Sponsored by:
Sponsored by: CARiD
HKS Pistons and Connecting Rods... can they work our swaps?
Old May 14, 2007 | 11:41 PM
NismoMaxman2's Avatar
The only 4.5 gen in da 956
I tried searching around the org for this questions, but I guess I wasnt placing the words correctly, to get any good results...
If someone had the money to build a very good N/A motor, would these be possible to use? I see alot people stating that 350z internals are the same as Maxima internals and that of course almost anything offered for the 350z can be used in our motor, hence there the same engine except ones RWD and the other is FWD.
http://www.hksusa.com/products/?id=3023&rsku=6139
also how bout this Plenum Spacer.. I've seen someone on here who used the 350z IM, would this/could this be used if we went with the 350z IM???
http://www.sfxperformance.com/parts/SK2307070400.htm
so i'm pretty sure this isnt new... but has anyone tried any of these parts? I know some of the gear heads on this forum, can dish out some thoughts on these upgrades...and if there worth it or not.
Raul
Old May 14, 2007 | 11:53 PM
nismology's Avatar
@ $3700.00 for pistons and rods. Many other cheaper options. What are you goals, first of all?
Old May 15, 2007 | 12:13 AM
My goals;
Goal #1 just do the 3.5swap
Goal #2 mod and tune to run either Meximax setup with Nitrous w/100shot... or JIME's all motor setup and run some high 12's NA,
But the question for the post, if money wasnt a option... "ok ok,, I know it sounds like a wish list" but are these even worth it? I know they offer cheaper alternatives... but anyone using aftermarket pistons and rods yet in there 3.5swaps??? If so what are the gains...
Raul
Old May 15, 2007 | 12:29 AM
found a similar link... i think this might somewhat answer my questions... thanks Nismology
Old May 15, 2007 | 06:49 AM
NmexMAX's Avatar
dot dot dot ...
Raul
I wouldn't say there are any WHP 'gains' if you stick w/stock sized pistons. They would only be expensive insurance.
Old May 15, 2007 | 07:46 AM
nismology's Avatar
My goals;
Raul
No one with a 3.5 swap has gone with aftermarket internals, to date. Aftermarket rods aren't necessary IMO unless you plan on revving to 8000 RPM and beyond on a regular basis. The pistons i'd get only if i wanted high compression or low-compression for boost. BTW, you can run nitrous safely and successfully on a high compression motor, but the tuning needs to be a little more conservative. Either way, a must-have component at the very least are ARP rod bolts.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 16, 2015 05:09 PM
Blackwind
Aug 5, 2015 06:35 PM
kenc15
Aug 5, 2015 08:29 AM
