Sponsored by:
Sponsored by: CARiD
cam adapters problems
Old Nov 5, 2006 | 01:35 PM
Biggs_02's Avatar
So my car just stopped working, as in the front 3 banks stopped firing...well burning gas. There is spark and everything. So i opened up the timing case and i found that my cam adapter broke. The cam adapter on the intake cam broke. The screw used for the adapter broke not the actually spacer. I'll post up some pictures soon. I'm going to contact stephen max to figure out how this could have happened.
Old Nov 5, 2006 | 01:41 PM
SDot82's Avatar
It happened to me to (not with stephen max's adaptors).
Old Nov 5, 2006 | 01:42 PM
Biggs_02's Avatar
what did you end up doing to fix the problem? i mean if there are problems with these adapters...people should know and something differently should be done to them to ensure that something like this does not happen again. my car has been down for weeks due to this problem
Old Nov 5, 2006 | 01:47 PM
Nismo3112's Avatar
Custom User Title
I still say drilling the cam is the best way to go.. Better to have stress on the cam than a dowel pin.
Old Nov 5, 2006 | 02:06 PM
Biggs_02's Avatar
well i'm screwed....finally took out the adapter and took a look and it looks like the dolley just broke out of the hole that it was screwed into. winter's here and i don't have a car this is great.
Old Nov 5, 2006 | 02:19 PM
MDeezy's Avatar
If you can find the screw and put it back in, get it welded in and it shouldnt pop out.
Old Nov 5, 2006 | 02:23 PM
Biggs_02's Avatar
this thing got wedged out of the hole that it was screwed into...pictures are below...sorry about my dirty finger nails :-X
Old Nov 5, 2006 | 02:24 PM
Biggs_02's Avatar
i could get it welded on but the thing is that this shouldn't have happened in the first place...
Old Nov 5, 2006 | 02:26 PM
MDeezy's Avatar
how does the adapter look in the rear banks?
Old Nov 5, 2006 | 02:36 PM
Biggs_02's Avatar
i have not have a chance to take them out and check yet...but i think they're fine. just hat this one came loose. and fudge up everthing. My cam gear is slightly damaged also.
Old Nov 5, 2006 | 02:41 PM
MDeezy's Avatar
going to get a new spacer and maybe a new gear put in and get back on the road?
any damage to the timing chain?
Old Nov 5, 2006 | 02:44 PM
Biggs_02's Avatar
no damage to the timing chain...dude i already got my cam drilled once. and now i got spacers and spacers are screwed....i'm not about to pay for new spacers that was suppose to be working.
Old Nov 5, 2006 | 02:45 PM
Nismo3112's Avatar
Custom User Title
Do this....
Get new dowel pins... and remove the pins from the adapters and use the adapters as a spacer.
Old Nov 5, 2006 | 02:47 PM
Biggs_02's Avatar
cams not drilled :-X
Old Nov 5, 2006 | 03:25 PM
speed racer's Avatar
So, drilled cams would be better at far as not breaking? Does anyone drill the cams?
Old Nov 5, 2006 | 03:28 PM
THT's Avatar
THT
Throbbing member
Tilleys99 does.
Old Nov 5, 2006 | 04:21 PM
csb's Avatar
csb
My '97 (w/ 3.5 swap) is in "the shop" right now b/c the front-bank secondary tensioner failed (don't know why). Anyway, they have the OUTER timing cover off right now. I purchased, and am using, StephenMax's cam adaptors. Should I have to shop perform any preventative measure(s) b4 reassembling everything? After paying this shop a significant amount of money, I'd like to ensure that nothing else happens. Glad I stumbled upon this thread...
Old Nov 5, 2006 | 04:23 PM
nismology's Avatar
Sorry to hear man. When i first looked at the spacers the screw looked kind of flimsy and i wondered if it would hold up to the forces it would be subected to.
It would be best if they were welded in, but the adapters are aluminum and it would be pretty hard to do.
Old Nov 5, 2006 | 04:25 PM
csb's Avatar
csb
Nismology, please read the post above yours. I wouldn't mind finding a machine shop to create some made of steel or ??? What do you think? Not trying to hijack the post, BTW.
Old Nov 5, 2006 | 04:33 PM
nismology's Avatar
The stress of turning the cam is always on the dowel pin. It's just better if the dowel pin is the OEM pin rather than a screw.
I say keeping the VTC and not having to modify anything is the best way to go.
Old Nov 5, 2006 | 04:41 PM
essential1's Avatar
My axles cry for mercy...
I dont mean to go off topic in this thread, but you really need to check your PMs Biggs...
Old Nov 5, 2006 | 04:54 PM
csb's Avatar
csb
Who do you mean by "you" and "your"?
Old Nov 5, 2006 | 05:09 PM
essential1's Avatar
Originally Posted by csb
Who do you mean my "you" and "your"?
Sorry about that. it's fixed.
Old Nov 5, 2006 | 06:11 PM
Nismo3112's Avatar
Custom User Title
The idea of the adapters would work good.. as long as it doesn't come apart like Bigg's adapter did. A one piece adapter would work best. And no using screws.
