Sponsored by:
Sponsored by: CARiD
data logging on a wideband
Old Nov 11, 2007 | 08:22 PM
ShiftVQ35
I am in the process of hooking up a wideband that has data logging inputs. It has 6 inputs which 2 of them are speed and 4 are analog. To those that have a wideband that has data logging , any suggestions on what to hook up to it ?
Old Nov 11, 2007 | 08:24 PM
nismology's Avatar
Did this device come with a manual?
Old Nov 11, 2007 | 08:35 PM
ShiftVQ35
yes it did. according to the manual a compatible speed input is a pulse which switches between a high voltage and a low voltage. high voltage is between 2v-25v and a low is 0-0.8v and a analog input is a voltage between 0-5 v. the device is a plx r500
Old Nov 11, 2007 | 09:03 PM
95turbo gxe's Avatar
what kind is it?
Old Nov 11, 2007 | 09:15 PM
ShiftVQ35
the wideband is a plx r500. BY looking at the fsm, i can hook up the maf and the tps. Both of them are analog signals.
Old Nov 11, 2007 | 09:20 PM
yes I believe so
Old Nov 11, 2007 | 09:22 PM
NmexMAX's Avatar
dot dot dot ...
I hooked up to MPH/ECT/RPM/TPS/MAF on my PLXR300. FSM + common sense = FTW.
Old Nov 11, 2007 | 09:35 PM
ShiftVQ35
which pinouts did you use if you dont mind helping? fsm owns me haha. howevr i came up with pin #83 for tps and pin #62 for maf. thanks for the help
Old Nov 11, 2007 | 09:39 PM
NmexMAX's Avatar
dot dot dot ...
IMO, the MAF input is useless because the voltage is not a 1:1 relation to airflow. Not sure which ECU pin I used, but it doesn't matter since well, it's not a good relation.
The speed inputs (RPM/MPH) are very useful though.
Old Nov 11, 2007 | 09:46 PM
ShiftVQ35
alright i got 3 analog signals which are maf,tps,and ect. Tach is a speed input but what about mph? according to the fsm it stays at 2.5v but isnt it suppposed to vary?
Old Nov 12, 2007 | 05:29 AM
L.M.L.
seems like you are in trouble
Old Nov 12, 2007 | 05:42 AM
ShiftVQ35
Tach and speedometer are speed inputs and the rest are analog.
Old Nov 12, 2007 | 02:26 PM
ShiftVQ35
got it all hooked up today. time to log some data.
Old Nov 12, 2007 | 02:39 PM
NmexMAX's Avatar
dot dot dot ...
If it's a speed input, it needs to be a frequency, not voltage.
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
Slamrod
Sep 3, 2015 07:38 PM
scutmud
Aug 28, 2015 05:04 AM
