Full Monty 3.5 swap progress
Originally Posted by nismology
Hmmm....
I wonder what ECU pin #30 is for...
I believe it is used to tell the AC AMP of the newer cars that the compressor has been shut off by the ECU
Originally Posted by made in china
You may be right about the specs on the A32. I read the A33B compressor description and they mentioned it is a new design unlike that used on previous applications. Maybe I have assumed incorrectly, and I have a different problem. But you are assuming I have not implemented the wiring correctly? The car is completely wired per I35 FSM. Everything properly in place and functioning fine aside from missing downstream O2 sensors, PSP sensor, stupid little things like that. Anyway, the wiring is 100% fully implemented, and all my AC functions are correctly wired. But, I may be barking up the wrong tree, if this problem persists I'll need to find a way to get a Consult-II and do some real troubleshooting. Unfortunately, I likely will never get around to that. No time!
And no need to get defensive and brag about your wiring prowess. If all the a/c functions were wired in completely, you wouldn't be having this issue.
Compressor feedback signal.
Furthermore, I'm not quite sure how "ACPDCUT" translates into a feedback signal. Cut means cut. This also coincides with the AC cut function the FSM describes in the EC section.
And thanks for pointing out that I am "bragging". Your tone has been condescending from the get go.
But anyway putting up with your crap attitude has helped me understand what I need to do. It makes perfect sense now, all I have to do is put up with a little crap from certain people and I eventually get the info I need!
The FSM makes no mention of this signal. The ECU has no way of knowing whether the clutch is engaged or not.
Thanks for clarifying it for me.
I guess that happens inadvertently when I don't feel like people are willing to read my posts thoroughly. Apologies. I was just trying to help you get to the bottom of this.
I plan on using a micro relay connected to ACPDCUT to intercept the ARCON signal and open the circuit. Now I can see I definitely over revved my compressor, ooops. No bragging here dude!
Pg. HA-34 of 2004 I35 manual.
Under normal operating conditions and for all intents and purposes, there is a 0V at pin #8 on the a/c auto amp.
Originally Posted by fuzionSE
is it worth it to swap out the 3.0 for the 3.5?
The 3.5 is so much heavier than the 3.0
ooo ooo i found it http://forums.maxima.org/showpost.ph...4&postcount=10
just a little more humor for this thread
Originally Posted by krismax
my question is ...does anyone have a full 3.5 swap with 100% no CELS ?
many states require 0 CELS
Originally Posted by eng92
I have been CEL free for about 1-1/2 years now. I also passed my tailpipe emissions test this past May.
Fortunately my car in WA state can just be tail pipe sniffed because Nissan sold some vehicle in 97MY that did not have OBDII. But anyways, I'd like to know how to clear my CAN codes
Security LED should be lit by both the smart entrance AND the NATS "LED" output. In my FSM, they were in parallel, simple as that. Your LED should flash by either the NATS or smart entrance, or both will cause it to flash.
Well i brought the car back home and attempting it myself. so far i "decoded" the wiring harnesses for both the VQ35 and body harness for my car so it's jus to connect up which i doing next week. i jus hope the guy didn't lock my ecu as he attempted to "initialize" the nats system to re-program the original key, don't know why he did that!!!
It appears my car did not come with smart entrance, instead it had the time control unit for thing like the interior lights and warning chime. not sure how it will impact with the rest of the system. have to connect all the harnesses and then see.
Hmm, OK, good to know.edit: nevermind im thinking something completly different.
Originally Posted by DasYears
you cut the wire from the ECU to the SES light
Last time I did emmissions, I had my SES lamp (A32) disconnected and the tech notified me that my OBDII system was reporting a "not ready" condition (I had blown O2's) so I played dumb and they went ahead and roller tested the car and passed me anyway. We'll see what happens, I am not sure if the CAN codes will create a emmissions problem, and if it does I just need to convince them to roller the car.
Check your State's requirements closely. In WA State, they require no CEL if they are going to perform the OBD ONLY test. If you have a CEL, they allow a tailpipe test, from the WA web about emissions:
Q: What’s the difference between the emission test on a vehicle with OBD and one without it?
A: If your vehicle has OBD, the lane operator at the test station will plug in a cable to the vehicle’s computer connection (usually located in front of the driver’s feet) to download emission-related information. This has no effect on the vehicle.
