Sponsored by:
Sponsored by: CARiD
35 LIM Q's
Old Jan 22, 2007 | 01:55 PM
Broaner's Avatar
2060lbs and falling...
35 LIM Q's
I'm assuming that the 35 LIM between the FWD and the Z/G VQ are identical. Just want somebody to confirm this if they can.
Once that is confirmed I can ask; is the LIM perfectly symetrical? In other words, can it bolt between the heads in either direction? If not what are the restrictions?
Old Jan 22, 2007 | 02:15 PM
nismology's Avatar
They're not the same. Different part numbers. This is why people have had to use the Z LIM when swapping the upper.
Old Jan 22, 2007 | 02:17 PM
krismax's Avatar
Father of the 00 VI
ok i know this for fact . 3.5 fwd LIM isnt the same as the Z/G lower IM
and iam gonna say that the fwd 3.5 lower can be swapped either way. but if you dont mind waiting i will try for you fri. I need to take my upper off for some work . Ill unbolt the lower and turn it around for the sake of science
Old Jan 22, 2007 | 02:45 PM
Nealoc187's Avatar
SLOW
I thought your thread title meant you had thirty-five questions about the LIM.
Old Jan 22, 2007 | 05:42 PM
Broaner's Avatar
Funny Neal.
Thanks for the heads up guys. I guess I'll have to see how much I can get the Z hardware for. Basically, I'm thinking of using a Z33 system. I'm hoping to turn it around, cut off the OEM TB elbow and weld on my own setup so I have a center mounted TB over the timing chain cover.
Old Jan 23, 2007 | 07:59 AM
tavarish's Avatar
fwd gone rwd cr00
Funny Neal.
I have the whole setup for sale, 200 shipped.
Old Jan 24, 2007 | 07:49 AM
Broaner's Avatar
Sent a PM to you. Since you have that I guess I should say that I'm interested in a set of used cheap DE-K topfeeds. As long as they work I don't care how old they are. I only need them to work for one year and then I'm moving to 550's.
Old Feb 3, 2007 | 03:21 PM
Broaner's Avatar
New bit of info suprised me very much. I thought the reason the 30LIM didn't work with the 35 heads was because they were oval. This site is disclaiming that. I'm totally at a loss. I thought all 35's had oval intake ports and thus allowed for the use of the Z33 system. WTF? I'm p!ssed. Is this info correct? If so how are you guys using the Z33 systems on the FWD 35 heads? Port matching?
http://www.anothershade.com/vq.htm
and
http://www.engineswaptech.com/forums/thread/1750.aspx
Old Feb 3, 2007 | 03:45 PM
nismology's Avatar
That first site is plain wrong. All Gen II VQ35's use the same head casting (Maxima/Altima/Quest/Murano/350Z/G35/FX35 etc.).
Old Feb 3, 2007 | 05:58 PM
95turbo gxe's Avatar
interesting Im wondering what 3.5 heads will the beloved 00vi work with on a 3.5 block?
Old Feb 3, 2007 | 06:06 PM
scrhale's Avatar
early 3.5 pathy heads ... this is pretty well known.
Finkle
Sep 27, 2015 09:53 PM
MOHFpro90
Jan 14, 2011 05:05 PM
natty99
May 16, 2007 08:05 AM
maxgp1029
Apr 29, 2007 08:22 PM
toddemullins
Jul 26, 2006 08:25 AM
