Sponsored by:
Sponsored by: CARiD
Tore down the VQ30DE I blew up last year. Big holes in pistons
Old Nov 4, 2007 | 11:26 PM
Nealoc187's Avatar
SLOW
OK so here are the results of the teardown of the motor I blew last fall. I blew this motor by accidentally running 17+psi on pump gas. I'd just changed a bunch of stuff which affected how much boost I made, got a little too greedy with the boost controller - obviously didn't have it tuned for that much boost.
The top of a good piston
Two front pistons - driver's side and center - are the ones that melted. FYI pistons are supposed to be circular. These ones as you can see, are not.
Nealoc187's Avatar
SLOW
Results of melted pistons effects on cylinder walls - aluminum melted and deposited on the cylinder wall. Notice in the first picture, a good wall is visible with the crosshatch from the factory hone still evident
Nealoc187's Avatar
SLOW
Heads - notice there are zero signs of detonation on both the pistons and heads. Headgaskets were perfectly intact. This was the result of a thermal meltodown that occured on one single run, something like this is not something that happens over time.
Rod bearings - the bearings were starting to flake. The film strength of Castrol Syntec 10w30 was starting to be overwhelmed. This is damage that occurs over time. There was all sorts of gunk in the oil ports for the rod bearings on the crank. I was unable to remove the block girdle to check the main bearings (the main bolts are a completely retarded design btw), but the engine doesn't spin easily with the rods and pistons removed, so those bearings might be shot too. I'll update on that. Sorry these pictures didn't turn out too well.
Old Nov 4, 2007 | 11:27 PM
Nealoc187's Avatar
SLOW
Just for comparison sake - from left to right - VQ30DE rod and piston, VG30E rod and piston, Honda F22A (Accord 4 cylinder) rod and piston.
Old Nov 4, 2007 | 11:46 PM
Nealoc187's Avatar
SLOW
Lastly, a couple pics of the 3.5 that's getting ready to go in the car shortly. Astute readers will notice that those are 3.0 valve covers on the 3.5 We (maxmaxima91 and I) CNC'd down the cam caps and then welded the VTC oil passages shut to work with the 3.0 valve covers.
Old Nov 5, 2007 | 12:24 AM
kzoosho's Avatar
Well i know where you been all day now man. Good work . I hope to see that runnig around here in Kalamazoo soon.
Old Nov 5, 2007 | 12:37 AM
maxpeed96plat.'s Avatar
Interesting and nice work on those covers.
Old Nov 5, 2007 | 09:23 AM
DandyMax's Avatar
3.5 in the works
Haha going for the stealthy swap, nice pics.
I'll post up my seized #2 bearing pics tonight (from the first engine), you'll like them..
Old Nov 5, 2007 | 10:33 AM
Nismo3112's Avatar
Custom User Title
Nice VQ30 you got there
Old Nov 5, 2007 | 10:52 AM
MrDicks95SE's Avatar
Offset Is Everything.
wow those pistons got F-ed up.
very sweet setup and very clean!
Old Nov 5, 2007 | 02:54 PM
Ephraim's Avatar
wait, what is the advantage to having the 3.0 valve covers on the 3.5?
Old Nov 5, 2007 | 03:03 PM
Nealoc187's Avatar
SLOW
I did it because I think the black valve covers are ugly as hell, and one of the VCs on the 3.5 I got was cracked. I don't know of any advantage per se.
I can glass bead stuff at work. so i glass beaded everything i realistically could to make it as clean as possible including the valve covers to clean them up (forgot to do the passenger side engine mount though, so I'll have to do that later).
Old Nov 5, 2007 | 04:36 PM
MAX2000JP's Avatar
Wow Neal, that looks really nice. Really impressed! You should paint those the crank pulley and the one to the left black. Also, you should paint those manifolds. Anthony used some off the shelf stuff on his Fury and it looks really nice for a rattle can job.
Old Nov 6, 2007 | 04:55 AM
MDeezy's Avatar
Very stealthy and nice, Do you plan the keep the man N/A? or N/A for now?
Old Nov 6, 2007 | 07:51 AM
gtr_rider's Avatar
192.168.1.1
Finally some progress I see, good stuff
Old Nov 9, 2007 | 10:59 PM
Sinturion's Avatar
N00blargh
Love the pics - looks nasty!
I'm considering stroking my VQ30 into a VQ33 using VQ35 conrods/crank (a whole VQ35 engine is still very expensive over here in New Zealand). Seeing as you have an engine in bits would you rekon its possible to change the crank & conrods without popping the head off? It would be a real time and money saver. Unfortunately the VQ33 isn't very well documented!
Old Nov 9, 2007 | 11:15 PM
DandyMax's Avatar
3.5 in the works
No, pistons have to come out the top of the block.
Old Nov 9, 2007 | 11:20 PM
MDeezy's Avatar
cant then come out threw the bottom if the crank and oil squirter's are removed? I'm not sure last time i took them out threw the top also.
Old Nov 9, 2007 | 11:25 PM
Sinturion's Avatar
N00blargh
But is it not possible to sneak the pistons down far enough to get access to the pins? (or am I just dreaming? )
Old Nov 10, 2007 | 01:08 AM
DandyMax's Avatar
3.5 in the works
You're dreaming. Take a look at a VQ30 block and you'll see. A) you can't get most of the pistons far enough down to even clear the pin before you hit the casting/main bearing saddles. B) even if you could somehow clear the pin height wise you'd still have to spin the piston a good deal, almost 90 deg maybe, to pull the pin out, which is not physically possible (spacing between the main bearing saddles...)
Old Nov 10, 2007 | 01:43 PM
Sinturion's Avatar
N00blargh
Alrighty thanks for the info. I haven't stripped down a VQ yet - the furtherest i've gotten is replacing the timing chain. Its definately going to be a learning experience and a half
Oh, and end of thread hijack
Old Nov 10, 2007 | 03:41 PM
Nealoc187's Avatar
SLOW
how much are vq35s going for in NZ?
don't worry about hijacking the thread, it's good to see a new member making good posts as their first posts instead of stupid ones
Old Nov 10, 2007 | 04:41 PM
goldtooth's Avatar
Thread Jacked. It is now mine. LOL
Is that the stock flywheel?
Old Nov 10, 2007 | 05:35 PM
kzoosho's Avatar
Nope thats a fidanza
Old Nov 10, 2007 | 08:38 PM
Sinturion's Avatar
N00blargh
Not sure of the exact price but it would be high. Our 5th gen maximas don't come with 3.5's here unfortunately - only the 6th gens do
I figured I might be able to order in the crank/rods from Japan (or possibly from the US). Looks like I might need to import some head gaskets and head bolts now too - speaking of which are the head bolts torque to yield on the VQ?
Old Nov 10, 2007 | 08:59 PM
MorpheusZero's Avatar
Sweet.
If Maximas were more widely known you might be able to fool a few people with the 3.0 VCs (even if you have the 3.5 coil packs coming up through 'em), but it still wouldn't be too hard to spot the snail...
Old Nov 10, 2007 | 10:00 PM
Nealoc187's Avatar
SLOW
i didn't use the 3.0 valve covers to fool anyone or anything like that, I just don't like the looks of the plastic valve covers.
Old Nov 10, 2007 | 11:45 PM
D-Bo's Avatar
Droppin logs
Gonna go for a polish too?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
