Sponsored by:
Sponsored by: CARiD
pathfinder intake manifold...will it fit?
Old Nov 30, 2006 | 10:34 PM
jvelos3's Avatar
i just saw some pics of a pathfinder intake manifold 01-04 and i know they have a vq35de but it looks as if the upper IM actually will bolt up to a vq30de. The holes are oval like the 3.0
so im wondering...has anyone tried this out before?
i thought i read a thread on this before also...tried searching for it and couldnt find it.
so will it bolt up?
Old Dec 1, 2006 | 12:36 AM
Tyrexx's Avatar
I highly doubt it would bolt up and I highly doubt you would like the performance change it makes.
Old Dec 1, 2006 | 02:00 AM
Hoooper
ive heard that if you get the upper and lower it will bolt to your 3.0, someone said they were trying it...
Old Dec 1, 2006 | 04:57 AM
RA030726's Avatar
I'm nutty for Nissans
zack342 blolted it up to a vq30de LIM and it fits. He sold it to larrio.
Old Dec 1, 2006 | 05:07 AM
MaximaSE96's Avatar
Maxima Owner
yes we awaiting for Larrio to get it on and everything working and Dyno results
Old Dec 1, 2006 | 06:08 AM
jvelos3's Avatar
did either of them drive the max with it on? any comments from either of them?
Old Dec 1, 2006 | 07:44 AM
Larrio Motors's Avatar
Boss Chen Industries
By my measurements everything does fit under the hood. Just need some time to test fit on a spare VQ30de I have around and figure out how to work around the DE-K stuff inside my car.
I'll try to get some teaser shots near x-mas
Old Dec 1, 2006 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
You will have TONS and TONS of low end power. Your midrange will be okay at best. Top end will also be amazing. That is what I see from lookin at the runner lengths.
Old Dec 1, 2006 | 08:15 AM
jvelos3's Avatar
sounds like it would be a dream to drive!!
im actually thinking of making this my winter project...
Old Dec 1, 2006 | 08:16 AM
goldtooth's Avatar
subscribed......
Old Dec 1, 2006 | 08:42 AM
Tyrexx's Avatar
How? is it a VI?
Old Dec 1, 2006 | 08:44 AM
jvelos3's Avatar
Originally Posted by Tyrexx
How? is it a VI?
yes it is...
long runner is like 1.5x longer than stock 4th gen and short is like .5 of the stock!
Old Dec 1, 2006 | 09:00 AM
Kevlo911's Avatar
Kevlo for President
Ya it is a TRUE vi as well. Not like MEVI or 00vi(upsidedown mevi)
Old Dec 1, 2006 | 09:19 AM
Imagine a 4th gen USIM with an extra half of the manifold length added on for the long runner and a switch off into runners so short that it practically goes from the TB to cylinder in about 6-8 inches
Old Dec 1, 2006 | 09:28 AM
Kevlo911's Avatar
Kevlo for President
Exactly
How heavy are the manifolds and is there an EGR hole?
Old Dec 1, 2006 | 11:44 AM
Ceasars Chariot's Avatar
Old Maxima Legend
any photos ?
Old Dec 1, 2006 | 12:04 PM
jvelos3's Avatar
Originally Posted by Ceasars Chariot
any photos ?
heres some...
in engine bay
as you can see from the pics...the long runner comes from the throttle body - forward - then winds back under and down into the lower IM.
the short runner comes from the throttle...into the large compartment seen in the 4th pic then straight into the lower intake manifold of the 3rd pic.
Old Dec 1, 2006 | 12:36 PM
No EGR hole from what i've seen on mine.
The manifold is fairly heavy in comparison to the stock DE-K composite one. I'll weigh it later on tonight
Old Dec 1, 2006 | 02:02 PM
d00df00d's Avatar
Old enuf to pick his own gears
How? If you have poor midrange, you have to choose between pounding the crap out of your internals with all that low-end torque and screaming around above 5k RPM all day.
Unless you're running at the track... in which case you'll have no traction off the line, and your times will be crap because your redline isn't high enough for the top end to make up for the lack of midrange.
goldtooth's Avatar
so wait, has anyone done this swap before? how much would the cost be compared to a 00VI? ohhhhh, im soo excited if this works.....
Old Dec 1, 2006 | 02:31 PM
JClaw's Avatar
I would use this knowledge to run a a full pathy VQ35 with a 00 VI. Stephen Max found out a while back that it uses the same sensors/timing chain setup as a VQ30, but with early VTC's. The point would be to run the pathy VQ35 w/ 00 VI on a regular VQ30 ECU and wiring harness, and add on stuff (RPM switch?) to control the VTC's.
