Sponsored by:
Sponsored by: CARiD
00VI swap, 5th gen everything not starting suggestions please!
Old Aug 17, 2007 | 12:01 PM
RedfoxXx's Avatar
00VI swap, 5th gen everything not turning over, suggestions please,
Well, spend all night swapping it in, no EGR because I could not get the dam guide tube off, blocked off both ends of that
Using 5th gen IACV
The motor just will not turn over, any thoughts are welcome
Old Aug 17, 2007 | 12:28 PM
DasYears
any clicking, radio/headlights work?
Old Aug 17, 2007 | 01:04 PM
RedfoxXx's Avatar
clicks, radio works
I pulled the codes I have a (0205) Idle Speed Control code
did i forget something using the Using 5th gen IACV?
Old Aug 17, 2007 | 01:14 PM
gtr_rider's Avatar
192.168.1.1
Did you ground the engine harness real good?
Old Aug 17, 2007 | 01:16 PM
RedfoxXx's Avatar
yup! ill post some pics as* soon as I can find a darn camera
Old Aug 17, 2007 | 01:22 PM
gtr_rider's Avatar
192.168.1.1
Only reason why it wouldnt crank at all would have to be because of the grounding situation, try grounding to another grounding spot(ie. timing cover)
Old Aug 17, 2007 | 01:47 PM
RedfoxXx's Avatar
sry, wrong word, its cranking, its just not starting
Old Aug 17, 2007 | 01:50 PM
RedfoxXx's Avatar
Old Aug 17, 2007 | 01:51 PM
RedfoxXx's Avatar
Old Aug 17, 2007 | 01:58 PM
DasYears
try holding the throttle open when starting the car? if the iacv isnt working correctly it may not start without holding the throttle open.
Old Aug 17, 2007 | 02:10 PM
gtr_rider's Avatar
192.168.1.1
I dont see a vacuum line on the fuel damper? I would remove that 00IACV, and block off the hole it makes. Adjust the set screw after you get it to startup
Old Aug 17, 2007 | 02:21 PM
RedfoxXx's Avatar
it will not start at WOT
where is there a screw on the 00IACV?
ill go take it off and look
Old Aug 17, 2007 | 02:37 PM
XJinCT's Avatar
<3's the all motor section
check for spark, check for fuel. thats always a good place to start...check your connections.
Old Aug 17, 2007 | 02:40 PM
gtr_rider's Avatar
192.168.1.1
did you check the vacuum on the fuel line?
Old Aug 17, 2007 | 02:41 PM
Tatanko's Avatar
Bacon Lover
The 5th gen IACV isn't the greatest idea in the first place because it isn't 100% compatible with our ECU and wiring harness, it would seem. But, if holding the throttle open won't allow it to start, the IACV probably isn't the problem. Are you trying to start it WITH your intake attached or no?
Old Aug 17, 2007 | 02:51 PM
RedfoxXx's Avatar
yes, intake is on
Old Aug 17, 2007 | 02:58 PM
RedfoxXx's Avatar
What is the best way to check for fuel?
The rail is pressurize, I popped off one of the FPRs to see
Old Aug 17, 2007 | 03:06 PM
nismology's Avatar
Sniff the exhaust while someone else cranks it.
Old Aug 17, 2007 | 03:07 PM
nismology's Avatar
Title edited for clarity.
Old Aug 17, 2007 | 03:44 PM
RedfoxXx's Avatar
Ok I think it’s the fuel, the exhaust dose not have a gas odder, and when I crank the engine with my hand under the injector I don’t feel any mist, what could be wrong with them? The fuel line is pressurized I am going to check wires
Old Aug 17, 2007 | 03:51 PM
RedfoxXx's Avatar
ok well now I am not so sure about the fuel theory, after pulling the fuel pump fuse and cranking it for a little bit I was able to depressurize the fuel lines, if they were not working the fuel rail would have stayed pressurized, hmm
Old Aug 17, 2007 | 05:11 PM
RedfoxXx's Avatar
still no luck
is the fact that im using both of the 5th gen FPR a problem?
Old Aug 17, 2007 | 05:29 PM
VQ'ed's Avatar
have you grounded the injectors...remember the little black wires that connected together in front of your usim. Check also the fuel delivery hoses if you changed all the hoses...
