Sponsored by:
Sponsored by: CARiD
Lack of torque in 3.5 swap?
Old Aug 6, 2007 | 11:37 AM
  #41
915Max's Avatar
I messed up on the numbers I put in.. didnt read that post by Nismology.. but my voltage is at 4.1....
Old Aug 6, 2007 | 01:31 PM
  #42
XJinCT's Avatar
<3's the all motor section
found this regarding ignition timing on a 3.5 swapped 4th gen with 4th gen ecu that later swapped to the 5.5 gen ecu. explains quite a bit. the power dip in the rpms we mention, is when the 4th gen ecu retards the timing quite a bit, could contribute to the large dip in power at that rpm.
Old Aug 6, 2007 | 02:12 PM
  #43
nismology's Avatar
The large dip in power is primarily a function of the modified VI. Even A33B's with their CVTC and more aggressive ignition timing between 3500-4500 RPM experience the same loss of power at the lower end. The ignition timing might have something to do with it, but it is not the main culprit. VE > ignition timing when it comes to the shape of power/torque curves.
Old Aug 6, 2007 | 08:50 PM
  #44
accordingtou's Avatar
VQ30 DE T
Originally Posted by chillin014
i can NOT get mine into spec. and i think thats what is causing my hesitation. Sometimes the car feels like it pulls the PROPER ammount and sometimes its holding back..its not always feeling crappy mid-range. Is it even possible to get the 4th gen TPS exactly within specs on the PF TB? i have mine pushed all the way clockwise to get it as close as i can.
Yes I set mines this weekend to .52v
Old Aug 6, 2007 | 09:44 PM
  #45
chillin014's Avatar
is it pushed fully clockwise? im trying to figure out why im the only one with this problem.
and driving hte car tonight, i did not feel the delay of power...like i said, with mine its kinda intermittent. In fact, when im driving and holding the pedal 30 percent down steady and accelerating in gear it will actually buck a little between the slower accleration mode and the quicker one...usually when its off a cold start*
Old Aug 6, 2007 | 10:15 PM
  #46
VQ30 DE T
No "fully clockwise" on my pftb tps reads.1v I used a snapon scantool
to read voltage while I adj the tps.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
