Sponsored by:
Sponsored by: CARiD
00VI, JWT ecu and VAFCII question
Old Mar 21, 2007 | 10:51 AM
cardana24's Avatar
Blown
I am putting an 00VI on my 95 maxima. I have printed out Jime's wiring instructions for a SAFCII...from what I have found these are the same instructions I can use for the VAFCII...is this correct? Also, which wire do I hook to VAIS on the 00VI? Finally I am planning on using 5th gen injectors in the rear so this will make my car run a little rich. I am running a JWT ecu and I would like to be able to make fuel corrections on the VAFC to correct the rich sitiuation that would be cause from the larger injectors. Can this work? From what I have read some people said it would not help anything and others said that it should not be done since JWT has adjusted the timing in there program. Any help you can give me with this sitiuation is appreciated.
Old Mar 21, 2007 | 11:24 AM
NmexMAX's Avatar
dot dot dot ...
Yes.
Can this work?
Yes.
Old Mar 21, 2007 | 12:53 PM
cardana24's Avatar
Blown
Originally Posted by NmexMAX
Yes.
Yes.
so the JWT ecu will not over ride corrections made? Which wire do I hook to the manifold? Thanks for your help.
Old Mar 21, 2007 | 01:12 PM
NmexMAX's Avatar
dot dot dot ...
There are other threads, but this one proves it just as good as any other.
http://forums.maxima.org/showthread.php?t=385141
VAFC wire color: Pink
http://forums.maxima.org/showpost.ph...68&postcount=2
Old Mar 21, 2007 | 02:22 PM
jmeister's Avatar
Old Mar 21, 2007 | 02:36 PM
95BLKMAX's Avatar
I dont think its a good idea to run two different size injectors for each bank of the engine. You'll have uneven mixtures bet'n the two banks. I would just either stick to all 4th gen injectors, or all 5th gen injectors.
But even so, why change the injectors for the purpose of running richer? Thats what the VAFC if for
Old Mar 21, 2007 | 02:55 PM
jmeister's Avatar
He won't be able to anyways...
Wondering if he meant 5th gen coils in the rear
Old Mar 21, 2007 | 03:18 PM
tsaulz's Avatar
Pretty sure that is what he means, in which case he shouldn't have any problems.
Old Mar 21, 2007 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
Damnit. I didn't catch that. VAFC will only control MAF signal, and not injector pulse.
EU can control injectors, don't do it. Jut find 3 cheap like injectors.
Old Mar 21, 2007 | 04:21 PM
Jason R's Avatar
aka UNCDooD
yes he will be using 5th gen rear coilpacks and all 6 5th gen injectors. Carson you could've just asked me which wire to hook up to the VIAS from the VAFC.
Old Mar 21, 2007 | 04:47 PM
NmexMAX's Avatar
dot dot dot ...
Yeah Carson, ask Jason next time.
Glad things will work out. It will be an interesting dyno.
Old Mar 21, 2007 | 07:33 PM
Jason R's Avatar
aka UNCDooD
this guy has good advice.
haha but yea he is buying the stuff from me (for a sweet deal might i add) and i had it up and running on my car, which the idle is still messed up on.
Ps- Carson, I didn't get a tracking number when i shipped out that VAFC but it will be there sometime tomorrow. sorry about that.
Old Mar 21, 2007 | 08:35 PM
4x4Max's Avatar
just remember there's no 'knock sensor' wire hookup needed
Old Mar 22, 2007 | 05:12 AM
cardana24's Avatar
Blown
hahahahha....sorry I get bored at work and start asking questions But I did really want to know about tuning with a VAFC while using a JWT ecu.
Thanks for all the advice
Old Mar 23, 2007 | 08:51 PM
aznsap's Avatar
should be able to do it. i have the vafc hooked up and a jwt ecu, but i still have my maf wire unspliced...... i'll wait until i actually have time to mess w/ the vafc and tune before i do that.
Old Mar 26, 2007 | 06:01 AM
cardana24's Avatar
Blown
the vafc is now in the car and the car is still running so that's a good sign. Hopefully the 00VI will be on next weekend and I can start tuning. Does anyone have recomended settings for the VAFC (i.e. minus what percentage to comensate for the larger injectors) that could get my by until I get to the dyno?
Old Mar 26, 2007 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
It's best not to play w/ those parameters until you have an accurate away of reading AFR.
Have you looked into getting a wb?
Old Mar 26, 2007 | 07:45 AM
cardana24's Avatar
Blown
No but I probably should since I have two maximas that will require tuning. Any advice on which ones to look at?
Old Mar 26, 2007 | 08:19 AM
goldtooth's Avatar
i have a Zeitronix zt-2.....
Old Mar 26, 2007 | 08:54 AM
NmexMAX's Avatar
dot dot dot ...
Plx R300 .
t6378tp
Sep 29, 2018 04:27 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
