Sponsored by:
Sponsored by: CARiD
z33 injector pics
Old Dec 11, 2007 | 11:14 PM
DasYears
z33 injector pics
anybody got pics of the injector tips from the z33(fbjc100)? i feel like i got the wrong injectors and just want to be sure they are right. did the injector swap from my fbjc101 to the fbjc100 on monday and my WOT ratio went from 13.6:1 before to 17:1 after . not sure WTF's up, but that shouldnt happen. i put a bunch of injector cleaner in the tank even though i let the tips soak in some before i put them in, hopefully from the tank will clean them out. either theyre dirty or my old ones were on crack working big time overtime. i cant understand this
Old Dec 12, 2007 | 12:20 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i had a look around on my350z.com but couldnt come up with any photos. maybe the reverse would work by putting a photo of what you got on their forum ?
Old Dec 12, 2007 | 12:56 AM
DasYears
yeah, worth a try. i didnt get any pics cause i figured they were right. guess i could make a pic though.
Old Dec 12, 2007 | 01:01 AM
DasYears
heres a crappy paint rendition i made, i think it gets the point across
ceasers you had some DE-k injectors with that de-k i assume, did they look anything like the FBJC100 i just drew up?
Old Dec 12, 2007 | 06:03 AM
Puppetmaster's Avatar
I have some DE-K injectors in my garage and will try to get some pictures later this evening. Unless of course someone else beats me to that.
Old Dec 12, 2007 | 06:38 AM
NmexMAX's Avatar
dot dot dot ...
Mine were black w/ an orange 'ring' on them. Compared to my A33B units (which had the P/N clearly engraved) they only had a Bosch P/N on them, and they looked different (color scheme). I too thought maybe they weren't the correct pieces. But after some driving around with them, I noticed my MPG readout went a little higher. This tells me that when in closed loop, the ECU had to compensate a little more due to the slightly larger flow, which then made the trip computer think it was getting better MPG due to the slightly larger amount of fuel being taken out.
If you're going that lean, the car should run semi crappy. Also, make sure all the injector's seated properly.
How do yours look, and do they have a P/N on them (Bosch or other wise)?
If it's a Bosch #, PM Bewstaddict, he'll have info for you.
Old Dec 12, 2007 | 02:59 PM
DasYears
yeah, i did a WOT and it took FOREVER, not to mention i could tell the car wa pulling tons of timing
how do you know if theyre in properly? i clipped them into the fuel rail first and then pushed each one into the fuel rail and bolted it down...not sure if that could go wrong. guess ill try again.
they have a purple body and clearly say FBJC100 on the side...
Its weird because when i first tested it i had to take out 1 pt of fuel, which i was concerned with but no biggie. i tried a different intake, which i didnt like, and when i went back i had to add 7 pts of fuel. ill try pushing them into their further and make sure all the plugs are surely in. i can feel most of em ticking but ill check again.
Old Dec 12, 2007 | 03:00 PM
DasYears
thanks, i mostly only need the tip pattern since the body is certainly right. i just thought it was weird that the lower flowing injectors have a much better (looking) spray pattern than the higher flow ones.
Old Dec 12, 2007 | 04:04 PM
Old Maxima Legend
das, yeah thats it. i totally missed the connection with the Z33 injectors and the DE-K. i just took some photos as well. will post them up, but yours look right on for the fbjc100.
Old Dec 12, 2007 | 04:21 PM
Old Maxima Legend
should have used a flash but in the last photo you can see its a match !
Old Dec 12, 2007 | 04:24 PM
Old Maxima Legend
FBJC100 Nissan Maxima VQ30DE-K A33 Injectors
Old Dec 12, 2007 | 04:37 PM
DasYears
hmm, guess ill just have to make sure all is connected and that theyre clean. thanks. mine are purple, so i would guess that means they really are from the g35 they were supposed to be from. guess ill let you know if i figure it out
Old Dec 12, 2007 | 05:06 PM
Old Maxima Legend
that sounds cool ! lets swap so i can claim i have g35 injectors rather than de-k. lol !
Old Dec 12, 2007 | 05:23 PM
DasYears
lol. im starting to get the feeling nobody would want these. at least not until theyre cleaned out.
Old Dec 12, 2007 | 08:42 PM
Old Maxima Legend
these two in the photos were clogged and i just replaced them.
Old Dec 12, 2007 | 08:45 PM
NmexMAX's Avatar
dot dot dot ...
Jesus, I don’t know I got, mine looked nothing like that. :
Old Dec 12, 2007 | 08:47 PM
Old Maxima Legend
DE-K lower intake manifold and fuel rail
DasYears
how were yours different? do you mean spray pattern or body design?
Old Dec 12, 2007 | 08:50 PM
Old Maxima Legend
i will go have a look to see if i have more. i have some off a NZ spec A33 and a few off a US spec A33, in photo I believe those are NZ spec.
Old Dec 12, 2007 | 08:53 PM
NmexMAX's Avatar
dot dot dot ...
Mine are only different by color. Mine have an orange ring on the lower shoulder and do not have any FBJC# on 'em.
Old Dec 12, 2007 | 08:55 PM
DasYears
damn, injectors galore. im going to give this a week of driving with constant injector cleaner, then let reset the ECU while im gone over the weekend. if its still doing this BS lean thing, i think ill put the old injectors back in and send these somwhere to get them cleaned and possibly worked to a higher flow rate. hoping that after the week and reset i wont have to go through any more
Old Dec 12, 2007 | 08:56 PM
DasYears
you said you got the equivalent part # though right? aka it was a bosch z33 injector? its possible and likely that the stocks were replaced with those for some reason
edit: mine are also a diff color, purple...
Old Dec 13, 2007 | 06:33 AM
NmexMAX's Avatar
dot dot dot ...
If you have access to a sonic bath, clean them that way. This does require removal and reinstallation though. Sonicate 'em.
Old Dec 13, 2007 | 08:00 PM
DasYears
i dont know WTF a sonic bath even is. only thing i can think of is a machine used for rapid prototyping...
the reset is beginning, will be plugged back in tuesday and hopefully all will be good
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
