Sponsored by:
Sponsored by: CARiD
A few questions before i start my install...
Old Mar 8, 2007 | 06:05 PM
machinehead131's Avatar
First off i want to say that i have done a lot of research and have, for the most part, clarified a lot of the things i was unclear on. Now lets get to what i am doing and my questions:
I am installing hotshot headers, test pipe, cattman catback, and an AFC.
Here is the deal - I live in upstate NY and am worried that there are not a lot of tuner type places that can tune for me. I have found one from another org member that said he could tune.
I have come to the conclusion that the VAFC-II is better for bolt on's i/h/e and the like than the SAFC-II but am worried that they will not be able to tune with it.....
For those with experience at the dyno and tuning, when i bring my car there should i have any settings or anything set on the VAFC?
(I was planning on just doing all the wiring and installing the unit.)
When i dyno, how are they going to install the wideband o2...do they just replace one of the o2 sensors on the header for the tuning?
What questions should i ask the people at the dyno before i go to make sure they are knowledgeable enough to tune a maxima with the VAFC?
Thanks, i look forward the hours of work ahead of me and tuning!
Old Mar 8, 2007 | 06:39 PM
nismology's Avatar
http://forums.maxima.org/forumdisplay.php?f=10 or http://forums.maxima.org/forumdisplay.php?f=48 or http://forums.maxima.org/forumdisplay.php?f=15
Old Mar 8, 2007 | 07:24 PM
i have already looked through a lot of that stuff i am looking for more clarification than anything.
Old Mar 8, 2007 | 08:29 PM
95BLKMAX's Avatar
Check on nycmaximas.org to see who can do tuning for you.
How did you come to the conclusion that the VAFC2 is better than the SAFC2? As far as I know the only difference is the V has the extra output for VTEC (or VIs) but its useless to you because your ECU opens/ closes your VI.
Dont go to the dyno with corrections made already. You dont have a wideband and thus you have no clue where your a/f ratio is.
Most dynos use a sniffer-type wideband. They stick it right up the tailpipe.
No idea what to ask them. I do the tuning myself.
Hope that helps somewhat
Old Mar 8, 2007 | 08:32 PM
yes that was more informative thank you....i have read several times the vAFC provides a better tune because of the 24 points as opposed to the 12 points.
Old Mar 8, 2007 | 08:44 PM
nismology's Avatar
My point was that the subject matter isn't appropriate in this forum and your question(s) could be answered in the general discussion forums.
Old Mar 8, 2007 | 08:54 PM
95BLKMAX's Avatar
I dont know why people make a big deal about the # of points.
To me, the only time 24 correction point are needed is if you have an EXTREMLY irratic a/f that is all over the place and changing frequently.
I have an SAFC1 with only 8pts and notice my a/f --> http://forums.maxima.org/showthread.php?t=511885. Its nice and flat.
Do people think that the SAFC1 doesnt make corrections in between the points? Is that why they think more points is better? The SAFC interpulated the correction in between its points. I dont see a need at all to have more than 8pts for tuning. At least not with a stable a/f that 99% of maximas tend to have
Old Mar 8, 2007 | 09:05 PM
From what i see in the 5th gen forum everyone says to go to the motor forum......
Thank you for the info
Old Mar 8, 2007 | 09:06 PM
So a SAFC-II would be a better bet??
Old Mar 8, 2007 | 09:13 PM
95BLKMAX's Avatar
its not that its any better man, its just that theres no need for 24 points when I can tune my a/f perfectly with only 8pts. Thats just more crap to adjust when tuning in my eyes, lol. and plus you have no need for the extra "vtec" signal output, so why bother? For your particular needs, I'd stick to the SAFC2 and call it a day.
Old Mar 9, 2007 | 06:03 AM
Well i was looking on ebay today and found the neo for 270 new..the same price as the SAFC-II, mine as well get that right?
Old Mar 9, 2007 | 08:28 AM
95BLKMAX's Avatar
sigh, do what you want, lol
Old Mar 9, 2007 | 08:37 AM
yea lol, well its the same price you know...
Old Mar 10, 2007 | 06:50 AM
speed racer's Avatar
When you go to the dyno shop ask them if they have a wideband 02 so that they could put it in the test pipe. This will allow you to look at the A/F curve. But if they only have a tail sniffer than you should be looking at the graph. As you lean out at various rpms you will see that the torque will increase. As soon as you see the torque drop than you add more fuel. That is your optimum torque. Just be careful with the tail sniffer b/c its known to show A/F readings fairly lean.
Old Mar 12, 2007 | 08:46 AM
okay, i talked to the guy that i think i am going to go to and he said if i have a cat then he has to use the wideband but i dont then he can use the tail sniffer, from experience would i get a better tune with the wideband and can he just put it in the headers bung while he tunes then just put the o2 back in?
-or does the wideband need to be like in a test pipe?
Old Mar 12, 2007 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
The 6000RPM 'go blind' thing really gets annoying.
That's your best bet.
Old Mar 12, 2007 | 09:46 AM
if you put the wb in the headers that means your getting readings from only one bank. Not good. You need readings from both banks therefore it has to be at the collector or the test pipe.
Old Mar 12, 2007 | 11:22 AM
Looks like ill have it in the test pipe - but what happens when i leave is there something i plug it up with?
Old Mar 12, 2007 | 11:37 AM
NmexMAX's Avatar
dot dot dot ...
There are plugs you can buy for ~ 8$ or so. --> O2 sensor bung plugs
Old Mar 12, 2007 | 11:54 AM
thanks NmexMAX - does anyone know if the wiring is the same for the NEO as it is for the SAFC or VAFC?
Old Mar 12, 2007 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
There's no reason why it would be any different sinceyou're after the same signals.
Old Mar 12, 2007 | 12:35 PM
I should expect somewhere between 15-20whp with I/H/E? - Cattman catback with a test pipe
Old Mar 12, 2007 | 12:43 PM
NmexMAX's Avatar
dot dot dot ...
Dyno and find out.
Old Mar 12, 2007 | 01:14 PM
I will i was just going on what i have seen - ill get the dynos but wont have a base dyno so i wont know exactly what i gained.
Old Mar 12, 2007 | 01:19 PM
NmexMAX's Avatar
dot dot dot ...
Should be good for up to 30+ fwhp IMO. It has been done w/ the mods you mentioned coupled w/ a decent tune and some good fuel. But let's not get into that guessing game. get a dyno and see what good comes of it.
Old Mar 12, 2007 | 04:25 PM
Okay, thats awesome i only run 93+ so should be able to hit some nice numbers.
Old Mar 16, 2007 | 04:35 PM
Does anyone have pictures of the ECU and wiring for the VAFC-II Install.
Old Mar 16, 2007 | 04:54 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...postcount=1441
Old Mar 16, 2007 | 05:10 PM
You must get angry, i don't know how i am oblivious to these things. Thank you.
Old Mar 16, 2007 | 05:14 PM
NmexMAX's Avatar
dot dot dot ...
Nope, I like what you're doing and willing to learn.
Old Mar 16, 2007 | 06:39 PM
You da man thanks.
Sport
Jul 3, 2017 05:40 PM
rbuswell
Nov 17, 2016 04:54 AM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
Jcof88
Aug 3, 2015 10:43 PM
