3.5 Swap, what timing components do I use?
Before ya'll me for "not" searching, please know that I have tried searching using the "Free Search", I don't get good results with my search terms. Also, in the two stickied swap threads, there is no clear indication as to what parts from which engine end up in the final swap. My car has 203K miles, and my swap motor has 9800 miles. I don't want to put the consumable timing components from the VQ30 because they are so old. Also, I am under the impression that there needs to be a mix match of timing parts from both the VQ35 and 30. So, help me understand:
VQ30 Cam gears w/spacers UNDERSTOOD
VQ30 chain UNDERSTOOD
VQ30 water pump?
VQ30 or 35 chain guides?
VQ30 or 35 tensioners?
Thanks for the help!
VQ30 water pump?
Originally Posted by nismology
I was under the impression that you were going to use the VQ35 ECU.
I re-read the swap threads, can't find any timing parts info, can you please help me?
THX
VQ30 water pump?
VQ30 water pump?
chain guides = 3.0
inner tensioners can be either. outer tensioners need to be 3.0
ot - oh and this had been covered because i was asking the same questions before i did my swap lol.
Originally Posted by XJinCT
water pump = vq30. the chain is double or triple linked and crazy looking for the vq35, while the vq30 chain looks like bike chain. so you need the pump that will fit on the chain.
chain guides = 3.0
chain guides = 3.0
FlaMark
25
08-28-2015 10:15 AM
MaximaDrvr
08-19-2015 08:20 PM
cmpowell86
08-10-2015 12:35 AM
