Sponsored by:
Sponsored by: CARiD
98 engine on a 95 max
Old Dec 2, 2006 | 02:00 PM
awsker's Avatar
hi, i was hoping to get some information about swapping a 98 engine on a 95 maxima. The car is a 5 speed and the used motor came from a 98 max with automatic transmission. Does this matter? You should be able to put in a 95-99 engine as a replacement right? Would the ECU matter? If any one has done a similar swap can you tell me some pointers?
thanks!
Old Dec 2, 2006 | 02:07 PM
JClaw's Avatar
It will drop right in
Old Dec 3, 2006 | 09:55 AM
95turbo gxe's Avatar
the ecu wont matter. You will need to change the pilot bushing over from auto to manual
Old Dec 3, 2006 | 03:06 PM
RA030726's Avatar
I'm nutty for Nissans
If your car is a 95 FED spec then youll need to reuse all the original sensors. Youll want to swap over the TPS sensor, it may be different b/c of the trannys. The pilot bushing does nothing for our cars so you wont need to touch it.
Old Dec 23, 2006 | 12:43 PM
awsker's Avatar
getting a whole bunch of codes now. so the sensors need to be specific to fed spec or cali spec? dam. how would i find that out?
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
