Sponsored by:
Sponsored by: CARiD
Vq30 sleeves?
Old Apr 10, 2007 | 09:26 PM
Scottyboi's Avatar
Vq30 sleeves?
Just woundering if they make these for this motor? Since i am dropping it in.
Old Apr 11, 2007 | 07:12 AM
95BLKMAX's Avatar
Im assuming you're asking about aftermarket sleeves... not that Im aware of. The VQ35 has quite a few companies that make sleeves for it, never heard of any for the 3.0.
How much are you planning to boost the VQ30 anyways? With a good tune on ignition and fuel, the stock motor can take 12psi all day, and 15psi is not common but its been done before. What are your goals for this swap?
Old Apr 11, 2007 | 07:48 AM
SR20DEN's Avatar
VQ Wizard
The Darton VQ35 sleeves will most likely work.
Old Apr 11, 2007 | 06:53 PM
Scottyboi's Avatar
Well at 1st i was just gonna do the vq35 swap...changed my mind...got the vq30 boosted...then built it...but i dont know...maybe that will be it...maybe not...depends on whats out for this motor...
wanna post some links to some turbo cams...injectors...fuel pump...anything really.
My wireless is out so im on 56k
Old Apr 12, 2007 | 04:25 PM
JClaw's Avatar
I actually e-mailed them about it and the guy would not do it. He told me about the blocks having different castings and whatnot. I know it SHOULD work, but thats what they told me.
And if you are going to build a VQ30, you should trust the factory sleeves, and destroke a VQ35 with VQ30DET crank and rods. The VQ32 using forged VQ30DET stuff WILL hold as much power as you would possibly want to throw at it, WITH all the benefits of the VQ35 heads and lower compression. It is the cheapest, less risky and most efficient way of doing it.
And that way you can slowly build the VQ35 while your old VQ30 is still in your car running.
Junkyard VQ35 = 600-800$
VQ30DET crank = 500$ (online)
VQ30DET rods = 700-1000$
Then ARP crank case & Head studs + HKS Headgasket = not sure exactly but it cant be that steep
Old Apr 12, 2007 | 05:54 PM
Nealoc187's Avatar
SLOW
Is the DET crank different than the 30DE crank? Actually as I type this I think I'm remembering that the DET has larger main bearings or rod bearings or something?
Old Apr 12, 2007 | 05:59 PM
SR20DEN's Avatar
VQ Wizard
He didn't ask that.
Old Apr 12, 2007 | 06:09 PM
JClaw's Avatar
True just trying to steer him in a better direction. Least he knows his options. His call.
Old Apr 12, 2007 | 06:44 PM
Scottyboi's Avatar
Thats true thanks for your info..
I think the guy doing my car ended up putting a vq30det crank and internals..
DBear
Sep 14, 2015 08:33 PM
A32goldylocks
Sep 14, 2015 06:49 PM
rtb
Feb 8, 2002 01:58 PM
njmaxseltd
60
Oct 19, 2001 08:53 AM
