Sponsored by:
Sponsored by: CARiD
OK! Whats going on with my car?
Old May 4, 2007 | 11:10 PM
ghostmax301's Avatar
Last year, when i ran my car, with just a warpspeed y, it ran a 15.01 @ 94 PB. Now, I have a WORKING 00vi with NO vaccum leaks added to it and i just lost a "foot" race to a stock 2001 5spd with 3 passengers and a stock auto 4th gen. The 5th gen's PB was a 15.7 i believe. At this point, my tranny is slipping.
1-2 is fine,
2-3 revs extra 1500rpm then shifts, 3-4, same as 2-3.
at idle, or coming out of "D" into neutral or park, the torque converter makes a spooling noise, Like a jet getting ready to take off
if i rev the car in Neutral, it moves foward a little like it's stuck 1/4 way in drive, on it decels it rocks back like its resting again..WTF?
I have a CEL for bank 2 sensor 1(which 1 is that? by the firewall?) and for the sensor in the cat.
I have no AFC tune
The car backfires, pop's and "gargles" alot
I dont have a CEL for the knock sensor but could it still be bad?
Could those above problems cause my car to go from a 15.0 to a 15.7+ car?
Someone please help me, thanks
Aaron
Old May 4, 2007 | 11:14 PM
also, besides a Vaccum leak or a no working VIAS, what else can go wrong with a 00vi swap...there is a few kinks in the travel tube of the fuel rail(the tube going from the front injector rail side, to the back rail. I managed to get the kinks out but the tube is still kind of "lumpy" would this be a problem?
Old May 5, 2007 | 04:36 AM
KRRZ350's Avatar
What are your exact code numbers? Very simple test to check for a clogged cat if you have a vacuum gauge. Warm car up to operating temp, shut car off and wait a few seconds, start it up and note vacuum reading as soon as it settles, let it idle for a minute and make sure vacuum reading doesn't drop slowly, race the engine a few times and make sure that after it settles it isn't dropping.
Old May 5, 2007 | 06:48 AM
Tatanko's Avatar
Bacon Lover
You're not the only one mildly disappointed. I'm not disappointed in the swap, though, I'm disappointed in my car in general. I'm definitely going to the wrong drag strip for personal best times, though
I can drop .6 off my ET just by making the VIAS work properly or not at the track (and yes, the conditions were identical, my 60 foot was almost exactly the same, even). I would try something like that. Go to the track sometime, set your VIAS to open at something crazy like 1000 RPM and do a run, then do a run with a 5000 RPM setting. See if it's doing it's job. If not, something besides the 00VI is wrong.
Fuel filter good? Air filter? I'd maybe check those fuel lines out again as well.
Old May 5, 2007 | 07:25 AM
renman's Avatar
Your knock wont throw a CEL, its a ghost code. It wont turn on the warning light.
Old May 5, 2007 | 11:30 AM
NmexMAX's Avatar
dot dot dot ...
This thread doesn't belong in here.
First off:
1.) Gather codes, fix them
2.) Get a new tranny (www.carpart.com) either a swap (MT) or direct transplant (AT) are in order.
Old May 5, 2007 | 09:13 PM
First off:
Not to spark feelings but, why wouldnt it? its a "all-motor" related problem. Ive CHECKED for codes, none related to my problem(VSS / EVAP) and im obviously trying to figure out if there might be other things wrong besides the tranny. So thanks for the notice Mr. Cellphone Holster Wearer
To the other replys, Ill try that method of vaccum checking tomorrow and change out my fuel filter(i have some reasons to possibly knowing it's clogged)
As for the track method, On my way home from work today, NORMAL driving. I approach a light after about 5mins of driving. Leave the light and car doesnt go past 2nd gear, clutchs are gone in 3rd and 4th now.. so it'll have alot of free time in the next few days to get a few check ups
Old May 6, 2007 | 07:43 AM
Tatanko's Avatar
Bacon Lover
VLSD auto or 5-speed time
Old May 6, 2007 | 08:57 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=345112
Change it.
I have the same problem on my A32. Change tranny
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
yat70458
Aug 3, 2015 01:16 PM
