Sponsored by:
Sponsored by: CARiD
anyone with a 5speed swap figure out how to get rid of code 1003
Old Nov 26, 2007 | 06:39 PM
  #41
A33 VQ30DEK's Avatar
if this were a 5th gen would i wire from pin 22 or 27?
Old Nov 29, 2007 | 09:23 PM
  #42
KRRZ350's Avatar
Neither, It's pin #44 according to the 2000 fsm. Also, it looks like you have it much easier. Ground the B wire on 5-speed p/n switch (which you need to do anyways) Than simply connect the unused auto G/OR wire to the G/W wire (the thinner one IIRC) on the 5-speen r/n switch.
Old Nov 29, 2007 | 11:40 PM
  #43
THANKS!
Old Dec 3, 2007 | 07:00 PM
  #44
does anyone know if you have to drill through the firewall to wire it up... or how did you guys go upon wire this up... where did the route the wires to?
Old Dec 3, 2007 | 07:44 PM
  #45
aznsap's Avatar
don't need to drill. thats why you use a wire that runs to your tcu which is inside the car.
Old Dec 3, 2007 | 09:07 PM
  #46
you mean the ecu?but the P/N switch is outside located on the transmission
Old Dec 5, 2007 | 12:30 AM
  #47
KRRZ350's Avatar
Reread post # 42, you already have a wire under the hood that goes directly to the required ecu pin. For a 5th Gen all the info about running wires OR doing the TCM re-route method is irrelevant,
Old Feb 10, 2008 | 11:44 AM
  #48
KRRZ350, tried wiring it up, but code p1003 still shows up. Maybe i wired incorrectly... any insight?
Old Feb 10, 2008 | 11:46 AM
  #49
B for black correct? G/W for green and white? and G/OR for Green and Orange?
mvm062
Nov 30, 2020 09:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
trungg86
Sep 4, 2015 04:58 AM
Lowered_a33
Sep 1, 2015 07:49 PM
