Sponsored by:
Sponsored by: CARiD
Spec for Ignition timing
Old Sep 5, 2007 | 08:02 AM
danman700's Avatar
I got access to a consult tool yesterday, so i was looking around a bit and ran the active ignition timing test. This is with the 3.5 swap,
CKPS-RPM(pos)-913rpm
CLSD THL POS - ON
IGN Timing- 30btdc
IACV-AAC/V- 57 step
This was at idle on a cold start. Anyone know what the ignition timing is supposed to be at? Also i noticed there was no way with consult to increase timing just retard it, by that i mean in that test at the bottom, there is a down button that will retard, but no up botton?
Old Sep 5, 2007 | 08:33 AM
eng92's Avatar
It's an A32 ecu. You cannot alter ignition timing and save changes on it.
Old Sep 5, 2007 | 05:52 PM
danman700's Avatar
bummer...but i ended up looking up to find what the ignition timing is supposed to be, 15 +/- 5 @ like 700rpm idle ( i forgot exactly what the idle was but it was something lower then mine)
Old Sep 5, 2007 | 09:12 PM
NmexMAX's Avatar
dot dot dot ...
Read the entire section in the FSM re: BTDC. The car should be @ operating temperature in a certain gear if AT whenever taking readings.
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
Slamrod
Sep 3, 2015 07:38 PM
Team STILLEN
Aug 10, 2015 04:29 PM
