Sponsored by:
Sponsored by: CARiD
What are these wires coming out of my JWT ECU?
Old Jun 27, 2007 | 01:07 PM
95maxrider's Avatar
Lightly modded
Today I went to swap out my JWT modified Maxima ECU (with NITROUS)and put in my stock I30 ECU for emissions testing. The Maxima ECU throws all sorts of emissions codes, so it doesn't pass the tests. I did this same process two years ago without a hitch. However, something was different this time around.
Now there are 3-4 wires coming out the back of the ECU, which I don't remember seeing before. One appears to be a ground, another appears to be related to my Harlan RPM switch(gray wire), and then there are two other wires, a blue and a red one.
The red and blue wires are thin coming out of the ECU, then there's a connector of some sort, then there are another red and blue wire, although these are thicker than the other R/B wires coming from the ECU.
There are a few possibilities for the R/B wires off the top of my head:
1. I had some fake A/F gauge that I replaced with a real WB O2 sensor. IIRC, we tapped into some wires to get a signal for it, but now that I'm using a real WB O2 sensor, the old gauge is not in the car. I'm going to ask the installer if he remembers how he did the install.
2. Wires put there by JWT for nitrous purposes. I didn't do my nitrous install myself, but I believe those wires may be used to arm my system and switch over to my nitrous program.
3. Possibly wires for my WB O2 sensor? I kind of doubt this, but it's a possibility. I thought the only wiring for the WB went directly to the sensor in the exhaust, but I could be wrong. Do most WB's need a connection to the ECU?
What this all boils down to is I need to put in my stock ECU, but I'm unsure I can do that safely if the wires coming from the modified ECU are necessary for the car to run properly. From what I can tell I can't transfer the wires to the stock ECU. I was thinking about just putting in the stock ECU and seeing if the car runs, but I'm not completely sure this would rule out the wires as essential to safe operation.
Thoughts?
BTW- When I tried to do the swap, I disconnected the battery. Now my subwoofer doesn't work
Old Jun 27, 2007 | 01:30 PM
Kevlo911's Avatar
Kevlo for President
I would go with the nitrous switch, call JWT...
Old Jun 27, 2007 | 01:51 PM
STILLENGLE's Avatar
Fire Hazard.
Old Jun 27, 2007 | 02:25 PM
nismology's Avatar
Call JWT. One would think that'd be the first thing to do.
Old Jun 27, 2007 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
to nismology
It be interesting to pop the top and comapare it w/a stock unit.
Old Jun 27, 2007 | 04:37 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by NmexMAX
to nismology
I said it first
Old Jun 27, 2007 | 04:42 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Kevlo911
I said it first
404 ERROR, subtle reference to use common sense not found. Ex.
Old Jun 27, 2007 | 06:35 PM
95maxrider's Avatar
Lightly modded
I already called JWT, but the techs were at lunch and I couldn't call them back. I'll call them tomorrow...
Old Jun 28, 2007 | 08:44 AM
Nismo87SE's Avatar
Red and blue wires plug into the n2o relay which activates the n2o solenoid. The grey wire is the arming switch for the n2o.
Old Jun 28, 2007 | 01:45 PM
95maxrider's Avatar
Lightly modded
Thank you sir, that's exactly what JWT said.
Matt93SE
May 24, 2019 02:58 PM
Slamrod
Sep 3, 2015 07:38 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
t6378tp
Aug 24, 2015 07:03 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
