Sponsored by:
Sponsored by: CARiD
Making connector for EU - Help!
Old Mar 1, 2007 | 07:15 PM
hacim105's Avatar
Ok I am trying to install my EU. So to start I wanted to make a connector for ease of installation. It will end up being a plug and play application.
So I started out by buying a used ECU and removing the main harness pin connection. Which gave me this:
I also got a main harness connector with all the wires and all that. And that was this:
I soldered all the wires to the pins. And this is the end result.
I was very proud of myself, I went and plugged the harness into the car to make sure everything was working. I start the car and here comes the cell, so I check it out and come to find out, for whatever reason the harness I have doesn't have all the necessary wires. It's missing like 13 wires. So I figure ok I think I can deal with this.
But now here's my delimma, how do I install the extra wires into the main harness connector? (shown here)
Is it possible to install more wires in, or am I screwed and have to buy another connector?
If anyone have any suggestions I'd appreciate it. I'm hoping I don't have to try and buy a new main harness connector. Which means I'll be waiting for someone to get into an accident and part out their car.
Old Mar 1, 2007 | 09:17 PM
eng92's Avatar
You just need to get some more female terminals to install in that connector. There are two or three different sizes used.
The terminals used in most of the connectors in the car are the same style. I would just go to a wrecker and find another Nissan that has the engine harness already damaged. That makes it an item they cannot sell and they will usually let you take what you need for a small fee.
There is a bit of a technique to removing the terminals from the connector without damaging them. I can send you some pictures if you need help.
Old Mar 1, 2007 | 10:21 PM
hacim105's Avatar
Ok I'll have to try that.
I would really like some pics of how to remove the female connectors and any other info you can offer.
My email is hacim007@yahoo.com, or you can post the info in here, which ever you prefer.
Old Mar 2, 2007 | 07:06 PM
SpeedCrazie's Avatar
Great Work, hopefully everything works out. Would you be intersted in making any more of these?
Old Mar 2, 2007 | 07:14 PM
hacim105's Avatar
I could if you were to get the parts for me.
Old Mar 2, 2007 | 07:24 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
What parts do you need? I am very interested.
Old Mar 2, 2007 | 08:05 PM
jmeister's Avatar
Shew, I just went thru all that last weekend and I'd never want to solder that much ever again. Looks good tho, mine looks like a birds nest. Gonna install over the weekend, hope I don't run into the same problem.
Old Mar 3, 2007 | 09:00 AM
hacim105's Avatar
Yeah well I found out I bought a 95 main harness connector. It has less emissions than the 96+ models so it is missing some wires. So as long as yours isn't a 95 connector you should be fine. Once I get the new wires in, the only thing left I want to do is encapsulate all the soldered joints with a hardening epoxy to create a strong more durable connection of the joints and it will also insulate all the exposed areas.
Old Mar 3, 2007 | 09:07 AM
hacim105's Avatar
I would need an ECU and the main harness connector with about 12"-18" of the attached wires.
Old Mar 3, 2007 | 11:47 AM
Iilac's Avatar
Does it matter what year harness and what year ecu it comes from?
Old Mar 3, 2007 | 06:31 PM
MDeezy's Avatar
if needed pm maxiam_kenny96. he is parting out his Maxima (I've been helping him) we can get out the ecu and/or cut the harness as needed.
make him an offer.
link to his thread.
http://forums.maxima.org/showthread.php?t=512874&page=2
Old Mar 3, 2007 | 09:09 PM
jmeister's Avatar
I got a 98 auto harness so I had to cut some wires and an fried 96 I30 ECU off ebay for $10 shipped.
Could you PM me about that apoxy fix you plan on, I'm having trouble with broken solder joints on the pins, damn leadfree solder is crap.
Old Mar 4, 2007 | 04:09 AM
eng92's Avatar
What are you using, plumbing solder?
You should be using a rosin core solder with a 63/37 tin/lead mix. 60/40 is your next best choice, but it requires more heat.
