Sponsored by:
Sponsored by: CARiD
Vq30dd
Old Dec 13, 2006 | 09:50 AM
JClaw's Avatar
Vq30dd
Would we be able to use the ECU-wiring harness stuff from a VQ30DD to run Direct Injection? Wouldn't this allow us to safely run like 12.5 compression on pump gas? (We get 94 Octane here) I say that would be a good combo with the superior 3.5 heads (cooling and knock surpression).
Old Dec 13, 2006 | 11:31 AM
Kevlo911's Avatar
Kevlo for President
I think the US gas has too much sulfer in it to use nissans DD
Old Dec 13, 2006 | 12:32 PM
Tatanko's Avatar
Bacon Lover
It's not so much octane that's the problem (we have 93 and 94 pretty widely available here everywhere except Cali), it's the sulfer as Kev mentioned.
Old Dec 13, 2006 | 12:40 PM
Jeff92se's Avatar
I'm needing a caw
Doesn't direct injection use very high pump pressures? You would have to modify your fuel system
Old Dec 13, 2006 | 12:42 PM
streetzlegend's Avatar
255lph high pressure perhaps?
Old Dec 13, 2006 | 12:54 PM
1FSTMAX's Avatar
How does sulfer in gasoline affect engine performace?
Old Dec 13, 2006 | 01:06 PM
Jeff92se's Avatar
I'm needing a caw
I believe sulfur might be bad for the DI injectors
Old Dec 13, 2006 | 08:41 PM
505max94se's Avatar
USDM Mazda cars have DI...
Old Dec 14, 2006 | 02:45 AM
Hoooper
mazda isnt the only company today with DI in american sold cars. they are saying the problem is with this particular setup from nissan, not that it cant be done
Old Dec 14, 2006 | 07:52 AM
Kevlo911's Avatar
Kevlo for President
Like I said... IN NISSSAN's DD
Do some google searches on it, I found plenty of info back in the day when I found out about the motor.
Old Dec 14, 2006 | 06:21 PM
505max94se's Avatar
ahh I see, I just thought DI would be similar in other motors as well...
Old Dec 15, 2006 | 05:07 AM
I30tMikeD's Avatar
Changing from Multi port to Direct injection would be an undertaking to say the least.
Old Dec 15, 2006 | 06:01 AM
MaximaSE96's Avatar
Maxima Owner
yes yes it would...it would be sweetness but quite the Undertaking as u state it
Old Dec 15, 2006 | 09:22 AM
I30tMikeD's Avatar
More like virtually impossible
Old Dec 15, 2006 | 09:44 AM
Jeff92se's Avatar
I'm needing a caw
Yeah, what do you know?
I wonder if that's the Tier 1 gas that's out? For DI?
Old Dec 15, 2006 | 01:35 PM
liqidvenom's Avatar
brotherhood of tq
why would he buy US gas? unless we pump our stuff up there to americas hat
Old Dec 15, 2006 | 01:42 PM
Kevlo911's Avatar
Kevlo for President
NorthAmerican gas happy, ahole
Old Dec 16, 2006 | 02:59 PM
JClaw's Avatar
lol, if it cant be done in the US, it cant be done in Canada either. The only advantage I have is nigh sea level, but poorly prepped tracks. The gas is most likely the same type of ****.
I was really curious about this one ever since someone brought up a hypothetical VQ35DD in an old thread. Since I'll be running this engine like a 3.0 I wanted to know if it was possible to use 30DD stuff to obtain a 35DD.
Looks like it's back to searching how high of a compression ratio we can run in North America, on pump gas with the regular 4th gen multi port setup.
Old Dec 18, 2006 | 11:07 AM
SR20DEN's Avatar
VQ Wizard
The new Toyota 3.5 liter V6 in the IS350 is a DI.
And I thought they had removed the high sulfer content in North American gasoline for '07 as they did for the diesel fuel.
Old Dec 18, 2006 | 11:11 AM
Kevlo911's Avatar
Kevlo for President
Where did you read this?
Old Dec 18, 2006 | 11:54 AM
SR20DEN's Avatar
VQ Wizard
For the gasoline? I don't remember. Which is why I am not trying to state it as fact. But they do have it posted on the diesel pumps.
Old Dec 18, 2006 | 02:02 PM
MaxesRule's Avatar
Hope these help:
http://www.fueleconomy.gov/feg/lowsulfurdiesel.shtml
http://www.eia.doe.gov/oiaf/servicerpt/ulsd/index.html
http://www.npra.org/issues/fuels/gasoline.cfm
http://www.dnr.state.wi.us/org/aw/ai...urfuelfaq.html
Old Dec 18, 2006 | 08:14 PM
Kevlo911's Avatar
Kevlo for President
Sweet, good to know. I wonder how the extra ethenol(spell?) in the gas in the NE affects direct injection.