If your vehicle does not have OBD, or has a type of OBD system that has problems with OBD testing, the lane operator will do a tailpipe test. For a tailpipe test, the operator inserts a probe into the tailpipe while the engine is running, to sample air pollutant levels.
WA State OBD Test Requirements
So check closely before you modify your car. You may be able to slide on CEL's as long as you have a clean tailpipe.
A pic of underhood connections:
The three red wires are fused supplies for:
BAT (10A) for NATS and EL cluster. The A32 in '97 doesn't have a BAT supply for the analog cluster, and since I was making the last of my connections underhood, I figured get the power for those at the fusebox instead of under the dash. BAT is available under the dash also, if you prefer.
ECM relay #2 pole. The A32 uses a SPST relay and the A33 uses SPDT, so this second fuse at 15A provides power for that second pole which powers everything else per FSM.
DBW (eGas) relay power source, power for the DBW VMOT.
The power is tapped off of existing male 0.250 spades in the underhood fuse box.
You can also see my Delphi Automotive connector that carries the signals/power that was originally run thru 2 8 pin connections. I chose to utilize one 16 pin Delphi GT150 connector to simplify my swap.
The signals are:
IGN SW 30A
SSOFF
RFRH
RFRL
BATT 10A
HO2S power
VB from ECU relay
Start/On 30A
IGN SW 30A
(unkown)
PNP Relay
ACRLY
ECU Relay Pole 2 load
DBW Load to VMOT
DBW Coil
Start/On 30A
The signals are:
IGN SW 30A
SSOFF
RFRH
RFRL
BATT 10A
HO2S power
VB from ECU relay
Start/On 30A
IGN SW 30A
(unkown)
PNP Relay
ACRLY
DBW Load to VMOT
DBW Coil
Start/On 30A
Update....
seems where i sent the car before the guy did a hack job on the wiring!!! The electrician who came to look at it after i brought it back home asked me if i carried the car by a butcher!!!
well after i wired up all the engine control harness, changed around some connectors for the instrument display an so forth go to start the car no "service engine light, no abs light" and well a few other things, like fuel guage didn't move(not sure if it still has gas in the tank to be honest) and some of the AT indicator lights weren't showing up...Oh yeah security light staying ON when ignition on... so brought a guy with a scan tool to re-program the key thinking that nats disabled the ecu an so forth, only to realise the ecu now powering on!!
mech checked and the guy cut alot of wires on the 2 8-pin connectors by the fuse box located in the pic above, which i was told supplies power for the relays and other main functions. so i now have to get someone to trace back the wiring for the power supply as it's not something i can handle with my limited knowledge on vehicle electronics.
stress stress and more stress....
Update....
You do not need to be terribly smart or gifted with electronics/electrical, but a good understanding is necessary. And most importantly, you need to establish a clear procedure/plan and follow every wiring connection thru the A32 (A33A in your case) and A33B FSM's. It's like a religious thing. You have to make sure every wire is connected correctly, and be aware that wire colors change between chassis and often between connectors (especially underhood, there is alot of color changing happening).
MOST IMPORTANT: IMO only 1 guy should handle the wiring from beginning to end. It can get to confusing when someone elses's work is too difficult to follow.
If I were you, I'd start over on the wiring. Whoever tries to pick up the pieces may prefer to just start over.
Can anyone see any of the pictures posted by made in china?
Is this a result of the "new site"... I know this thread is old but I went looking for it when I couldn't find it in the stickies here:
http://forums.maxima.org/all-motor/4...-progress.html
Maybe it should be added? nismology?
Merry Christmas!
Updates:
The car now has 35K miles since the swap. I drive the **** out of it.
Oil consumption @ 6000 mile oil changes: 1/2 quart
Average MPG: Summer 30.1 MPG, winter 27.9 MPG
Passed full OBD-II emissions recently.
Converted back to A33B pre-cat/4 O2 sensor stock manifolds. Butt dyno says the HP is down at higher revs. This is compared to my previous Warpspeed Y and A32 manifolds. No plan to go back, I like how quiet the car is now.
Never fixed the AC issue, but I have a new A33B AC compressor, and when my A32 AC system finally conks out, I'll be installing the new compressor and lines that have the A33B pressure sensor which I'll connect to the ECU (as it's supposed to be). The AC works fine at anything below 80% throttle.
So far, I have had no reliability issues at all. knocks on wood..........
Updates:
