Sponsored by:
Sponsored by: CARiD
3.5 swap, Cam drilling
Old May 14, 2007 | 06:37 PM
danman700's Avatar
I am at the point on my swap where I should be drilling new holes for dowel pins. I am using 3.5 cams, and have the spacers made by stevenmax, I was trying to figure out what needs to be done here and they seem like nothing would need to be drilled? I went back to the writeup on the org and I am a bit confused, I just want to be correct and not have to take this apart again, If i used 3.0 cams, I'd have to drill new dowel holes, but sense I am using 3.5 cams with spacers I will not have to drill them? If anyone has clairification I'd appreicate
Old May 14, 2007 | 06:41 PM
danman700's Avatar
haha, I am getting tired and stupid, I see now that you must reposition where my cam spacer dowl pin will go into the cam so that the pin on the other side is where the hole is now...right?
Old May 14, 2007 | 06:56 PM
Nismo3112's Avatar
Custom User Title
Wooooooooooooooooooo
Ok.
If you use 3.0 cams your power will suffer but you will need nothing.
If you use 3.5 cams you will need EITHER drilled cams/spacers OR cam adapters.
I'd get some adapters... No drilling required.
Old May 14, 2007 | 07:08 PM
danman700's Avatar
wow, I need to figure out what i've got. I was under the impression it was spacers but maybe I am wrong..
Old May 14, 2007 | 08:42 PM
SDot82's Avatar
those are adaptors and no drilling is required.
Old May 15, 2007 | 12:00 AM
SpeedCrazie's Avatar
Stupid Question im sure but if you have those adapters do you still need the JWT spacers?
Old May 15, 2007 | 12:59 AM
D-Bo's Avatar
Droppin logs
JP- IIRC those are StephenMax's alternative to the JWT cam spacers. So short answer, no.
From all your posting here it looks like you made up your mind (re post on NWMaxima) I would definitely come to a work meet for this project
Old May 15, 2007 | 06:22 AM
TDotMax's Avatar
What degree did you get the adaptors made at?
Old May 15, 2007 | 11:35 AM
95naSTA's Avatar
I had spacers made for abci30's swap and I still have some sets left over.
I can also do cam drilling.
Pm me if your interested.
Old May 15, 2007 | 12:39 PM
Kevlo911's Avatar
Kevlo for President
Those are worth 100 bucks
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
