Sponsored by:
Sponsored by: CARiD
Quick question
Old Jun 28, 2007 | 06:41 PM
Theyears02's Avatar
Quick question
does anybody know the inner diameter of a 5.5 gen MAF tube? i know everybody talks about using the 82mm land rover MAF, but the price of boring my stock one VS the price of buying the land rover one and getting a vafc and tuning it is a huge difference. im thinking about boring about 2 mm out of the MAF tube, which would hopefully make a little difference with the AFR and the timing, although im not sure if i can bore it enough to make a difference. anybody with some numbers to help? thanks a lot. input on the idea is welcome too.
Old Jun 28, 2007 | 06:49 PM
NmexMAX's Avatar
dot dot dot ...
ID = 70mm. . . . . .There's not nearly enough meat on there to even make a 75mm safely.
M62 MAF can be had for quite cheap. (65 - 110 USD)
Old Jun 28, 2007 | 07:06 PM
DasYears
i was thinking about this same thing, but i cant spend 65 +150 (real cheap vafc2)+80 (real cheap for vafc tune). i was planning to make either a 72 or 73mm bore. think there would be any real difference? i dont car about airflow, thats not whats gonna change really, specially with a 72mm TB.
Old Jun 28, 2007 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
Only one way to find out.
Old Jun 28, 2007 | 07:18 PM
DasYears
haha, going to osh to pick up 73mm as we speak
Old Jun 28, 2007 | 08:25 PM
NmexMAX's Avatar
dot dot dot ...
Osh, 73mm??? Ok..
A 76.2mm housing has been proven for ~ 8whp untuned. FYI
Why not just do it right the first time, and get the proper items necessary to take full advantage of it?
Old Jun 28, 2007 | 10:40 PM
DasYears
because a 73mm drill bit (for a drill press) is only like 12 dollars, so i can use it both on the MAF tube and the Injen intake adapter that im using to connect to the filter. i plan to go 82mm later, but thats such a small amount of money to try something. im pretty sure i spent more doing the ssim
Old Jun 29, 2007 | 10:57 AM
NmexMAX's Avatar
dot dot dot ...
Why not just slap a filter on the MAF? 'Tis what I did.
Old Jun 29, 2007 | 12:51 PM
DasYears
you mean cut the flange off? by flange i mean the square part with all the bolt holes. if so, what did you use to cut that?
Old Jun 29, 2007 | 01:43 PM
NmexMAX's Avatar
dot dot dot ...
I forgot. My LR MAF doesn't have a flange. NM
See what I did there --->http://forums.maxima.org/showpost.ph...19&postcount=6
Old Jun 29, 2007 | 02:13 PM
DasYears
95blckmax actually did what i thought you were suggesting. might be worth a try, since i KNOW i have some 3" ID PVC lying around here somewhere. i guess well see what i end up doing and ill post up the results. thx for the input
Old Jun 29, 2007 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
3" PVC = for the 5th gen. I'm assuming you knew that. There's an entire thread on it from years ago.
Old Jun 29, 2007 | 02:40 PM
DasYears
yeah i know, sr20 did it first, but he kinda got in trouble for using the pvc. meh. blckmax did remind me though. i like the idea since the cost to me would be = the cost of a little jb weld
Old Jun 29, 2007 | 02:45 PM
NmexMAX's Avatar
dot dot dot ...
What's nice/convenient about the M62 MAF housing is that our sensor sits in there and feels at home. Although, electronic IPW adjustments via remote MAF V correction does need to be adjusted as so.
Old Jun 29, 2007 | 03:02 PM
DasYears
yeah. such is my plan for the future. but for now im only looking for a dirt cheap alternative that will last the summer racing season
Old Jun 29, 2007 | 03:13 PM
NmexMAX's Avatar
dot dot dot ...
This forum should cheap members
IBthat'showweinnovati.vehings
Old Jul 1, 2007 | 01:02 PM
DasYears
well i did this, dont have pictures yet since im on vacation now. its seems to be ok. got pretty good gas mileage driving here but i have no idea if thats an effect. ended up getting about a 74mm cut, which i calculated to a 11.76% increase in cross sectional area of the intake. i know i probably wont have gotten more than 5HP at most for this, but for the $12 it cost me, ill take it. better $/HP than most mods you can buy. im planning to get the LR intake later but this should do until i get a VAFC and headers...i will post pics in a week i guess. nothing special, hard to tell a 4mm difference in diameter. butt dyno says i dont see a difference...im not surprised
Old Jul 1, 2007 | 01:10 PM
NmexMAX's Avatar
dot dot dot ...
. It wont affect anything in closed loop.
Old Jul 19, 2007 | 09:22 PM
DasYears
just thought i would update with what i did. i ended up making about a 75mm cut through the tube since my drill press it seems doesnt rotate exactly right, haha, i guess this time its a plus. after that i sanded it nice and cut off the flange. made a bit of an air horn at the end (not really but kinda).
now for the pics.
and the resulting diameter
installed
EDIT: forgot to add, the gains are as expected: nothing i can feel. but i do have to say, it may have sounded better and may have had better part throttle response. placebo? could be
Old Jul 20, 2007 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
No data no care.
Old Jul 20, 2007 | 07:34 AM
DasYears
ill probly dyno sometime in the next while, but it doesnt matter cause i have never before
Old Jul 20, 2007 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
Will it be on a dynojet?
Old Jul 20, 2007 | 09:19 AM
DasYears
yeah of course, got to use the org standard
Old Jul 20, 2007 | 09:47 AM
NmexMAX's Avatar
dot dot dot ...
The reason I ask is because there a lot of members that do not use a DJ, and try and compare their runs to a DJ, from a different machine.
Old Jul 20, 2007 | 06:47 PM
DasYears
yeah i know this, i figure i wont see much, but hopefully i get a good idea of my AFR so i know im still safe
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
