first of all
second of all let me explain. I held the key to start it and i got that ticking which i think was the fuel pump pressurizing the system? Then when it was done i tried starting multiple times and it would sound like it was going to start but it just didnt the starter would give a VERY short cranking noise but no continuation. It doesnt sound like it even turned.
As far as connections, there is one spot on the firewall near the transmission where a ground was connected on like a foot long wire and i dont have that plugged in because i dont remember where it connected to. ALSO there is a green harness connector that is loose coming off of the same area as the knock sensor connection.
i tried putting in my friends battery and the car was acting really weird, everything was flickering on and off. I put my battery back in and it acted normal, all electronics turned on. I tried to start it a couple more times and then it started acting weird again with the flickering.
please help...this is real discouraging.
Quote:
So one end goes to the tranny and the other end goes?
its screwed straight into the firewall and the other end is just a loose connector. i dont know where it went...i cant find a spot for it to connect.Originally Posted by Kevlo911
Fix that ground and see what happens. So one end goes to the tranny and the other end goes?
holy crap i had almost this exact same problem. i just cleaned the batt terminals and it went away.
the battery was getting really hot. I dont think its the terminals i mean...all the electronics worked fine...
anyone think its a jammed starter gear?
tavarish said that ground wire isnt needed. gonna go take a pic of that other loose connector
I took the starter out a little bit and put it back in just to make sure it wasnt a jammed gear.
here's a picture of the connector that isnt connected.
it wants to start...it really does.
Originally Posted by chillin014
I took the starter out a little bit and put it back in just to make sure it wasnt a jammed gear.here's a picture of the connector that isnt connected.
that plug goes to a sensor located on the VQ30 coolant log, it reads either coolant temp or vac cant recall at the moment
Quote:
i thought you fixed yours though? Originally Posted by MAXSE5SPD
same here, both our ruby pearl 95 4.5 gens wanna start.
and gtr rider i dont need that to be connected anywhere, right?
Quote:
nope not yet. Originally Posted by chillin014
im getting my ds axle tomorrow then i gotta get the car running.Quote:
oh yeah? i just hate this clueless sh*t. if i knew what the problem was i'd be on it in an instant...Originally Posted by MAXSE5SPD
nope not yet.
getting my starter tested tomorrow.
Quote:
i donno, theres no spot for it to connect to that i can see, all the coolant line plugs are plugged in.Originally Posted by Kevlo911
If it is the ECTS you need it connected.
Quote:
Any cels?
ive got alot im sure, i'll check them tomorrow though i've called it quits for today.Originally Posted by Kevlo911
Actually the ECTS is a single pin connector IIRC. ha Any cels?
If this is the connector that is connected to the knock sensor, I believe you dont need it.... Well what I actually did was remove the 3.5 knock sensor and install the 3.0 knock sensor, just in case the 3.5 knock sensor needed that connector to function.Originally Posted by chillin014
Your right, I remember now.
Quote:
Originally Posted by Nismo3112
IIRC, the only green plug on THT's car and my car was for the EGR solenoid valve.
alll im getting is clicking in the engine bay after buying a new starter, the old starter failed tests at autozone the first time he tried it the wheel didnt even spin...the 2nd time it did though...
spent 140 on a new starter cause i'm in a panic
If you getting a clicking noise when you flick the ignition switch, your electircal is not grounded right. Check the alternator and its grounds, the starter's ground.
The starter is grounded to the block via the engine/tranny mating surfaces. The car should start even with no alternator hooked up.
Actually, my car had a similar problem... On the day we got it going, we drove aroud the block, came back, turned it off, and then when we tried to start it again, it just made a clicking noise.... and the alternator's connection was loose. We secured it, and the thing started up.
i re did my negative cable grounds and no change. I found out the alternator wasnt connected and connected the power and then attached the ground-bracket as well. No change to the starting situation.
there is just rapid clicking in the engine bay...it no longer sounds like the starter is trying to start or starting at all like it was before. I am extremely eager to figure out what the problem is so i can return the starter since it doesnt seem to be the problem.
i'm getting stressed.
its weird yall mention that because hte alternator WAS DISCONNECTED. but now it is and there is no difference in the situation. Where does the alternator grounding bracket attach to? i just screwed it into one of the screws on the alternator bracket. next to the timing case..
guys listen to this. Remember that loose ground wire i was talking about? Well on the new starter i bought there was one of those little single connectors on it that that wire could connect right to. Welll i connected it to it just playing around and when i try to start now i get NO CLICKING. The gauge lights just dim and thats it. Does this mean my starter needs to be grounded better?
this is a nightmare...i recharged my battery and tried starting again (didnt groudn the starter better yet) and now its acting like theres no power at all, the lights are very dim when the key is in the "ON" position..
Quote:
i recharged it again, and tried to start and the starter spun!!! it sounds really whiney though....i let off and tried cranking again and it sounded like the starter spun again. When i tried for the 3rd time its like hte battery lost juice because everyting got real dim and weak and solenoids were buzzing again.Originally Posted by 915Max
Check the battery, make sure it has juice.
im recharging the battery again...but it cant hold a charge apparently...i hope the car starts..
okay who knows how i fixed the problem, but the car starts and even idles. i have a big vacuum leak to fix as well my fpr problem but that should, hopefully be it.
haha shut up. and for your information my good friend (a fellow orger) came over and let me borrow his which lasted through multiple cranking sessions.
but anyway...!
but anyway...!
damn man...you gotta move here its the ****. i appreciate your help, and everyone else who posted in the thread or helped me otherwise. yall arent off the hook yet though haha.
Quote:
but anyway...!
haha shut up. and for your information my good friend (a fellow orger) came over and let me borrow his which lasted through multiple cranking sessions. but anyway...!
i took apart the fpr to make sure the gasket was on there right, and it looked to be, i put it back together and installed it and its still reading zero on the gauge. I know its important to have the proper fuel pressure but i can drive the car, i am just wondering how bad it is to drive with the fuel pressure so low?
also, my brake booster seems to act a little funny or something...my brakes will lose pressure and then gain it back after revving. somethin must be leakin?