Old Nov 5, 2006 | 06:19 PM
csb's Avatar
csb
So...maybe I should find a local machine shop that is willing/able to machine one-piece adaptors out of (aluminum?/steel?)...just to be safe?
Old Nov 5, 2006 | 06:27 PM
eng92's Avatar
Did you torque the cam sprocket bolts to spec?
The torque is transmitted from the sprocket to the cam in two ways.
1) friction between the three faces sprocket/spacer/cam from the clamping force created by the bolt preload
2)Shearing force across the dowel pin(s) (set screws in this case)
Failure mode was low stress, high cycle fatigue as evidenced by the very small area of ductile tearing left on the bolt fracture face. The fatigue crack would have initiated at the root of one of the threads.
It is hard to tell looking at the pictures whether the relatively "soft" aluminum started to deform at the surface prior to crack initiation or not. If that is the case, then the loading on the setscrew would have changed from almost pure shear to a combination of shear and bending which would have expedited the fatigue process.
To make a long story short:
1) Threaded fasteners should never be loaded in this manner if at all possible
2) The spacers should have been made from steel and dowel pins used. Obviously a more expensive assembly, but considering the consequences, I would say it is cost effective.
Old Nov 5, 2006 | 07:04 PM
well like you said given the circumstances these cam spacers are vital to the 3.5 swaps. So, the best design to prevent failure would be a material that can handle more stress.
Old Nov 5, 2006 | 08:16 PM
Biggs_02's Avatar
every thing was tighen to spec. It looks as though the screw just bent and then came loose. you can see that the other screw, which is still in tack on the adapter, has no damage at all and are holding up just fine. maybe there was a defect in the one i got? or maybe because this screw was long and therefore could not hold up like the shorter one.
Old Nov 5, 2006 | 08:28 PM
GoalieKeg's Avatar
Biggs, how long have you been running the 3.5 swap with the spacers? How many miles?
Old Nov 5, 2006 | 08:31 PM
Biggs_02's Avatar
i only had it for 600 miles. I went to pickup a camera from a local maxima guy and the car failed one me 45 mins away from my house. Had to get the car towed home.
Old Nov 5, 2006 | 08:34 PM
GoalieKeg's Avatar
That is really really odd man. I've been running the 3.5 swap for over 4k miles with stephen max's spacers. Haven't had any problems.
It looks like there was some play between the cam and the sprocket with all those scrape marks on there. Are you sure you torqued those bolts down well enough?
Old Nov 5, 2006 | 08:39 PM
Biggs_02's Avatar
i torque them down well enough...like i said...maybe it's just this one adapter that is defective. look at the other side and it looks fine. and the motor only spins one way...why is there damage to the screw on the other side...
Old Nov 5, 2006 | 08:45 PM
Biggs_02's Avatar
the picture of the screw of what seems to be left of the thread at the point of breakage is not acutally what it seems to be. It's actually the thread being pushed inwards and then protruding up making it seems as though that's where it broke. I could not find the other "half" of the screw...it was there...
Old Nov 5, 2006 | 09:41 PM
eng92's Avatar
The light grey part of the setscrew fracture surface is the fatigue portion. You can even see the clamshell shaped markings originating back to the initiating point (at about the 5'oclock position the way you are holding it).
The stretched out part is just the final ductile failure zone where the cross sectional area was no longer sufficient to support the applied load.
All the markings on the one side of the spacer are from the broken setscrew being dragged around as the sprocket continued to turn with a stationary cam for a few revolutions as the engine stalled.
Of course there were no markings on the other side of the spacer as the setscrew was still intact. Therefore there was no relative motion,
Old Nov 5, 2006 | 10:00 PM
eng92's Avatar
I am assuming that the people with drilled cams and regular aluminum spacers are using proper dowel pins. They will be fine as long as the sprockets are torqued on properly. There are no threads to serve as initiation sites for fatigue cracks.
For those that have cam adapters of the same type as used in this thread, it is a different story. Don't think that because you have 10K or 20K on your adapters that you are homefree. Fatigue crack initiation can take millions of cycles to occur and they can grow very slowly in a low stress field.
Old Nov 5, 2006 | 10:07 PM
Biggs_02's Avatar
so what does this mean for everyone with this spacers? i mean everything was tight down to spec i mean how can we go about making sure that this will not happen to anyone else? make the adapter a "one piece" thing and not like the way it's now?
Old Nov 5, 2006 | 10:25 PM
jcy98maxse's Avatar
Turbo is too much fun!
have you spoke with stephenmax yet? Lets wait for his responds first and see what he says. If this becomes a more frequent problem rather than just a freak thing then something should definitely be changed.
Old Nov 5, 2006 | 10:30 PM
Biggs_02's Avatar
i send him a pm already...i hope this is just a fluke....all my other ones are doing fine...except for this one...
Old Nov 6, 2006 | 04:39 AM
GoalieKeg's Avatar
Eng92 is pretty much saying that everyone is screwed at this point.
Old Nov 6, 2006 | 05:05 AM
MDeezy's Avatar
A one piece would be idea, or use a equal length solid piece of solid tube, and get it welded in place. diymaximakid gets his adapeter pieces welded in for extra strength.
