Sponsored by:
Sponsored by: CARiD
VQ35 with 3.0 ECU Write-up.
Old Jan 19, 2007 | 07:14 AM
tavarish's Avatar
fwd gone rwd cr00
Check it out:
http://forums.nycmaximas.org/showthread.php?t=19270
Old Jan 19, 2007 | 07:30 AM
JClaw's Avatar
Super detailed write up, ya cant possibly fawk it up. Lots of pics (that helps newbs alot).
Old Jan 19, 2007 | 07:31 AM
tavarish's Avatar
fwd gone rwd cr00
Sticky! LOL
It'll help people who can search, rather than PM everyone.
Old Jan 19, 2007 | 07:34 AM
WielkiWaac's Avatar
MaximaDriver
very veeery nice
Old Jan 19, 2007 | 09:21 AM
meximax's Avatar
SC Overspinning Swapper!!
Great write-up and congrats on the nice clean job.
Old Jan 19, 2007 | 11:29 AM
MaximaSE96's Avatar
Maxima Owner
we need a detailed write up like this for DE-Ks....Good Job
Old Jan 19, 2007 | 11:37 AM
scrhale's Avatar
Why was it necessary to strip the engine down that far? Or was that just valve covers and timing parts removed? Sorry for the noob question.
Old Jan 19, 2007 | 11:38 AM
97Maximus's Avatar
Shift_custom
yeah thats a great write up man! def needs to be a sticky!!
Old Jan 19, 2007 | 11:48 AM
Nismo3112's Avatar
Custom User Title
It's necessary.
Nice job on the writeup!!
tavarish's Avatar
fwd gone rwd cr00
You could swap in a DE-K with the steps from my writeup. You just don't have to open up the engines.
Old Jan 19, 2007 | 12:45 PM
MDeezy's Avatar
great write up tavarish. good detail and a lot of pics, this in conjunction with the previous write that is already stickied, should be all anyone needs to do the swap.
Old Jan 19, 2007 | 12:49 PM
tavarish's Avatar
fwd gone rwd cr00
yup, i want this to be the end of the incessant pm's about this and that - the do's and don't during the swap.
Old Jan 19, 2007 | 12:59 PM
MDeezy's Avatar
I think that might still happen, but with your write up it should cut that down atleast in half.
Old Jan 19, 2007 | 02:57 PM
915Max's Avatar
I'm guilty of buggin!!
I wish I would have ran into this a while back.... I was completely unaware of the thermostat replacement... but I would have probably figured it out once I get to that.
Anyways thanks to everyone who has put up with my pm's and repetative questions.
Old Jan 19, 2007 | 03:31 PM
hightuner's Avatar
Nissan maniaco conpulsif
i think he mean dek swap for a DE engine
anyways , great how to ...
Old Jan 19, 2007 | 07:44 PM
tikiboom's Avatar
I need an intervention
that is a beautiful write-up
kudos
Old Jan 19, 2007 | 09:00 PM
95BLKMAX's Avatar
i aplaude to your writeup, great job
Old Jan 19, 2007 | 09:20 PM
tavarish's Avatar
fwd gone rwd cr00
Thanks, everyone.
Can someone sticky this?
Old Jan 19, 2007 | 09:51 PM
glenmoormax's Avatar
10 psi
One question. You used the 3.5 upper oil pan instead of the 3.0, I thought there was some modifications needed to make that work? Or is the 3.5 upper oil pan work?
Old Jan 19, 2007 | 09:56 PM
maximariceboi's Avatar
bump to be put into the sticky
Old Jan 19, 2007 | 11:30 PM
gtr_rider's Avatar
192.168.1.1
very nice
Old Jan 20, 2007 | 07:42 AM
TomV's Avatar
Thanks a ton Tavarish. Will help me immensely when i finally do the swap.
Another vote for the sticky...
Old Jan 20, 2007 | 08:00 AM
915Max's Avatar
Sticky fo sho!!
Old Jan 20, 2007 | 08:22 AM
deezo's Avatar
Done. If the mods in this forum have another way of containing this writeup in this area of the site, feel free to do so.
I pdf'd the writeup just in case I eve get the ***** to do the swap.
Old Jan 20, 2007 | 08:25 AM
krismax's Avatar
Father of the 00 VI
i noticed you didnt use the 3.5 oil cooler with the swap is there a reason for this. my car runs very cool with it and it allows the use of the lower temp 350z thermostat.
tilley did that stuff without me there didnt see what went into doing that.
also knowing i love weight reduction, me and tilley weighed the pass mounts 3.5 and 3.0 and actually on a very precise gram scale the 3.5 mount was slightly 1 lb more. so......
Old Jan 20, 2007 | 08:39 AM
tavarish's Avatar
fwd gone rwd cr00
I didn't have the full cooler lines with the engine, so I just blocked it off with a bolt. My engine has never run hot, and the 3.0 thermostat is fine. Don't know if the 3.5 thermostat would run a little cooler, but my engine gets enough ventilation, and I have the rewired fans.
I honestly don't remember which mount I used, whichever one was in better shape.
Old Jan 20, 2007 | 08:41 AM
tavarish's Avatar
fwd gone rwd cr00
no modifications needed. I used a 3.5 crank sensor and plug, I just spliced into the wires.