Old Aug 17, 2007 | 07:27 PM
RedfoxXx's Avatar
Blown fuse . . .now on to the air leaks
Old Aug 17, 2007 | 08:55 PM
RedfoxXx's Avatar
Ok it runs, at 0% throttle it accelerates to 35MPHs thos, In neutral it will climb up to 3k and drop back to 2k, so it sounds like there is a vacuum leak and the IACV is trying to compsate?
I switched to the 4th gen TPS, my VAFC reads the throttle % now,
Good news no more CELs!
So what’s the best way to look for vacuum leaks? Popular spots for 00VI swaps to leak form?
ill post if I find anything
Old Aug 18, 2007 | 08:50 AM
gtr_rider's Avatar
192.168.1.1
Not sure if you read, but remove that 5G IACV and block off the TB where it attached to it. A 5G IACV doesnt really work correctly on this swap.
Old Aug 18, 2007 | 10:43 AM
RedfoxXx's Avatar
you suggest using the 4th gen IACV then??
who sells the plates for thos?
Old Aug 18, 2007 | 10:53 AM
RedfoxXx's Avatar
http://forums.maxima.org/showthread.php?t=463248
this thread says thet the 5th gen IACV will work
Old Aug 19, 2007 | 05:13 PM
RedfoxXx's Avatar
modded in the 4th gen iavc, still same problem dose this sound like a vacume leak? from where
I blocked off where the 5th gen iavc plugs in FYI
Old Aug 21, 2007 | 08:02 AM
cardana24's Avatar
Blown
the surging idle sounds like a vac. leak, while the car is running spray carb cleaner at different spots to find out where it is leaking. When the engine takes in some of the car cleaner the rev's will race. Some of the more common places for them to leak is at the Lower and upper intake manifold unions.
Old Aug 21, 2007 | 06:53 PM
RedfoxXx's Avatar
yeah I think its the plenum gasket I ordered a new one , we will see wends
Old Aug 21, 2007 | 11:11 PM
elemax's Avatar
I'm using all 5th gen, including IAC- works perfectly in all conditions.
Be sure to properly adjust the TPS and base idle too.
Old Aug 22, 2007 | 02:37 PM
vipervadim's Avatar
I like Maximas
Sorry bro, but i have to say you are using VERY OLD information... or you just don't know..
I've done 9 00vi installs! only 2 stuck with 4th gen IACV + adapter plates, and ONLY those two guys have cold start issues.. everybody else starts the car and it revs to 1500
I even had the Pathy TB + IACV on my Max hooked up and working CORRECTLY, the way it should
I'm not out to start BS.. just information for those who need it.
Old Aug 22, 2007 | 02:40 PM
RedfoxXx's Avatar
THX I am on it already, i am going to use the 5th gen IAC no matter what I have to do just to spite GTR_rider. I have read 4 threads about similar vacuum leaks and he says in all of them that the 5th gen IACV dose not work for us and that using the 4th gen Iacv will fix the problem. Maybe he can post that on his VQpower site
Old Aug 22, 2007 | 04:15 PM
Tatanko's Avatar
Bacon Lover
I stand corrected, also, then. Just curious, what are you doing to them to make them work? Just splicing wires?
Old Aug 22, 2007 | 04:25 PM
nismology's Avatar
The thread that RedfoxXx posted on the first page details what to do to use the A33 IACV.
Old Aug 25, 2007 | 03:42 AM
Curt's Avatar
Not that it's the cause of your problem, but here's something else you'll need to fix to get the 00VI working correctly: that vacuum line to the passenger-side port on the VIAS is wrong. That port doesn't need vacuum, which will cause your power valve to be activated continuously. That port should be connected to fresh, unpressurized air. On stock 5th gens it's connected to the airbox (IIRC); I don't have mine connected to anything.
Old Aug 30, 2007 | 12:18 PM
RedfoxXx's Avatar
Your right i miss read this thread http://forums.maxima.org/showthread.php?t=508217
THX!
Old Aug 30, 2007 | 01:12 PM
speed racer's Avatar
All you do is break the outer connector shell part of the IACV on the engine harness side and than connect that the the 5g IACV. Use tape to hold it down.
ON the 4g IACV there's a pink and purple connector. This can actually be removed from the IACV. Take them off and find a place in the engine bay to tie them too. No splicing at all.
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
maxima-junky
Aug 13, 2015 09:59 AM
Blackwind
Aug 5, 2015 06:35 PM