Do not rely upon other mechanical means to support poorly soldered joints. You are just asking for electrical problems down the road.
Old Mar 4, 2007 | 08:03 AM
hacim105's Avatar
Yeah I've been using rosin-core solder 60/40. I've only had one problem with a broken joint, but that's because it was one of the first ones and I didn't do a very good job on it. I've resoldered it and it holds up well.
I will PM you, I mostly want to use the epoxy fix so I have no worry whatsoever about moving the connector around with possible breakage.
Old Mar 24, 2008 | 09:49 AM
KRRZ350's Avatar
Bump to the top with a teaser pic, I've been taking pics the whole way through and will do a [small] write-up.
Anyways, I was wondering if someone that is bored could maybe help me out so I know if I am going to run into problems later tonight when I start soldering away at the 150 or so connections....
The car is a '99 a/t fed-spec harness, the ecu that I raped for the connector was a '98 i30 a/t, and the harness that I am off to the junkyard to hack is from a......... errr, doubt I'll luck out and find a '99 a/t, so it will hopefully be 96-98 a/t.
Anyways, this ecu connector from a '98 a/t, am I going to be missing pins when trying to install it on a '99? Actually, better yet, does anyone have a chart of the pinout differences between 99 and pre 99? That would be sweet, would save me some time, as you can see I've got alot of labeling ahead of me..........
Old Mar 24, 2008 | 10:04 AM
Matt93SE's Avatar
STFU n00b!
Eeeek!! how are you going to be able to trace wires when you have a problem?
there's a reason people use different colors of wire on things like this.......
Old Mar 24, 2008 | 11:03 AM
hacim105's Avatar
I don't think you'll be missing any, some pins will just be in the wrong location so you will need to move them to the correct spot. I have the FSM's on my computer at home but I'm at work right now and won't be there for quite some time.
Difficulties are not having enough space to make this job easy, so you need to learn to make good connections that aren't bulky. As you solder more connections the wires start to get in the way more. It's all mostly about space. there were a few times where I had joints break, because I didn't do a good job of soldering the first time, and then when I went to resolder it I touched another joint with the soldering gun and desoldered that joint. Just make sure you aren't using lead-free solder, and take your time. Chances are you probably won't finish tonight unless you are really good at soldering.
Old Mar 24, 2008 | 12:01 PM
nismology's Avatar
http://forums.maxima.org/showpost.ph...00&postcount=1
Old Mar 24, 2008 | 04:33 PM
MDeezy's Avatar
different colors makes it much easier, but still can get confusing if you dont focus at watch which wire your solding to which pin.
nervous part is starting the car up and seeing if all is done right
Old Mar 24, 2008 | 05:58 PM
eng92's Avatar
Or you label both ends of the wires before you start soldering. This harness is about 5ft long.
Old Mar 24, 2008 | 06:02 PM
MDeezy's Avatar
5th gen harness.... sexy...
Old Mar 24, 2008 | 06:08 PM
Puppetmaster's Avatar
That's a great idea labeling the wires AND having a pinout on the connector. Really cleanly done too. If mine turns out 1/4 as clean as that, I'll be happy. lol.
Old Mar 24, 2008 | 06:49 PM
MOHFpro90's Avatar
Agreed...eng92 that is some nice work there.
Old Mar 24, 2008 | 07:18 PM
KRRZ350's Avatar
Great work man, I also like your idea of printing out the numbers and taping them to the wires, I was planning on using neon green masking tape with one of those super fine sharpies, but I like your idea much better, and yeah that is so kick-*** with the pinouts.
lol, problems? Anyways, same way I would always trace the wires, from the pin #/location, allthough occasionally I do use the colors as a reference to double check myself, most of my diagnosis and installs regarding pin-outs to date has involved locating the pin #. Also, I didn't really feel comfortable dealing with those 108 pins, so I straightened them out, brought them to a tv/vcr repair shop, and payed $165 for them to do it. Can you imagine how much that would have cost if I had them all labeled with a chart saying, make this one this color and that one that color. Theres a reason why I'm not the only one who used the same wire colors on things like this.........
