Sponsored by:
Sponsored by: CARiD
reluctor ring
Old Jan 24, 2007 | 03:00 PM
Hoooper
reluctor ring
when installing a flywheel, how easy would it be to damage the reluctor ring?
Old Jan 24, 2007 | 03:22 PM
eng92's Avatar
On an A33B?
6MT or 5AT?
The 6MT is thicker (~1/8" plate) and is welded on.
You won't damage it by hand but if the flywheel is dropped, you will knock it out of true. The sensing face on the crank sensor is wider than the ring though so you should be able to straighten it out sufficiently so it will work. I had to on mine when I did my swap because it warped a little from the welding.
The 5AT ring is a much lighter gauge and is bolted on. It is pretty easy to bend but it can also be straightened easier.
As long as the ring is still round but just a little out of true, it is repairable.
Old Jan 24, 2007 | 04:59 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by eng92
6MT or 5AT?
I WISH the A33B came in 5AT
Old Jan 25, 2007 | 03:23 PM
Hoooper
6mt, according to nissan the reason my 3.5 will not start is that the reluctor ring was damaged somehow. are you saying that they could possibly just straighten it out somehow and it would be fine?
Old Jan 25, 2007 | 05:01 PM
eng92's Avatar
They can tell if the signal plate is damaged by watching the crank signal pulses while the engine is cranking. If they are not in the correct pattern, the sensor is not reading all of (or too many) gaps, there is a problem with the signal plate.
Obviously whether it can be repaired or not depends on the type and severity of the damage to it. You cannot determine this until the flywheel is removed.
However, the dealer is not going to screw around trying to get it into spec. They will just replace the flywheel.
Old Jan 25, 2007 | 05:10 PM
Hoooper
bah, thats what i figured. i guess its new flywheel time, too bad they wont install a new aluminum one, theyll demand OEM like a typical dealer. o well, thanks for the information
maxfever1987
Nov 19, 2016 08:01 PM
Pied
Sep 26, 2015 03:29 PM
msellas
Sep 23, 2015 09:16 PM
DBear
Sep 14, 2015 08:33 PM
95Maxi
Aug 25, 2015 08:01 PM
