Sponsored by:
Sponsored by: CARiD
Help with my 3.5 swap....
Old Apr 12, 2007 | 09:52 AM
  #81
Maximus_95's Avatar
huhm....interesting...
the only reason i ask its because for some odd reason, my FPR is not doing its job.
With the car in idle, i tried adjusting the FPR but there was no difference no matter how i adjust it. So i thought about adjusting it with the car off.
Still no matter how i adjust it, it goes to 65psi once, and when i adjust it again, it goes to 41psi. It only gets those 2 pressures and this is after 2 FPR's i bought. (SARD) first one i bought is used, and the second i bought was brand new....
Im not sure if there is something with the FPR itself, but im starting to think that it is my gauge that may be broken... im going to buy another gauge today and see if that works.
Any SARD user's out there?
Old Apr 12, 2007 | 02:48 PM
  #82
scrhale's Avatar
I am pretty sure SARD is recognized as the Hyundai of FPRs ... needs a 100K warrenty cause it is always fu&^%d up lol.
Old Apr 12, 2007 | 08:27 PM
  #83
Maximus_95's Avatar
alright guys....
i was looking in the H. Manual, and it was stating that our fuel pump from the 4th gen maxima puts out a fuel pressure of 43psi.
that's exacty what i am getting right now, and no matter what i do, i cannot get my Fuel pressure to be at 51psi.
right now, im getting around 41-43 psi on idle.... is it ok for me to drive on that pressure?
Old Apr 13, 2007 | 04:49 PM
  #84
GoalieKeg's Avatar
Originally Posted by Maximus_95
alright guys....
YGPM mang....
Old Apr 13, 2007 | 11:40 PM
  #85
Maximus_95's Avatar
wow....ok guys.... i finally got my car rolling today... but just before i thought i was completely done, i ran into a problem...
Ok, here's the story.... hopefully someone can help.
I put my car into 1st gear, start to engage the clutch, and it fully engages.
now when i start driving the car, once i hit the 10mph mark, car seems to just hop suddenly, like i ran over some unexpected huge piece of log..... so i tried shifting to 2nd before it does that, and it shifts no problem...
Only happens when i hit about 10mph on first gear....
-I also realize that the pressure on my clutch is not as it used to be, its a little soft about 30% when i step on the clutch then i get pressure, even though i bled it a bunch of times, its still the same. From what i remember, i think i have to drive around a while to completely build pressure i think...
has anyone had this problem?
any idead what it may be?
thanx guys..
Peter
Old Apr 14, 2007 | 01:54 AM
  #86
KRRZ350's Avatar
sounds like something is hooribly askew, possibly a PP or flywheel problem, you're probably going to have to pull the tranny, if it's something else like axles or mounts you'll notice it along the way, that's my vote. But double and trible check for any hydraulic problems first.
Old Apr 14, 2007 | 03:53 PM
  #87
2ndcoming's Avatar
Old Apr 14, 2007 | 08:07 PM
  #88
Maximus_95's Avatar
does anyone know if it may be a tps problem?
anybody have a link on how to check it and to recalibrate it?
im guessing it could be that..... thanx.
Old Apr 15, 2007 | 12:56 PM
  #89
MDeezy's Avatar
thanx guys..
Peter
I might have missed it, but what kind of clutch are you using? is it a clutch your re-using or brand new?
After you ran over the log, did you inspect for damages.
if you have the haynes manual it instruct you how to set the TPS.
With my VAFCII I adjusted the TPS to read 4v at full throttle and ~.5 volts at Zero throttle.
Old Apr 15, 2007 | 03:38 PM
  #90
JeEvE's Avatar
How do you have the throttle cable set up? Any pics of it?
Old Apr 15, 2007 | 07:30 PM
  #91
Maximus_95's Avatar
sorry, i dont have pics right now, but the throtle cable is hooked up to the intake manifold, not to the firewall or anything.
-MDeezy, i did not run over a log, the feeling is like i ran over a huge log.
My car just kicks like i let off the accelerator and all of a sudden hammered it to the ground. That's the feeling i get, but after that, its smooth but then it happens again...
This is so confusing....
you guys think it may have something to do with the tps?
Old Apr 15, 2007 | 07:50 PM
  #92
Nismo3112's Avatar
Custom User Title
I had something like this happen to my 95 I just bought. But it was worse than you describe. The car bucked like crazy in first gear and even in the other gears at RPM's below 2000.
It was a loose positive battery cable.
Old Apr 15, 2007 | 08:19 PM
  #93
Maximus_95's Avatar
are you serious? a loose battery could do that? i suppose i could check it out. thanx....
anyone else?
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
MaxRPM6
Sep 11, 2015 06:56 PM
JoshG
Sep 5, 2015 10:10 PM
