot ...
Are you asking or telling?
Old Nov 3, 2006 | 01:01 PM
vq354thgen
hmm lets just say both.
Old Nov 3, 2006 | 01:10 PM
NmexMAX's Avatar
dot dot dot ...
Where's your dyno?
Old Nov 3, 2006 | 01:51 PM
steven88's Avatar
Need A Light?
it's not bone stock...it had intake/Z33IM/catback
stock 2k2 6spds put down 205whp....he made 225whp....so those 3 mods gave him 20whp....throw in some cattman headers and a test pipe...with air fuel tuning...he'll be in the 250whp range...
Old Nov 6, 2006 | 10:08 AM
MaxBlack97's Avatar
test pipe hasnt proven of any gains
Old Nov 6, 2006 | 10:40 AM
NmexMAX's Avatar
dot dot dot ...
He may have meant it in the context of it being a prime placement for a wbo2.
Old Nov 6, 2006 | 04:48 PM
Nismo3112's Avatar
Custom User Title
I didn't dyno or have VTC's but I am comparing my car before/after the Z33 IM.
Stock 2k2 IM vs. Z33 IM, I seemed to average better quarter mile times on the Z33 with worse conditions. But then again the "after" setup had HS headers instead of stock headers and a y-pipe as well. I also beat my previous trap by 2 mph, and ran 2 tenths faster with a 1 tenth slower 60ft.
Old Nov 6, 2006 | 05:18 PM
NmexMAX's Avatar
dot dot dot ...
Too many variables to be anywhere near conclusive.
Old Nov 6, 2006 | 05:48 PM
Jime's Avatar
My best 1/4 times have come from the stock 2k2 IM, I have a higher trap with the modified IM ie 111 vs 108 but my best et is from the stock IM. The totally modified 350Z IM ie spacer etc etc was in the middle, waste of money unless you are running cam timing and then I am not sure of the results.
lowpost99
Oct 26, 2025 06:53 PM
220k+ A32
Sep 11, 2015 02:18 AM
AT978
Sep 6, 2015 10:31 PM
trungg86
Sep 4, 2015 04:58 AM
