Sponsored by:
Sponsored by: CARiD
Need a bit of info: "6 speed - Hlsd" Maxima ?
Old Aug 30, 2007 | 01:17 PM
Ceasars Chariot's Avatar
Old Maxima Legend
Beyond the A32 I dont know much about the newer models. I do know we had a 6 speed option in the later models, but I have always heard the term VLSD when concerning factory LSD with our maximas.
Is there a 6 speed - with (Helical) HLSD option, if so what year is that ?
Old Aug 30, 2007 | 01:19 PM
ewuzh's Avatar
2002-2003 6-speeds had optional HLSD from the factory.
Old Aug 30, 2007 | 01:26 PM
DasYears
as well as 04's (even through 06 maybe? )
Old Aug 30, 2007 | 02:47 PM
nismology's Avatar
Heh...
It was optional for 02-06 6-speeds.
Old Aug 30, 2007 | 05:16 PM
vq35power
and only 2004 had optional hlsd as far as 6th gens go...
Old Aug 30, 2007 | 05:20 PM
95turbo gxe's Avatar
If you wanted to go through like I did I got a spec v tranny all of them have it(HLSD) and can be bought for much cheaper than maxima tranny all you need to add is a maxima bell housing with could be bought for like 238 new
Old Aug 30, 2007 | 07:05 PM
MorpheusZero's Avatar
from what i understand (not sure though so correct me if i'm wrong)
spec-v: weaker(although there are spec-vs with vq35s and stock trannys), closer ratios, shorter gearing meaning higher engine speeds when cruising...
A33-34 6sp: stronger and taller gearing, more befitting for a max with a 35 swap
Old Aug 30, 2007 | 07:27 PM
nismology's Avatar
There is no strength difference between the maxima and spec-v 6-speeds. As far as gear ratios go, they are all the same except that the spec-v 6th gear is shorter. The early spec v's had an extremely short final drive, while the later ones had the same as the A34's.
Old Aug 31, 2007 | 10:25 AM
AnDyMaN's Avatar
what nismology said. 2002 spec v's have the 4.4 fd. however, i thought that was the only difference between the spec v and the a33 tranny.
in any case, those tranny's are strong. my friend w/ the spec v said that vq35 swapped and turboed sentras do not have much problems with the transmissions. and all come with hlsd. if you do a swap, you can get a spec v tranny for about 300 bucks.
but make sure you know, 2002 spec v cruises around 3000 ish rpm at 80mph. 2003 and up is taller.
correct me if im wrong.
Old Aug 31, 2007 | 12:04 PM
damn, $300? the shifter cable driven like the A33/4?
Old Aug 31, 2007 | 12:06 PM
nismology's Avatar
It's essentially the same transmission in the ways that matter.
Don't let the low pricetag on the Spec-V tranny fool you though. You still have to source a VQ bellhousing, shifter and cables (the most expensive components, typically), 6-speed clutch/flywheel, axles, mount and bracket, starter, slave cylinder, and all associated hardware.
Old Aug 31, 2007 | 12:08 PM
including price then?
Old Aug 31, 2007 | 12:15 PM
DasYears
probly from the dealership, not from junkyards. my guess is a higher % of spec-v's get wrecked than 6spd max's, plus more are around to start with. high supply=low price, since they dont know that they are all mostly the same
EDIT: i see an 04 for 250..., 9 pages of those tran's on car-part.com, a total of 3 04-06 max HLSD 6spds
Old Aug 31, 2007 | 12:19 PM
yeah i was thinking $300 sounded awfully cheap for a A33 HSLD 6sp... screw that, i'm all for the spec v tranny then
Old Aug 31, 2007 | 12:54 PM
eng92's Avatar
Let us make sure that everyone is clear that it is called a clutch housing which is an integral part of the transmission and not a bolt-on part like a bell housing for a rwd tranny.
To do it properly, all your bearing end-play/preloads need to be measured and the correct shims installed.
Most people would not have the measuring tools necessary to do this accurately enough.
So if you cannot do it yourself, then be sure to factor in the cost of a transmission shop to do it for you.
Old Aug 31, 2007 | 06:27 PM
The shifter cable are not that much I got mine for $50 from car-part.com
Old Aug 31, 2007 | 07:06 PM
made in china's Avatar
To add to all this, doesn't the SpecV have a provision for mounting up a VSS and the maxima 6MT has none?
Old Aug 31, 2007 | 07:11 PM
DasYears
just because its there doesnt mean you have to use it...
Old Aug 31, 2007 | 08:00 PM
eng92's Avatar
Where are you getting your information from?
The VSS mounts in the clutch housing, not in the transmission case. A33B and A34 share the same clutch housing (30400-8H810) There is a provision for mounting the VSS on it and the final drive has a speedometer gear on it. I have one sitting in my garage if you would like a picture.
Old Sep 1, 2007 | 06:07 PM
Red Lion's Avatar
I bought my Spec V transmission for $450shipped, my CLUTCH housing lol for roughly $250shipped, so that's $700 and I still need to install them; if you can take the transmissions apart it'll probably lessen the cost of having a shop put them back together, but figure maybe another $200 give or take, depending on the shop. So roughly $900 for a 6-speed HLSD. And this doesn't include the motor mount, cables, shifter, axles, etc.
Old Sep 1, 2007 | 06:28 PM
uhh, this forum, like everyone else.
Old Sep 1, 2007 | 09:02 PM
eng92's Avatar
link please
maxinout93
Oct 27, 2015 01:29 PM
kingw323
20
Oct 21, 2015 08:36 AM
Finkle
Sep 27, 2015 09:53 PM
niZ
Aug 7, 2015 10:18 PM
