Sponsored by:
Sponsored by: CARiD
00vi idle problem need help ASAP!!
Old Feb 3, 2007 | 09:07 PM
4x4Max's Avatar
We just put on my 00vi on my 99, using the dek lower, upper, fuel rail, injectors, tb, iacv.
Whenever i start the car, it won't idle at all and runs VERY rough anywhere under 4k+ rpm. If i keep pressing the gas, i can keep it running but the rpm jumps up to 4k whenever i hit the gas. If i keep it running anywhere below that, its extremely rough and even pops sometimes through the intake. It smells like gas from the engine bay. I don't belive i have a vacuum leak.
Anybody have ideas?
Old Feb 3, 2007 | 09:43 PM
matty's Avatar
injector o-rings...find the source of the leaking gas then fix it. Its running rough because of that...
-matt
Old Feb 3, 2007 | 10:12 PM
4x4Max's Avatar
-matt
For the o-rings, do i need to buy new ones or is it common for them to just sit wrong or not be positioned correctly? I'm guessing that this is also related to my idle problem, or maybe i do have a vacuum leak on top of the o rings. What do you think?
Old Feb 4, 2007 | 07:49 AM
4x4Max's Avatar
Guys i'm about to go over to my friend's garage where my car is, and i really need to know if this 0-ring problem is fixable or if i need to buy new ones. I'm going to research but i really don't have any time because i need to take the whole manifolds apart now to fix the leak since its in the back 3 injectors under the upper manifold.
Old Feb 4, 2007 | 09:42 AM
4x4Max's Avatar
Took injectors off with the fuel rail, and it does not look like anything is bad. I can't track down the problem, how do i know if something is wrong with my injectors or is it something else?
On the outer side of the fuel rail, i don't have any kind of dampener, i just attached a nipple there and hooked the fuel line just like the stock line was hooked up. I doubt thats the problem, but just throwing that out there.
I'm pretty positive that my fuel lines don't have any leaks, but i still smell fuel when the car is started and i'm attempting to keep it running with the gas pedal.
help a out!!
Edit: well...all the injectors spray. I took off the fuel rail and cranked the car and all injectors sprayed, so thats not it. How bout if i put a bunch of gasket sealant on the injector points where they seal and put it back, will that work?
Old Feb 4, 2007 | 12:44 PM
Curt's Avatar
[QUOTE=4x4Max]On the outer side of the fuel rail, i don't have any kind of dampener, i just attached a nipple there and hooked the fuel line just like the stock line was hooked up. I doubt thats the problem, but just throwing that out there.QUOTE]
I'm not sure what "the outer side of the fuel rail" is supposed to mean. Are you sure what you have on there is the FPR, and that you're not trying to make it run with a damper but no FPR? And I don't have a clue what the symptoms would be if you had the FPR but on the wrong end of the fuel rail and plumbed backwards. Stranger things have been done by guys.
Just a guess.
Old Feb 4, 2007 | 01:44 PM
jmeister's Avatar
Just in case
Old Feb 4, 2007 | 02:01 PM
4x4Max's Avatar
Uhhh...i dont have a dampner...i just JB welded a nipple on there and hooked it up like it should be hooked up. Is that the problem??? If so, how do i go about fixing it without spending more money that i don't have? Its running extremely rich and popping through the intake. I disconnected one of the plugged up vacuum sources on the manifold and it seems to run better for some reason, WITH a vacuum leak.
Here are some videos of how it is:
It IS idling in this video.
You can hear the popping in the middle of the video.
It's hard to tell from the video, but its running VERY rough. I took apart the injector rail and the o-rings look fine, and it seems like it seals up well.
Here's how it sounds from the exhaust side:
In the middle, i got the car to idle and stay at idle. After the video, i could have the car idling for a few minutes before dying, but its EXTREMELY rough like before.
Old Feb 4, 2007 | 02:27 PM
Ceasars Chariot's Avatar
Old Maxima Legend
we had trouble getting mine going as well. ( i want to make it clear that i dont know even 10% of what most of the all motor guys here know ) but my car sounded kinda like that.
we pulled each injector connector while it was running to see if it changed the way the car was running. it would try to die on the good injectors but on the two bad ones nothing changed.
then we took off the UIM and pulled the fuel rail and started the car and you could see 4 squirting fuel and 2 doing nothing. at that point my issues were solved. got two new injectors and everything ran correctly. not sure if you checked yours liked that ?
sorry i cant be of more help, but always willing to lend a hand !
Old Feb 4, 2007 | 02:35 PM
4x4Max's Avatar
Thanks for the reply, yeah i checked the injectors like you did and they all sprayed, so thats not the problem.
Old Feb 4, 2007 | 05:58 PM
4x4Max's Avatar
Update: the car idles perfectly smooth at 1500rpm without the maf sensor plugged in. When its reved, it goes up to 2.5k and acts like there's a rev limiter right there, it just bounces off of it. Wtf???
Old Feb 4, 2007 | 06:38 PM
matty's Avatar
With the MAF unplugged it shouldnt rev past 2500. Thats normal
-matt
Old Feb 4, 2007 | 06:56 PM
97Maximus's Avatar
Shift_custom
just a sugestion but have you tried out using a different MAF.. or even just checked to see if the injectors are dirty? either way its obiously a fuel problem.. no vacuum problems from what i can see.. which was my difficulty.. what codes are you running?
Old Feb 4, 2007 | 08:25 PM
4x4Max's Avatar
All the injectors seem to spray just fine, i took them out and cranked, and they all sprayed an even pattern. After, i put them back in and i'm almost positive that they sealed fine because i don't smell anything odd when the car is on. As for the codes, i have the following:
TPS
IACV
EVAP(i think i fixed this one)
Driving the car to autozone and back was interesting to say the least....
Old Feb 5, 2007 | 07:33 AM
97Maximus's Avatar
Shift_custom
Im assuming you have your tps set correctly?? thats odd that you are getting a IACV code.. cause i was almost sure that you coulde use a 5th gen IACV with the 5th gen TB and it would work just fine no codes.. just out of curiosity have you checked to see if that is working correctly.. there is a procedure you can follow in the FSM to see..
Old Feb 5, 2007 | 12:00 PM
4x4Max's Avatar
set tps, changed to 4th gen iacv setup, and no luck whatsoever. car still pops through the intake filter.
Old Feb 5, 2007 | 12:57 PM
matty's Avatar
If I were you I would pull the manifold off and change the upper i/m gasket. I think you have a major leak somewhere
-matt
Old Feb 5, 2007 | 01:19 PM
4x4Max's Avatar
Would it be running rich with a major leak somewhere? plugs are black and there is a lot of smoke from the exhaust. Would that mean its rich, related to a vacuum leak?
We just took the gasket off and it is broken a little bit but we sealed it with silicone, so it shouldn't leak air.
Old Feb 5, 2007 | 02:32 PM
Cdg2125's Avatar
As I said in the other thread, you probably have a mixed leak. Air and fuel. Check to make sure the rings seal. If you're getting pops from the intake then change the setup. The look of it has leak all over it. Also, get a new gasket. Don't try to seal it, just get another one.
Old Feb 5, 2007 | 05:02 PM
Mad-MAX_SE's Avatar
Still kickin'
the gasket pack for intake manifolds is a whopping 15 bucks from autozone (i know i bought them for my MEVI swap.) I would recommend just picking those up for piece of mind at the least that you know for sure that the gaskets are not the problem.
Old Feb 5, 2007 | 07:44 PM
4x4Max's Avatar
Ok guys i took off my lower manifold gaskets off, and they have fuel all over the points where they're supposed to seal, in some cylinders only. Tomorrow i'm going to get new gaskets from autozone and see what happens...also found a big *** hole in that home-midpipe-intake thing...gonna seal that up with tape for now to see if the car works.....
hopefully at this time tomorrow i'll be hooking up my rpm switch....you guys are always welcome to throw out other ideas though, it might not even be the gaskets because there wasnt that much fuel and it might of not been past the seal points.
Old Feb 5, 2007 | 08:01 PM
97Maximus's Avatar
Shift_custom
dont you have to retune these things after you convert over to the 5th gen injectors??
it sounds like you might have found your problem?
Old Feb 5, 2007 | 08:13 PM
4x4Max's Avatar
Yeah i'm getting emanage ultimate whenever i save up enough. For now, it'll run fine just a little rich. Power increase won't be as much with just the rpm switch and no tuning, but thats ok.
I REALLY REALLY hope we found the problem, i'll let you guys know tomorrow.
Old Feb 5, 2007 | 09:25 PM
Cdg2125's Avatar
No you don't have to tune. It's recommended since you'll be running rich but it's not completely necessary.
Yeah the leak of fuel and the mig a$$ midpipe hole should fix thing. Since things are off, go back and make sure everything is correct. Injectors, LIM, all that. So you'll know that that is set up right.
Old Feb 6, 2007 | 03:36 AM
Curt's Avatar
Now that you seem to be on the scent of a solution to the basic problem you've been experiencing, here's a suggestion:
You mentioned earlier replacing the damper on the fuel rail by JB Welding on a nipple. Certainly your decision, but speaking for myself, I wouldn't even start up my car with that sort of a shadetree, makeshift deal (I won't dignify it by referring to it as a repair).
Now that I've got your attention - just imagine for a minute the scene if that ever starts to leak. It'll have the same pressure on it as the injectors. Under the hood could be anywhere from a spray going all over the place, to a major fuel hemorrhage. And it'll probably happen at WOT when the fuel pressure is highest. That gas hits the hot exhaust and it'll be quite a flaming spectacle. Talk about going 60 MPH with your hair on fire. You'll be lucky if that's all that gets burned.
But then again, it's just a suggestion.
Old Feb 6, 2007 | 11:13 AM
4x4Max's Avatar
just got back from autozone, advance, and dealer. autozone and advance dont have the gaskets, and they can't order them. Dealer wanted 44 bucks EACH FOR A FREAKIN LOWER MANIFOLD GASKET!!!!! got the upper one for 8 bucks. No wonder so many people on this board hate how nissan is right now.
What the hell do i do? I'm not about to dish out a hundred bucks(that i DONT HAVE) for gaskets.
Old Feb 6, 2007 | 11:14 AM
4x4Max's Avatar
I'll fix it in a while, i need the car in working order first.
Old Feb 6, 2007 | 11:27 AM
Cdg2125's Avatar
[QUOTE=4x4MaxWhat the hell do i do? I'm not about to dish out a hundred bucks(that i DONT HAVE) for gaskets.[/QUOTE]
Well then you won't have a working car. Go back to autozone and have them order them. Cost me $21 for all three gaskets (one which I didn't need).
Old Feb 6, 2007 | 01:56 PM
Mad-MAX_SE's Avatar
Still kickin'
I went by advanced a few minutes ago while i was joyriding on my new d2's to verify they didn't have them, and I totally spaced that the gaskets you needed were for the 00-01 models, that was my mistake. However, i would think the lower IM gasket should be same as the 95-99, i mean it's bolting up to those heads afterall, and i know for a fact both advanced and autozone carry those (atleast around here they do.)
Old Feb 6, 2007 | 03:59 PM
4x4Max's Avatar
both autozone and advance auto said they cant even order it for me, its apparently a 'dealer' item. I just filled both gaskets with silicone implants so i'm gonna see if the car works right tomorrow. I'm about to order feltpro gaskets online for 20 bucks shipped, all 3. The silicone implants are just to test and see if maybe it holds for a few seconds, then i'll know its the problem.
Old Feb 6, 2007 | 05:00 PM
speed racer's Avatar
You know they have those gaskets readily available at the dealer. Don't be cheap on a mod and if its your DD why keep trying different alternatives. Stop trying to reinvent the wheel.
Old Feb 6, 2007 | 05:22 PM
4x4Max's Avatar
Actually they didnt have them at the dealer, they said they had to order them and they would have them in 2-3 days. Screw a hundred bucks for 2 gaskets, what a rip off....i'm ordering gaskets online for 20 bucks.
Old Feb 6, 2007 | 05:58 PM
Cdg2125's Avatar
What kind of stores do you have around you. You're sure you're asking for the correct parts right? lol. I don't understand that. Everyplace I went had the gaskets. Either order or in the store. Don't use silicone...come on.
Old Feb 6, 2007 | 07:32 PM
4x4Max's Avatar
I'm just gonna order the gaskets online, none of advance auto or autozone stores aroudn had the lower gaskets, they checked in 'the system'.
Decided to start the car with the silicone. The car is running a LOT better than before. No more popcorn machine, its pretty smooth. The idle is rough but hey i dont care for now, i'm just happy its working pretty well. The roads here are completely covered in snow so no test drive today, but tomorrow i'm taking her out fot a little bit to see how everything is doing. I'm using no iacv, just going to adjust idle with the throttle body screw and see how it works out during the next couple days.
Thansk for all the help, i'll probably be back with more issues later.
Old Feb 6, 2007 | 09:22 PM
Cdg2125's Avatar
You need an IACV to control air. I dont understand how the car will stay on without having the IACV plugged in.
Old Feb 6, 2007 | 10:00 PM
4x4Max's Avatar
I remember researching and i'm not the only one without it...if i remember correctly, stephenmax is runnign no iacv, i think i remember reading it in a thread. My TPS is toughly adjusted. I have .4v at ide and 3.79 at WOT....i cant figure out how to make both idle and WOT reading right. Idle is supposed to be .4, WOT is supposed to be 4, just for reference. Any hints?
Old Feb 7, 2007 | 09:47 AM
Cdg2125's Avatar
reading should be .5 and 4. I don't remember him not running IACV. This is your daily driver.....many run no evap. I havnt heard the no IACV.
Old Feb 7, 2007 | 10:13 AM
4x4Max's Avatar
.5 and 4?? oh crap, are you sure? i thought i read .4 and 4....dammit!! Thats probably why its idling weird sometimes.
edit: i searched again, in this thread it says .4 and 4
http://forums.maxima.org/showthread.php?t=379743
Old Feb 7, 2007 | 12:23 PM
4x4Max's Avatar
Just got back from a test drive, and the car feels slower than it was before. RPM isn't hooked up yet. I tried a run with the vias closed, and one with vias open(hooked up vacuum to the nipple, to open vias). Could not really tell a difference between the two. Car feels slower than it was with USIM. Where's all this top end power that i was suposed to get, am i missing it because of vacuum leaks?
I'm running no pcv right now.
Old Feb 7, 2007 | 02:37 PM
Cdg2125's Avatar
Why do you keep running the car not fully hooked up?
