Sponsored by:
Sponsored by: CARiD
Engine harness for 3.5 swap
Old Jan 24, 2007 | 09:11 PM
THT's Avatar
THT
Throbbing member
My engine didn't come with the main engine harness so I'm missing the injector clips for the front bank. I vaguely recall seeing a post that said it's possible to get the harness or clips at an auto parts store. I searched for the post but came up empty handed. Anyway, is this true? Can I go to O'reilly's/Napa/Autozone and get the harness or clips? Salvage yards I've called want $100 for the harness...
Old Jan 24, 2007 | 09:13 PM
02Meridian
You can probably use a Dremel to file down the edges around the plug itself and use any plug with the same pin size/spacing.
Old Jan 24, 2007 | 09:24 PM
tavarish's Avatar
fwd gone rwd cr00
you can use 2000 chevy s10 injector plugs, you can get those at autozone.
Old Jan 24, 2007 | 09:30 PM
THT's Avatar
THT
Throbbing member
Direct fit or does this require special adhesion or other modification to work?
Old Jan 25, 2007 | 07:28 AM
tavarish's Avatar
fwd gone rwd cr00
I haven't tried them, but they need little to no modification to work.
Old Jan 25, 2007 | 04:46 PM
MDeezy's Avatar
according to goaliekeg you might need to adjust to conector like break off a tab or two and then it fits right on.
MAXSE5SPD
Sep 17, 2022 04:00 AM
vingodine
45
May 21, 2016 12:46 PM
schmellyfart
Sep 25, 2015 04:47 PM
TurboA32
Aug 27, 2015 08:44 AM
Blackwind
Aug 5, 2015 06:35 PM