Old Dec 19, 2006 | 12:20 AM
Hoooper
so does this mean it would be possible? meaning it would work ok, not that putting it on would be possible
Old Dec 19, 2006 | 09:44 AM
liqidvenom's Avatar
brotherhood of tq
ethanol is always a good thing, if anything it will aid in allowong people to increase timing even though it might be a little bit...but i dunno how much extra ethanol is in the gas
Old Dec 19, 2006 | 10:16 AM
Kevlo911's Avatar
Kevlo for President
No it's not a good thing. It is only good if the car is made for it.
Old Dec 19, 2006 | 10:22 AM
Jeff92se's Avatar
I'm needing a caw
Ethanol is a good thing? In what way?
Old Dec 19, 2006 | 10:46 AM
liqidvenom's Avatar
brotherhood of tq
wat do u mean made for it? minus altering the timing, possibly a fuel filter change since the ethanol will break free sediments in your tank and maybe less mpg running more ethanol will do no harm to your car.
in addition to hopefully being cheaper and give you more power ( even though less mpg) ethanol is great for people who can tune a car since it has a high octane rating and will help reduce detonation. so in theory u can run the same car harder
Old Dec 19, 2006 | 10:54 AM
Kevlo911's Avatar
Kevlo for President
Power gain not found. Maybe pure it might be good, but when its mixed in with gasoline it is no good.
Old Dec 19, 2006 | 11:22 AM
liqidvenom's Avatar
brotherhood of tq
e85 is ethanol mixed with gas.....if u can get ur hands on some it has an octane rating of something like 108 or something. run that with more timing and there is yoru power gain, and also your 15% or so loss in mpg
pure and cars wouldnt start in cold weather in the NE.
Old Dec 19, 2006 | 11:27 AM
Kevlo911's Avatar
Kevlo for President
So where can you buy E85?
The little bits of ethanol mixed with gas is not helping any.
Old Dec 19, 2006 | 11:42 AM
liqidvenom's Avatar
brotherhood of tq
there is an e85 locator online somewhere i misplaced it, but yeah the 10 or so % in what we have now, which i think is called e10 or gasohol or something liek that, isnt doing much for us aside from burning cleaner. i kno they sell it in our area but only on military bases or something for testing before its available for public use
Old Dec 19, 2006 | 12:05 PM
SR20DEN's Avatar
VQ Wizard
It costs more to burn E85 than regular gasoline.
Old Dec 19, 2006 | 12:45 PM
Kevlo911's Avatar
Kevlo for President
Ya I know. I was just stating, there arent many places that have E85 so too me there are no advantages. I really didn't want an answer to my question
Old Dec 19, 2006 | 10:12 PM
SPiG's Avatar
SomePsychoGuy
http://forums.maxima.org/showthread....ghlight=sulfur
I was very surprised they didn't just make a VQ35DD instead of the VQ35HR. Mazda and Lexus and I think maybe VW/Audi all use DI here. I don't see why Nissan can't do it. Super high compression, better mileage, and more power FTW. Changing those injectors would probably be a major PITA.
However converting to DD aftermarket would be very, very difficult. You would at least take a new ECU, probably wiring harness, fuel pump system, and different heads to get it to work.
Old Dec 20, 2006 | 05:45 AM
JClaw's Avatar
That is why I suggested all stock VQ30DD stuff. Aftermarket would also be very expensive I think.
Old Dec 20, 2006 | 11:43 AM
SPiG's Avatar
SomePsychoGuy
No I meant converting to a VQ30DD even with the JDM OEM parts. Aftermarket as in converting it custom, i.e. not having Nissan do it from the factory. I have never even seen VQ30DD parts in the US, so that would be your first thing to accomplish in something that seems rather uphill IMO. People have done plenty of other things that others said were impossible or not worth it so if that is what you want to do, go for it.
Old Dec 20, 2006 | 11:48 AM
JClaw's Avatar
I am just brainstorming on how to create a reliable, high HP, high revving NA VQ. Hence the thread about using a VQ30 crank and sleeved VQ35 block.
Old Dec 20, 2006 | 11:55 AM
Kevlo911's Avatar
Kevlo for President
I have yet to see a DD for sale. If you can find one, I am sure you can make it happen.
Old Dec 20, 2006 | 12:04 PM
JClaw's Avatar
The problem I think is that the 30DD most likely uses the 3.0L oval ports so my VQ35 lower IM does not match. I am only planning on a custom upper intake manifold (ITBs) but am not touching the lower with a 10 foot pole for now.
