Sponsored by:
Sponsored by: CARiD
BBMAF Solution for DEK
Old Aug 27, 2007 | 11:48 AM
TDotMax's Avatar
BBMAF Solution for A33B
I've searched and only find info on 4th gens and 5.5 gens or FI 5.0's.
I can get a 93 J30 MAF for $50. Would it be worth it in a A33B. Also how do they wire up? Or do I just use the stock A33B unit and pulg into the new MAF?
Old Aug 27, 2007 | 11:53 AM
NmexMAX's Avatar
dot dot dot ...
WRT to housings, DEK MAF = A33B MAF.
Old Aug 27, 2007 | 11:57 AM
TDotMax's Avatar
Better?and what does WRT mean? At first I though you were saying a WRX housing works lol.
Old Aug 27, 2007 | 11:59 AM
NmexMAX's Avatar
dot dot dot ...
With respect to housing size, the sensor is the same.
Cliffs: Anything 5.5 gens do, you can do it too using the same hardware.
Old Aug 27, 2007 | 12:02 PM
TDotMax's Avatar
Would that not be overkill using a Land Rover MAF though?
Old Aug 27, 2007 | 12:04 PM
NmexMAX's Avatar
dot dot dot ...
General consensus seems to be pointing in that direction right now.
1.) Get ahold of 6spd_Hayes and see if he will sell you one.
2.) Bore your stock unit.
3.) Find a Ford 77mm unit and custom fit your sensor into
Old Aug 27, 2007 | 12:06 PM
TDotMax's Avatar
Maybe I'll try boring, I think I got a old housing lying around. I saw a thread on that option.
But I thought the J30 would be a good option at $50 since I see its the same as a Z32 which is common.
Old Aug 27, 2007 | 12:12 PM
NmexMAX's Avatar
dot dot dot ...
I fail to see the advantages/gains of a J30 MAF.
IMO, it's easier to use your sensor in a different/larger housing. Assuming you have all supporting mods (AFC/WB).
Even though it might not be much harder to wire in the J30MAF, what exactly does the J30 have over the DEK?
Old Aug 27, 2007 | 12:15 PM
95BLKMAX's Avatar
J30 Maf= Z32 Maf
Old Aug 27, 2007 | 12:19 PM
TDotMax's Avatar
Originally Posted by 95BLKMAX
J30 Maf= Z32 Maf
Hence why it would be better then the A33B Mass.
Yes I have supporting mods except for the WB yet. But SAFC is there as I've read what the MAF upgrade can do without proper tunning.
Old Aug 27, 2007 | 12:24 PM
nismology's Avatar
The Z32 MAF is like the A32 MAF in that the actual sensor can't be removed from the housing without hacking it up. Why not remove your sensor and bolt in into another housing? (get in touch with 6Spd_Hayes like Nmex suggested) The wheel need not be reinvented this day!
Old Aug 27, 2007 | 12:27 PM
TDotMax's Avatar
Originally Posted by nismology
The Z32 MAF is like the A32 MAF in that the actual sensor can't be removed from the housing without hacking it up. Why not remove your sensor and bolt in into another housing? The wheel need not be invented this day!
Gotcha, hopefully I didn't throw out my old MAF housing and I can play with that and contact 6spd as well.
Old Aug 27, 2007 | 12:28 PM
nismology's Avatar
Oh btw, I think the reason that A32's can't use the A33/B MAF is the same reason why you wouldn't be able to use an A32/Z32 MAF.
Old Aug 27, 2007 | 03:53 PM
NmexMAX's Avatar
dot dot dot ...
In N/A form, explain how so.
Old Aug 27, 2007 | 05:03 PM
DasYears
so you can get a good 10:1 afr
Old Aug 27, 2007 | 06:12 PM
TDotMax's Avatar
I got pwned
I did more reading
I am looking into other things such as my old MAF being bored and using the new sensor first then see from there.
Old Aug 27, 2007 | 06:19 PM
NmexMAX's Avatar
dot dot dot ...
Glad you're learning though. I thought I;d let you do some reading first. But yes, you're on the right track now
Old Aug 27, 2007 | 06:42 PM
TDotMax's Avatar
I'll check my options out for below a 77mm MAF the 82's 3.5 are using would be too much for a 3.0 from what I gather.
Old Aug 27, 2007 | 06:47 PM
NmexMAX's Avatar
dot dot dot ...
Depending on your ultimate goal(s), I'd shoot for a PFTB coupled w/ a larger MAF housing.
Old Aug 27, 2007 | 07:07 PM
TDotMax's Avatar
Got one, just no adaptor plate. Won't be able to do the TB for awhile (Wedding and house closing don't mix with mods lol)
Old Aug 30, 2007 | 12:30 PM
95BLKMAX's Avatar
!!!!!! That, along with this that I had done on my 3.0....
Do that to each runner on the LIM, use the gasket to port-match to the upper and polish as much as you can reach into the upper (if using a VI, most you might have to do is port matching, if at all). That top end will be sweeeeet! (especially with some cams y0!)
knight_yyz
Nov 6, 2015 02:34 PM
jchronis2552
Sep 21, 2015 05:52 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