Lol, much appreciated on the link Nismology, IBI'llbehittingyouupforFSMreferencelater, but I was more so looking for a list of everything that's different, not just those that pertain to EU installs (pin44/46). Partially because it would suck if the spare harness connector I grabbed had empty slots that are used by a '99, and partially for a future project that may or may not happen, but would involve a patch harness to convert a '99 harness to a different ecu (is that even possible, I need to go read up in the grail)
Old Mar 24, 2008 | 07:32 PM
chillin014's Avatar
does anyone foresee any problems with wiring up for a 5 speed swapped 4th gen (with the 5 speed ecu) or is everyone basically just buying harnesses/ecu's from whatever they can get their hands on and only using the necessary wires
Old Mar 24, 2008 | 07:50 PM
KRRZ350's Avatar
Well if the car is A/T and you didn't use an a/t harness I believe your spare connectors would be shy a few wires, but if you were doing it for a 5-speed with an a/t harness it wouldn't affect anything, you could use an a/t harness/ecu for the spare connectors no problem. In terms of the p/n code it wouldn't really complicate much and would allow you to run the pin?? right to the engine bay even easier than the tcm harness bypass method, let me know if you want me to dig that thread up.
Old Mar 24, 2008 | 08:32 PM
RacerX1320's Avatar
Thumbs up 5th gen Harness?
I first heard this idea from BlackbirdVQ. I didnt even occur to me to think of this. Not to mention IF we were to sell our cars down the line we could easily take the EU OUT and revert back to stock.
i would DEFF be interested if you begin making these on the reg. I would get you whatever parts you needed to complete the project. Please let us know if your interested i am in NY.
Old Mar 24, 2008 | 09:24 PM
KRRZ350's Avatar
I'm interested in making more of these (I'm sure other members would as well), but they would be a little on the $teep side, you can pm me for details
RE: '99 differences.....................
I'll have a chart for anyones future reference soon enough, BUT it will be according to the FSM, and according to some the FSM is wrong, I think I can already see that in the crank sensor, I'll need to double check a few things first before saying anything definitive...........
Edited.
Old Mar 24, 2008 | 10:22 PM
KRRZ350's Avatar
Big ups for the tips, I see the light now regarding the locations that the '99 is missing and how I will have to swap over some of the spare pins on the harness side, luckily nissan included even the unused pins on the ecu board, for a brief second I thought I was screwed because those ones are molded in.
And yeah, I was hoping to at least have all the wires labeled before sleepytime, but that's not going to happen. No worries about the lead-free bs, also F the guns, I have one of those $20 radio-shack butane ones, that thing is the shiz, as well as the auto crimpers. But I can already see how space would start to be a huge concern and it will begin to become a hairy mess at the end, it's so tempting and would make it much easier if I could leave the wire long and just bundle it up afterwards. But that isn't going to happen because I want to reduce the risk of interference any way I can, that is my main and only concern with this project. It was also a concern with the guy at the electronics repair shop that did my ecu connector, I'm probably going to wrap the everliving **** out of several sensors, allthough I'm not sure if that cuts down on interference or not Anyone else have any thoughts re: interference
Old Mar 25, 2008 | 02:44 AM
Product_Of_Korea's Avatar
can you imagine how much that would have cost if I had them all labeled with a chart saying, make this one this color and that one that color. Theres a reason why I'm not the only one who used the same wire colors on things like this.........
But no 165 bucks isnt bad. im sure you can sourced cheaper though.But then again i know how much it really sucks soldering all of those. but mine looks like a beast compared to that lol. Wish i would of used new wires instead of the old *** harness wires that broke off all the time.
Even just soldering all those wires back together was a royal pia. Man i was so excited when i got all my pins done i was like ok wires will be easy. yeah they were easy just very time consuming!!!! I am seriously so sick of soldering i never want to do it again!
So how much you thinking you going to sell for(ballpark)?
Old Mar 25, 2008 | 09:29 AM
hacim105's Avatar
Wow, that is some serious wiring! But I'm glad you were able to get the job done.
When I first did the project I offered to do it for a couple guys for about $100 for the labor and then they never responded back. So I never even pursued selling my services. But I would definitely be willing to do it for anyone that is interested.
Old Apr 4, 2008 | 01:47 PM
ColdSHO's Avatar
awesome work, i was planning on doing the same thing
another way of doing it would be to just make a bypass harness at the eu end, thats what i ended up doing, for some reason all the ends going into the eu happen to be the same harnesses that are used to install aftermarket radios. i know its not the same thing, but its very easy to just pull the eu out and swap the bypass in, since everything is in my glovebox, its super easy. esp since my eu keeps eating my #6 coil.
just my $.02
Old Apr 7, 2008 | 10:06 AM
hacim105's Avatar
just my $.02
That is another idea but I think the main reason for making a this connector is so that you don't have to alter the main harness in any way. I don't believe it's all just about plug n play, at least it wasn't for me.
I had previously wired in a SAFC-II and that was by no means easy with the constricted space and with the wires so tight together. Aside from that there was one wire that I ended up having to attach an extra piece to because I accidently cut it instead of just stripping it.
So when I thought about installing the EU and all the work it would take to wire it into the car with about triple the amount of wires of the SAFC, I was not about to do that. So I made a plug n play connector to help. And I'm sure glad I did. And everything works like a charm.
Old Apr 7, 2008 | 01:36 PM
wish i could say the same for my harness
but yeah besides the plug and play features of making the harness you dont have to chop up your existing wiring like this
i have to admit thou hardwiring it in wasnt as hard as i thought it was going to be. i had to pretty much sit indian style on the ground while working on it. but i do regret hacking up my wiring but ill live
Old Apr 8, 2008 | 12:05 PM
Flava_24/7's Avatar
Boosted Panda
Okay, Im in a similiar situatuion so sorry about the thread jack. I didnt want to create another Emanage harness thread.
So my issue is this and hopefully someone can help.
I have created my own harness as well, similiar to the ones pictured above.
Now when I plugged it into the main harness and between the ecu and started the car, everything went fine. Car idled fine, and drove fine. After I drove it around for a bit I got a CEL. Pulled the code and its for EGR Temp Sensor.
Now I pulled up the pin diagram for this to see if maybe a didnt solder it correctly or etc. and its not listed.
Anyone know which one it is so I can inspect it?
Old Apr 8, 2008 | 12:26 PM
hacim105's Avatar
I first need to know what year car did you get your harness connector from and what year ECU are you using currently in your car? And what is the code # you pulled? If you can state those things I might be able to help.
Old Apr 8, 2008 | 12:42 PM
eng92's Avatar
For that code, the year does not really matter as long as it is 96-99. He would have a lot more codes if he was running a 95 harness on a 96+ ecu.
The DTC is 1401 and the pin is 63.
Old Apr 8, 2008 | 12:49 PM
hacim105's Avatar
That's true. I'm at work and don't have the resources to get all this info so quickly unless I'm at home.
I just remember that I switched from a 96 ecu to a 97 and there was one wire I had to move. But i couldn't remember what one it was so I was wondering if he had the same problem.
Old Apr 8, 2008 | 01:20 PM
Flava_24/7's Avatar
Boosted Panda
Sorry about that, Im using a 96 ECU and the harness I believe is from a 97. Not 100% sure at the moment though. It was given to me by a friend. Code was 0305
I can find out later though.
Old Apr 8, 2008 | 01:22 PM
Flava_24/7's Avatar
Boosted Panda
Hmm, I will check pin 63. Its location is pictured in the diagram but what it actually is wasnt listed.
