Sponsored by:
Sponsored by: CARiD
RPM signal for mevi on 99 max
Old Jun 20, 2007 | 12:38 PM
96sleepergle's Avatar
cant find an rpm signal for the mevi on a 99 maxima it seems to be different than my 96 i had.
Old Jun 20, 2007 | 01:07 PM
nismology's Avatar
What's your question, exactly?
Old Jun 20, 2007 | 01:14 PM
DandyMax's Avatar
3.5 in the works
The FSM says it's a W/G colored wire on pin 5 at the ECU and terminal 3 on the gauge cluster, just like the previous years. The 99 FSM is known to have mistakes though...
Old Jun 20, 2007 | 01:53 PM
I followed the various charts/diagrams floating around the org. I have a 99, and it was the same color as described for older years. Per the writeups/diagrams, I tapped the grey w/ red stripe coil wire for cylinder 6.......
By doing it this way, you don't need to run a wire into the cabin to get to the ECU.
Old Jun 20, 2007 | 04:59 PM
thanks just on the 96 dash board (cluster) on the rear theres a screw that says tam thats where i wired the rpm switch to to get the signal for 96 models but on the 99's theres no screw just didnt want to tap into the ecu wire(cutting into it) but have no choice now thanks
yes 99 fsm have mistakes that i discovered
Old Jun 20, 2007 | 06:43 PM
nismology's Avatar
Originally Posted by 96sleepergle
thanks just on the 96 dash board on the rear theres a screw that says tam thats where i wired the rmp switch to to get the signal for 96 models but on the 99's theres no screw just didnt want to tap into the ecu wire but have no choice now thanks
Old Jun 20, 2007 | 08:03 PM
your point?? question answered already
Old Jun 20, 2007 | 08:51 PM
nismology's Avatar
First off, please check your attitude at the door.
You said you don't have a choice but to tap into the ECU wire in the cabin when in reality you don't have to. You can tap into the coil wire under the hood. I was trying to help.
captchaos
Mar 15, 2016 12:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
Maxxx10
Sep 13, 2015 03:16 PM