I'll add that to the writeup. Remember, I did this from memory one night, and i'm bound to have forgotten something.
Old Jan 20, 2007 | 09:01 AM
97_Roadrunner's Avatar
If I could ask you about the wiring diagram...What has been left from the 3.5 wiring and sensors. What has been used from the 3.0. We`re about to do the swap but were intimidated by the electronics. Developped answer please.
-injectors: wiring back the 3.5 clips on 3.0 wiring
-coils packs: 3.5 coilpacks wired back on 3.0 wiring
-o2 sensors: 3.5 sensors rewired on 3.0 wiring???
-evap: do we keep it from the 3.0L???
-iacv: plate adapter with 3.0 hardware
-MAF: 3.0L or 3.5 rewired on the 3.0 wiring
-Map/baro sensor from 97 : is it necessary??
-crank sensor: 3.0L sensor on the 3.0L pan
-cam sensor: same 3.0 sensor on front bank/timing cover
Explain what you did, sensor by sensor would be SUPER Appreciated.
Not noobs but still affraid of electronics. If i miss something, let me know!!
Thanks twice!!!
Old Jan 20, 2007 | 09:25 AM
915Max's Avatar
I was looking at both coolant tubes from each and that extra tube off of the 3.5 is for the oil cooler right!? I really didnt get a chance to look at it carefully because it was raining a lot and freezing--I i unfortunatly dont have a garage so my engines are sitting in my front yard covered up by a couple of tarps.
What sensor is not on the 3.5? I also looked at both the 96 and the 04 FSM and I couldnt find any differences, other than the coolant tube, but I might have missed it.
Old Jan 20, 2007 | 06:20 PM
915Max's Avatar
n/m... when I got home from work, I looked at the engine and saw what coolant tube your thread talked about. sorry...should have looked at it before asking away.
Old Jan 20, 2007 | 07:15 PM
MDeezy's Avatar
Yes splice and wire in the 3.5 injector clips onto the 3.0 harness
Your motor should come with 3.5 coils, and the stock 3.0 harness will plug into them no problem.
You can keep using your normal 3.0 sensor. If one is bad and your motor came with an o2, I believe it can be used, you have to rewire them in.
Plug the sensors in, and tie them off somewhere
get the adapter plate from stephen Max, and you'll be able to use the iACV, many arent running it. I believe those who run the pathy TB will need it, as that doenst have the iacv build into the TB, like the 3.5 eletronic TB does
Dont know if your motor came with a 3.5 MAF, but stick with your stock MAF from the 3.0
Plug in the sensor and tie it off somewhere.
use it, if your using the 3.0 oil pan.
use it, you need it. nothing needs to be rewired, if thats what your wondering.
Thanks twice!!!
Old Jan 21, 2007 | 12:25 AM
KRRZ350's Avatar
AWESOME WRITE-UP! just a tip here, instead of spending forever with stupid gasket scrapers just use a "3m automotive scuff pad" and brake cleaner (then rags) it take's 1/10th the amount of time to get it way better, you'll throw away even the most expensive scraper once you try it.
Also, I noticed you re-installed the o-rings in the 3.5 head for the vtc oil channel that is non-existant in the 3.0 timing cover. I actually saw them tonight and I also noticed that the one in the front head get's blocked by the 3.0 timing cover. I was clueless as to which way the flow went and how the vtc's worked, but just on my own assumptions from looking at it I think those selenoid looking things near the head are some sort of pressure regulator and my geuss on it was that oil pressure comes through the head, into those regulators and then gets pumped through the timing cover into the vct's and then drains back to the oil pan through the timing cover. So just to be on the safe side I cut a little groove in the front head so that it would channel any oil from this passage back into the timing cover just like the passage on the rear head is using 3.0 covers, I'm going to take pics tomorow, I might have wasted my time but oh-well, I just wanted to be on the safe side and not disrupt the oil flow that much from how the head was engineered to be
Old Feb 20, 2007 | 07:30 PM
UNDEFINED76's Avatar
nice write up....can u use a pftb on the 3.5 im???
Old Feb 21, 2007 | 07:13 AM
MDeezy's Avatar
yes. An adapter would be needed as well.
Old Feb 26, 2007 | 04:32 AM
does anyone sell one???
Old Feb 26, 2007 | 09:06 PM
accordingtou's Avatar
VQ30 DE T
STEPHENMAX
Old Mar 13, 2007 | 12:19 PM
ghostmax301's Avatar
need to register to look at it.. i tried twice and never got a email, is there a maxima.org username we can use or something?
Old Mar 23, 2007 | 11:41 AM
95naSTA's Avatar
One tip for blocking the EGR when using the vq30 exhaust mani's is;
Just cut the metal hose and seperate it from the nut that screws it into the exhaust manifold, put a nickel in the exhaust manifold EGR port with some high temp RTV, and torque the nut back down sandwiching the nickel.
Kinda ghetto, but cheap and you'll never see it.
Old Mar 23, 2007 | 12:25 PM
Nismo3112's Avatar
Custom User Title
Interesting.. I just finished a swap and we got a shop to weld the EGR pipe shut for free.
Old Mar 23, 2007 | 12:36 PM
95naSTA's Avatar
Yeah, obviously if you have a welder or free access to getting that done, why not.
But, if not, it will only take a couple on minutes to plug it up.