So VTC's without the wiring of a 02+ ECU, you get to keep simple cable throttle (no e-gas and electronic pedal), but you do get VTCs. Although they vary less than 350z/maxima VTCs.
Old Dec 1, 2006 | 02:53 PM
grey99max's Avatar
LandShark has Cosworth
If Nissan just made a front-wheel-drive 3.5 Pathy.......
Old Dec 1, 2006 | 03:03 PM
jvelos3's Avatar
sounds good...but why use the 00VI? the 00VI is for an engine that is .5 liters smaller...so i dont think it flows better than the pathyVI or the other 3.5 IM's.
Old Dec 1, 2006 | 03:33 PM
RA030726's Avatar
Until dynos have been done with the VI open, closed, and dialed in we will just have to wait. I think the short runner length only may work well at the track, similar to the SSIM. On the street the long runners would be good in the city like the VQ30DE USIM.
Old Dec 1, 2006 | 03:35 PM
RA030726's Avatar
The runners are the same shape, so it wouldnt need any boring or customization to fit and flow well.
Old Dec 1, 2006 | 11:04 PM
JClaw's Avatar
Well if the 00 VI is great on boosted engine, it'll do fine on a NA 3.5.
Old Dec 2, 2006 | 09:54 AM
d00df00d's Avatar
You'd be surprised.
Old Dec 2, 2006 | 10:04 AM
nismology's Avatar
The people that went from a 00VI to a 2k2 IM noted a power gain.
Old Dec 2, 2006 | 10:32 AM
JClaw's Avatar
Yes - extremely poorly matched to FWD VQ35 heads and lower IM. No one has tried VQ35 pathy heads and lower IM with 00 VI.
Seriously - the whole pathy VQ35 (okay, perhaps with FWD VQ35 shortblock) running on a VQ30 ECU but with VTC's on top of that - and a 00 VI - would be a great setup, really. I hope someone tries it. Then we will know FOR SURE how well the 00 VI works on an NA VQ35 setup since the heads and lower IM actually have oval ports that match up perfect to a 00VI.
Old Dec 3, 2006 | 12:08 AM
jvelos3's Avatar
wait...ppl noticed an increase in power with a 3.0 w/2k2 IM or 3.5 w/00VI IM?
this is getting really interesting...
Old Dec 3, 2006 | 07:01 AM
d00df00d's Avatar
We're not talking about 3.0s.
What happened was that some people with 3.5 swaps were using the 00VI even though the ports didn't quite line up. Then they switched to the 2k2 IM and got more power (duh).
Old Dec 3, 2006 | 07:02 AM
d00df00d's Avatar
BTW, is anyone concerned that Pathy heads might not be as good for high RPMs (>6k)? Has anyone looked at them vs. other 3.5 heads and compared?
Old Dec 3, 2006 | 11:17 AM
Zack342's Avatar
It did and if anyone is interested I have Lower VQ30DE manifold with injectors for sale.(shameless plug)
Old Dec 3, 2006 | 11:19 AM
Zack342's Avatar
Cost $30 too ship its darned heavy
Old Dec 3, 2006 | 11:22 AM
Zack342's Avatar
any photos ?
Old Dec 3, 2006 | 11:23 AM
Zack342's Avatar
Old Dec 3, 2006 | 11:24 AM
Zack342's Avatar
The pathfinder Heads
Old Dec 15, 2008 | 10:56 PM
l3ftonm3's Avatar
I hate to bring up a really old thread but what happened with this? I was looking for info about a thread where someone mentioned chopping up a pathy manifold for a 3.0 and ran into this.
Old Dec 16, 2008 | 08:02 AM
KRRZ350's Avatar
Good point, and search for posts by 98seblackmax and you will find the other thread you are thinking off, don't know if he gave up after all the timing cover issues but you should bump that thread as well.
So with the '02vi properly portmatched set-up that I did I think we can now assume that even though the '02vi gives huge gains and 1k rpms early than an '00vi, for a motor that is setup to rev out, the '00vi is still the king. BUT, I'm still anxiously awaiting the 2 manifold people have been sleeping on - the de-t & pathy, I have alot of faith in the pathy.
Old Dec 16, 2008 | 09:26 AM
grey99max's Avatar
So how could you mod one of these for a 3.5 ??
