Sponsored by:
Sponsored by: CARiD
de-k injectors in 4th gen w/ stock ecu?
Old Dec 12, 2006 | 02:23 AM
Ceasars Chariot's Avatar
Old Maxima Legend
with all the 00VI swaps being done, figured someone out there has been there and done that ! just wondering how much richer the car is going to run, and what to expect until i get the greddy eu tuned.
ruin spark plugs ? burn heaps of fuel ? just looking for some personal experience and what i need to do with this setup until tuning?
Old Dec 12, 2006 | 05:00 AM
RA030726's Avatar
I'm nutty for Nissans
Under normal driving it should be fine, with you mods you may run pretty good under WOT.
Old Dec 12, 2006 | 06:44 AM
gtr_rider's Avatar
192.168.1.1
Under normal conditions like Jason said, you wont notice a thing.. I do however notice a difference between WOT and 3/4 throttle w/o a fuel tune.
Old Dec 12, 2006 | 12:53 PM
Old Maxima Legend
gtr a bit slower right ? so the difference in size is not enough to mess up anything short term.
Old Dec 12, 2006 | 05:35 PM
RA030726's Avatar
You can get an AFPR and lower the FP ever so slighty, BUT dont bother until you check your a/f ratios. Stock is 259 and the DEk ones are 290 IIRC. Its not a huge difference, definetly not enough to foul the spark plugs. If anything the rich condition will slow you down, keep you cool, and pretty darn safe.
Old Jan 4, 2007 | 02:07 PM
VQ'ed's Avatar
I plan to upgrade my engine for spring. Actually I have injen cold air intake, y-pipe, hi flow cat, 2.5 cat back mandrel bent and NGK iridium plugs.Other small things but not as important as these. I'm thinking about these parts:
-Pathy TB
-V-ACF2 with 24 pts corrections
-DE-K rails and injectors(290cc/min)
-FPR with gauge around 50 psi
-DE-K heads with cams
-00VI
I have a deal on a 64,000mi DE-K at 800$CAN around 600$US.
What kind of gains should I expect.Or with what I actually have, what would you guys do.Consider I wanna stay N/A and 3.0L...
Thanks for your support!!!
Old Jan 4, 2007 | 08:07 PM
goldtooth's Avatar
i did a base street run and datalogged at the 9s....yeah, its pretty rich......
Old Jan 4, 2007 | 09:43 PM
jcy98maxse's Avatar
Turbo is too much fun!
-Pathy TB
-00VI
upgrade engine... meaning you don't have a 3.0L or just getting a newer motor in the form of a DEK? I'm a little confused since you posted both you're getting a DEK for $800 CAN but you also getting DEK heads with cams??? 00VI?? Both comes on the DEK already so you wont have to make additional purchases. Anyhow, you will see a very noticeable gain in the top end power without sacrificing low or mid range....
Old Jan 5, 2007 | 06:39 AM
VQ'ed's Avatar
I already have a VQ30 in a GXE 97 and planning to swap all the components from the DE-K mentionned in my last post.I just don't want to remove my present engine.
Old Jan 5, 2007 | 06:49 AM
VQ'ed's Avatar
I want to have another 'shelf engine' like the block,accessories that comes with it and internals. If the engine internals craps, I would have the internals to swap in the 3.0DE block. Imagine if we can stroke it with higher compression pistons, I would already have the the crank and bearings in the DE-K shelf engine.
Old Jan 5, 2007 | 09:13 AM
gtr_rider's Avatar
192.168.1.1
Yes, a bit slower but no I have been running without the tune for almost a year now and its perfectly fine. I should be fixing that eventually
Old Jan 5, 2007 | 05:29 PM
JClaw's Avatar
If youre going to buy a DEK for 800 you really should swap the whole engine. Better cooling and redesigned internals. Youre paying 800 why not use all to get your moneys worth. I mean I paid 600$CND for a 2003 VQ35 in Montreal. Dont short sell yourself.
Old Jan 6, 2007 | 08:00 AM
VQ'ed's Avatar
I was between swapping the whole engine or swapping those components.
Thanks for the advice and if i do it, I'll post in the future...
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
t6378tp
Aug 24, 2015 07:03 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
